![]() Enthusiast ![]() Joined Nov 24, '06 From Kansas City Currently Offline Reputation: 2 (100%) ![]() |
How do you remove the govenor / rev limiter. My car tops out at 112mph I believe. A buddy of min on his tc said all he had to do was unplug something and it was removed? let me know please.
1994 GT 5sge |
I think you mean 5sFe. I'm fairly certain certain there is no govenor on GTs.
![]() Enthusiast ![]() ![]() ![]() Joined Feb 8, '04 From Thornton, CO. Currently Offline Reputation: 1 (100%) ![]() |
I thought a governer regulates/directs hydraulic pressure in an automatic tranny?
-------------------- Fred
"...Armed with backbone and busted zoo gates, promising you from the bottom of my harmonica pocket - FOREVER - you will never have another lonely holiday..." ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 12, '07 From Houston, TX Currently Offline Reputation: 4 (100%) ![]() |
QUOTE(Supersprynt @ Dec 5, 2007 - 9:49 PM) [snapback]619993[/snapback] I think you mean 5sFe. I'm fairly certain certain there is no govenor on GTs. If your GT is in the US it has a governer unless it gets rerouted. Removing the governer makes your car not street legal. And I'm pretty sure it kicks in at 120 mph, as I tested it in my ST on the way to Galveston. Perhaps the GT is different than mine, but I can't imagine why they would let the 7A go faster than the 5S. But then again, stranger things have happened... -------------------- "He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn." "What?" "Just do it." ".......He said yes." "Tell him you are not darklings. He should open up." ".......Sweet. Thanks." "No problem." |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 28, '04 From St.Louis Currently Offline Reputation: 15 (100%) ![]() |
my ST has a governor that kicks in at 116, and my GT i have reached 135 indicated and then it was drag limited, but with more HP it would have gone further than that at least. Just my experience
-------------------- ![]() 1994 GT Hatchback 1994 ST Coupe 1988 Corolla Wagon All-Trac 1999 Corvette 2008 Cobalt SS Turbo |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 7, '06 From Lawrence IN, 46226 Currently Offline Reputation: 17 (100%) ![]() |
my gt topped out at 137, that was b/c i had no more room. i could have gone a lil higher i am sure. i never hit a limiter
Enthusiast ![]() ![]() Joined May 23, '06 Currently Offline Reputation: 0 (0%) ![]() |
I know the ST has a fuel cut at 5k rpm in 5th stopping it at around 115-116. I remember somewhere on here is how to remove it.
All i remember is you need to cut some wire in the back of your ecu and doing this will result in a permanent check engine light. |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 19, '05 From Nebraska Currently Offline Reputation: 4 (100%) ![]() |
QUOTE(terqui @ Dec 6, 2007 - 1:52 PM) [snapback]620231[/snapback] All i remember is you need to cut some wire in the back of your ecu and doing this will result in a permanent check engine light. which is why you probably shouldnt do it. -------------------- Teh Celica sleeps for Winter '06. Suspension overhaul begins........
Enthusiast ![]() ![]() ![]() Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) ![]() |
QUOTE(mneal2_92788 @ Dec 5, 2007 - 11:14 PM) [snapback]620080[/snapback] my gt topped out at 137, that was b/c i had no more room. i could have gone a lil higher i am sure. i never hit a limiter lol, exact same for me. There is no limiter on the gt. But there is no need to go over 112. I was just young and stupid ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) ![]() |
QUOTE(terqui @ Dec 6, 2007 - 1:52 PM) [snapback]620231[/snapback] I know the ST has a fuel cut at 5k rpm in 5th stopping it at around 115-116. I remember somewhere on here is how to remove it. All i remember is you need to cut some wire in the back of your ecu and doing this will result in a permanent check engine light. http://evilspeed.com/Speed_defeat.htm ![]() -------------------- |
Lo-Fi Version | Time is now: February 20th, 2025 - 1:28 AM |
