clutch combo swap ??? |
Dec 4, 2007 - 4:33 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
well i'm gonna drop a 4age in a friends ST and we're using the ST tranny.
i was wondering what clutch combo i'm supposed to use??? is it the 4age clutch and ST pressure plate????????? or vice versa??? -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Dec 4, 2007 - 4:39 PM |
Pressure plate & flywheel from the 7afe, 4age clutch disc *is not correct.
*Edited. This post has been edited by Supersprynt: Dec 4, 2007 - 5:40 PM -------------------- |
Dec 4, 2007 - 4:42 PM |
please try and post in the appropriate forum.
13.6@108MPH, 5SFTE Powered |
Dec 4, 2007 - 4:48 PM |
QUOTE(Supersprynt @ Dec 4, 2007 - 9:39 PM) [snapback]619631[/snapback] Pressure plate & flywheel from the 7afe, 4age clutch disc. Doesn't work the same for a 7AFE/4AG as it does for a 3SG/5SFE... You use the 4AGE flywheel and clutchkit. The 4AG clutch is basically the same as the 7AFE... -------------------- "It's ok to be naked girl... I'm an artist!"
Dec 4, 2007 - 5:09 PM |
I tried to be logical
Will that setup plain old not work, or is it just easier to use the complete 7a kit? This post has been edited by Supersprynt: Dec 4, 2007 - 5:10 PM -------------------- |
Dec 4, 2007 - 5:36 PM |
QUOTE(Supersprynt @ Dec 4, 2007 - 10:09 PM) [snapback]619648[/snapback] I tried to be logical Will that setup plain old not work, or is it just easier to use the complete 7a kit? It won't work because the 7A is a 6 bolt crank while the 4AG is an 8 bolt crank. The actual flywheel itself is basically the same thing (besides the bolts), as is the clutch kit. This post has been edited by Kwanza26: Dec 4, 2007 - 5:37 PM -------------------- "It's ok to be naked girl... I'm an artist!"
Dec 4, 2007 - 5:39 PM |
I should have known better than to meddle in the A-series motor affairs.
Thanks for the info. -------------------- |
Dec 4, 2007 - 6:15 PM |
so 4age everything..........
Lo-Fi Version | Time is now: November 24th, 2024 - 4:40 AM |
