Checking for codes, is it the same process as the Supras? |
Dec 2, 2007 - 5:29 PM |
Enthusiast Joined Nov 7, '06 From Houston, Tx Currently Offline Reputation: 17 (100%) |
So on the way home from the movies last night, the car's CEL comes on for about 10 seconds and I nearly shat myself cuz this is the second time it's done this in a month.
Ok, so I know that with the MK3 Supras, you find the diagnostic box under the hood and connect lines TE1 and E1 together with a paper clip, turn the key to the on position and watch the CEL blink however many times to see what codes the ECU is throwing. I'm assuming I can use this same process on the Celica? Is there a list of what each number means or will they be the same as what the Supra's TSRM have listed? -------------------- -Alex {](O_o)[}
1993.5 Toyota Supra ....with stuff.... ....sorta broken.... 1998 Toyota Celica ....this one, too, has stuff.... ....broken....yeah...definitely broken.... |
Dec 2, 2007 - 5:47 PM |
Enthusiast Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
Yep it's just jumping TE1 & E1. I'm not sure if it is the same as the supra codes but the list is at http://www.toyotacelicaonline.com/error.htm .
Dec 2, 2007 - 6:19 PM |
Whoo! TPS (41) and EGR (71) system. [/sarcasm]
Thanks for the site. Much appreciated. Turns out most of the codes are the same for the Supra, so here's a website for you guys just in case you get a code that's not listed on the first one posted. It lists the trouble areas for each code, so it's pretty useful. http://www.cygnusx1.net/Supra/TechTips/eng...rror_codes.aspx -------------------- -Alex {](O_o)[}
Lo-Fi Version | Time is now: December 1st, 2024 - 10:06 PM |
