> fuel pressure regulator
post Dec 2, 2007 - 9:41 PM
pabel89
Joined Sep 28, '07
From new jersey
ok as most of u kno im trying to turbocharge my 7afe to a 7afte im using a walbro fuel pump and i need a fuel pressure regulator some suggested the 1:1 fuel pressure regulator but i found this universal one in ebay. let me kno what u think. and will it work ?
http://cgi.ebay.com/ebaymotors/Fuel-Pressu...sspagenameZWDVW
post Dec 2, 2007 - 9:45 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
buy the sard brand if you want qaulity
post Dec 3, 2007 - 12:21 AM
Harold_Fastwaker
Joined Aug 8, '07
From United States
I don't trust $23 FPRs
post Dec 3, 2007 - 1:33 AM
OOBE
Joined Aug 30, '02
From San Juan, PR
Go ahead and set the example, Pabel. When your car just throws a piston out the hood, you'll know why we stress so much that taking the cheap route is bad. You need to stick to quality parts. If they're wholesale cheap in price parts on eBay, they will be cheap on quality too.
post Dec 3, 2007 - 3:04 AM
beno
Joined Nov 22, '05
From New Zealand, Hamilton
I was just talking to a tuner for my ecu and he said; sard definately, you dont ever mess around with something that important. but everyone has their own opinion. He also said that there are other good brands but he has found the sard to be good quality and reliable.
I think the 'sard standard rising rate' is the one that youll want for a turbo. 1:1 wouldnt be rising rate but the best thing you can do is to ring a ecu tuner and chat with them
This post has been edited by beno: Dec 3, 2007 - 3:06 AM
post Dec 3, 2007 - 5:29 AM
ice23q
Joined Jan 16, '04
From sydney australia
I have a Magnafuel reg.....works real good..... Have a look.
http://www.magnumforce.com/magnaflow_fuelr...0Control%20Unit.
312whp with more to come....
post Dec 3, 2007 - 2:36 PM
pabel89
Joined Sep 28, '07
From new jersey
ok so a sard fuel regulator when i install the supra TT walbro fuel pump it will fit right in i dnt have to do anything custom so it can fit in my car???
post Dec 3, 2007 - 5:02 PM
QUOTE(beno @ Dec 3, 2007 - 4:04 AM) [snapback]619169[/snapback]
actually, beno, a 1:1 regulator, al'la the 3sgte stock one, IS a rising rate FPR, it raises FP 1psi for every psi of boost.
so, if your running 5psi, it adds 5psi of fuel pressure, ect.
post Dec 3, 2007 - 9:54 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
Yeah, when I read that I was like "wat", LOL. What is a 1:1 if it's not rising rate? laugh.gif
post Dec 9, 2007 - 9:51 PM
Tony_the_Tiger
Joined Dec 2, '07
From Canada
1:1 is standard really... When we refer to rising rate, it also means "additional" fuel is increased as boost rises. Pretty much all factory fuel regulators are 1:1. There is no additional fueling with a 1:1 regulator.
The SX 2:1 is a true rising rate. The Cartech FMU are rising rate regulators. The engine is receiving additional fuel whenever boost increases.
A 1:1 regulator doesn't increase more fuel.. it maintains base fuel pressures when fuel is firing from the injector.
For exmaple, 45 PSI base pressure at the fuel rail minus the 20 PSI positive pressure in the intake manifold = 25 psi of fuel from the injectors due to boost fighting against the injector itself.
A 1:1 rising rate will maintain 45 psi firing out of the injector. 65 PSI rail pressure fighting against 20 PSI of manifold pressure will still result in only 45 psi exiting the injector.
Anything higher than 1:1 will be considered a true rising rate. smile.gif
This post has been edited by Tony_the_Tiger: Dec 9, 2007 - 9:51 PM
'94 Supra TT 6spd; AEM EMS, HKS T51R KAI BB; 737 WHP @ 23 psi
'94 Camry V6; AEM EMS, GT4088R; 520 WHP @ 26 psi
'01 IS300; EMU, GT4088R; 381 WHP @ 10.5 psi
'95 Integra GSR; AEM EMS GT2871R; 383 WHP @ 18 psi
post Dec 17, 2007 - 3:22 AM
beno
Joined Nov 22, '05
Yeah i was thinking aftermarket rising rate meant that it more than proportionally increases the fuel pressure ie not just at a linear rate of 1:1
This post has been edited by beno: Dec 18, 2007 - 1:24 AM
post Dec 17, 2007 - 5:23 AM
Turbofun
Joined Dec 11, '07
From Norway
That ebay FPR will actually close fuel return when the pressure is risen enough. Pretty crappy.
Lo-Fi Version Time is now: November 24th, 2024 - 3:50 PM
