> turbo timer
post Dec 4, 2007 - 7:51 AM
dagreat1
Joined Mar 27, '06
From Gainesville
I have a 3sgte with an up graded turbo (T4).... about how long should i set my turbo timer for?
post Dec 4, 2007 - 10:07 AM
CaliJeff
Joined Apr 22, '07
From Bay Area, California
doesnt matter what kind of turbo u have, depends on how hard u push ur car. so if u gave it a good a hard drive, maybe a minute, otherwise i would set it for 30 seconds any other time.
You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=-
post Dec 4, 2007 - 12:27 PM
dagreat1
Joined Mar 27, '06
From Gainesville
even when pushing 20lbs?
post Dec 4, 2007 - 12:35 PM
QUOTE(dagreat1 @ Dec 4, 2007 - 12:27 PM) [snapback]619549[/snapback]
besides just a turbo upgrade, what other mods do you have?
post Dec 4, 2007 - 12:39 PM
dagreat1
Joined Mar 27, '06
From Gainesville
2nd 3sgte JDM Motor Swap Garrett T3/T04e 60 trim Polished Turbo(15psi) South Florida Performance turbo manifold SFP 3" downpipe Full 3" exhaust setup(resonator, high flow cat, flex pipe, apexi n1 muffler) Spearco Front Mount Intercooler w/ 2.5" pipes SAFC Supra 550cc injectors Wolfkatz high flow fuel rail 255lph walbro fuel pump Braided stainless fuel lines Tial 38mm wastegate 1993 MR2 E153 tranny ACT HD clutch kit(brand new) 13" Big Brake kit w/ Wilwood calipers GT rear disc brake conversion Japanese rear motor mount(not a custom mount) . Polished engine parts HKS SS blow off valve Magnecor plug wires
i know ya didn't need to know half of that, but w.e.
This post has been edited by dagreat1: Dec 4, 2007 - 12:39 PM
post Dec 4, 2007 - 12:50 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
before i get my timer on, i wait til the oil pressure dropped to 40
This post has been edited by LewFX: Dec 4, 2007 - 12:50 PM
post Dec 4, 2007 - 12:55 PM
Lew - what?
DaGreat1 - post some pics seems like a nice little setup you have.
For reference - I set my timer for 1 minute if I'm driving around normally, 2 if I drove it hard.
And it matters a little bit what turbo you have because some are water cooled & oil cooled or both and different substances have different requirements.
post Dec 4, 2007 - 1:02 PM
water & oil cooled = don't use a turbo timer
oil cooled = use a turbo timer, 1 min is a typical run time
post Dec 4, 2007 - 1:07 PM
Well, I wouldn't say DON'T because it sounds negative. It's not required. It's always a good idea to warm the car up before boosting and cool it down after driving.
This post has been edited by Supersprynt: Dec 4, 2007 - 1:10 PM
post Dec 4, 2007 - 1:17 PM
dagreat1
Joined Mar 27, '06
From Gainesville
i put 2 new ones up in my profile... i'll put up more but i have to run to class.... todays the last day and then have a calc 3 final tomorrow... yipee!
post Dec 4, 2007 - 1:26 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
uh... so i bought a blitz FATT for nothing since i got a oil + water cooled turbo?
This post has been edited by elvasoshexai: Dec 4, 2007 - 1:41 PM
06 Civic EX
My For Sale Thread
post Dec 4, 2007 - 1:40 PM
LewFX
Joined Jan 28, '05
mines oil and water cooled but i still want to use the timer. usually i wait 2-3 minutes to turn it off
post Dec 4, 2007 - 2:01 PM
Kadett
Joined Mar 17, '05
From The Netherlands
It depends on all kinds of things.
When I get from the highway and have to wait a minute for a traffic light and then drive slowly/normal (2k rpm)I dont use the TT or max 10 seconds. When its green all the way to my house and have done some high rpms speeds its about 3 minutes.
This post has been edited by Kadett: Dec 4, 2007 - 2:01 PM
post Dec 4, 2007 - 3:56 PM
3 minutes just seems like a waste of gas to me; especially with the water cooling.
post Dec 4, 2007 - 4:23 PM
QUOTE(dagreat1 @ Dec 4, 2007 - 12:39 PM) [snapback]619557[/snapback]
you are going to do more harm with the safc trying to control 550s, then you will by running without a turbo timer. but to answer your question, i set mine for 45sec, and 1min20sec, if i JUST got done beating on it.
post Dec 4, 2007 - 4:36 PM
the purpose for the TT was when turbos didn't have the advancement of water and oil cooling.
With oil cooling alone, when people would turn off their cars, the oil pump would stop and flow ceases. This would leave a small pool of oil left inside the turbo journals, which from the heat would coke. Thus giving negative affects to performance & part longevity.
With the advancement to oil & water cooling there is no longer an issue with oil coking. Which brings the bandaid of the TT to a superfluous piece of equipment.
Although I do highly agree that you need to let your car cool off for a BRIEF period of time after a nice hard drive. really no longer than a min or 2 at the most. Reason why is most modern cars now have provisions for after you turn the car off, it keeps a fan on or other cooling measures. the longer your TT runs the easier it is to steal.
post Dec 4, 2007 - 4:38 PM
There are safe guards against being stolen. First and foremost being the E-brake must be up to enable the TT.
post Dec 4, 2007 - 4:42 PM
i wouldn't like the E-brake as a safty..
only because when you are driving hard (IE track days/mountain runs)
you are braking hard, this brake heat normally lasts just as long as your engine heat.
when you stop you shouldn't be applying your e-brake, but leaving your car in gear to hold it.
having an e-brake applied on heated brakes can easily cause severe rotor damage.
any suggestions for another way to safeguard, for those who fall under that catagory?
This post has been edited by playr158: Dec 4, 2007 - 4:42 PM
for the most part, i agree that turbo timers are a ricer toy, but if you read the owners manual for an alltrac or mr2, they even tell you to let the car idle for about 120sec or so after hard driving.
post Dec 4, 2007 - 5:16 PM
QUOTE(playr158 @ Dec 4, 2007 - 4:42 PM) [snapback]619633[/snapback]
I think "track day" is something few and far between to negate the safety feature altogether. That being said, your point is still valid.
Regardless of the ebrake light being on - without the key wouldn't the steering wheel lock?
This post has been edited by Supersprynt: Dec 4, 2007 - 11:32 PM
Lo-Fi Version Time is now: November 28th, 2024 - 8:43 PM
