![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 12, '06 From Wilmington, NC Currently Offline Reputation: 45 (100%) ![]() |
QUOTE(pitcelica @ Dec 9, 2007 - 9:33 AM) [snapback]621109[/snapback] So, as I can seen, a lot of people want to know what are the aftermarket parts are available for the ST215 3SGTE engine. Here's are some parts that are bolt on : -Adjustable cam gear (AEM, Fidanza, HKS, OBX, ATS). Any cam gear kit for 3SGTE will fit. -XS Power SSAC ST205 manifold/downpipe used with a ST205 turbo will convert the one-piece ST215 manifold/turbo to a nicely upgradeable ST205 Ct20b turbo kit. You can add to this a t3/t4 adaptor and you will be able to use a t3/t4 turbo (like I did on my ST215 swap) -Pistons, rods, crankshaft are all the same for ST205 and ST215 -The injectors are the same as the ST205 one, so, if there is a 3rd gen fuel system available, it will fit the ST215 too. -The exhaust camshaft is the same as the ST205 one. So an HKS 264/272 exhaust camshaft will bolt on. For the intake, I don't know if the HKS one would fit. Next year, when money will allow it, I'll buy a HKS264/264 camshaft kit and I'll know if the intake camshaft fit or not. -You can remove the top ATA intercooler and add a FMIC as easy as any other 3SGTE. The things that need heavy custom work is the ECU/wiring harness, ignition component (because of coil-on-plug). In my case, I used a Megasquirt II ECU with Ford EDIS wastespark ignition system and everything works nicely. The other aftermarket parts like BOV, wastegate, air intake, boost controller etc, can be fitted easily like on any other 3SGTE engine. So plz, stop saying that the ST215 engine isn't easily modifyable, there are plenty of parts that can be used to give a lil more hp to this unknown beast. Thanks Sam from the link: QUOTE The fuel rail is top feed and beefy. I'm assuming that the 3rd gen is side feed then, which means the injectors and fuel rail are not interchangable. and QUOTE The cams are not interchangeable with previous generation motors because they lack the distributor notch and run an internal cam sensor instead. this one speaks for itself. the rest of the stuff is probably interchangable like you said though. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
3 CHEERS FOR SAM!!!!!!!!!!
![]() ![]() ![]() ![]() ![]() HIP HIP...... -------------------- |
Enthusiast ![]() Joined Jan 28, '07 From Québec, Canada Currently Offline Reputation: 1 (100%) ![]() |
The 4th gen fuel rail isn't top feed. The fuel enters from one end and go back to the tank at the opposite end.
Here's a pic of the ST205 fuel rail and injectors : ![]() Here's a pic of the ST215 fuel rail and injectrors : ![]() Here are some pics of the engine naked (ST215) : ![]() ![]() ![]() ![]() Maybe I don't understand clearly what's the difference between top-feed and side-feed fuel rail (I come from Quebec and I speak french), so, be gentle if I made a mistake in understanding. You're right, the injectors aren't interchangeable, because according to EPC, the ST205 one and ST215 one don't have the same part number. But both of them are 540cc and ST215 are high impedance. For the cam, exhaust cam are the same for ST205 and ST215 (EPC part number are the same). But for the ST215 intake camshaft, there is a little arm that provide info to a cam position sensor at the rear end. But I'm sure that someone machinist can cut the distributor end of a ST205 intake HKS camshaft and drill a hole for the little arm for the sensor and I'm sure that it will fit. It's maybe what I'll do if I buy new camshafts. |
Here's a pic of the cam sensor and trigger shaft mentionned above :
Side feed injectors, as the name implies, feeds the fuel into the side of the injector and then it goes down through the tip. While top feed injectors have the fuel go through the top of the injector as in your picture of the ST215 ones. The pictures you posted also shows that the ST205 fuel rail is side feed.
Ok, thanks,
I was thinking that the side feed or top feed was only the fuel rail setup: If the rail receive fuel from one end to the other, this was a side feed fuel rail. If the rail receive fuel from the top (center) to each end, this was a top feed rail. Thanks for the input! I suppose that this is why ST205 injectors have a larger body diameter than the ST215 for the same flow rate. What are the differences in performance between both (side feed and top feed) for the injectors, what should narrow my choice to top-feed or side feed injector if I have to change them for aftermarket ones. Thanks |
![]() Enthusiast ![]() ![]() ![]() Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(pitcelica @ Dec 7, 2007 - 12:45 PM) [snapback]620539[/snapback] I know that the exhaust cam is the same as ST185 and ST205. Here's my guess for the intake cam : Specs of stock ST185 cams: Ex, max cam lift 8.2 mm, 236°, max lift at 118° BTDC, open 56° BBDC, close 0° In, max cam lift 8.2 mm, 236°, max lift at 110° ATDC, open 8° BTDC, close 48° ABDC Overlap 8° Specs of stock ST205 cams: Ex, max cam lift 8.2 mm, 236°, max lift at 118° BTDC, open 56° BBDC, close 0° In, max cam lift 8.7 mm, 240°, max lift at 113° ATDC, open 7° BTDC, close 53° ABDC Overlap 7° Specs of stock ST215 cams: Ex, max cam lift 8.2 mm, 236°, max lift at 118° BTDC, open 56° BBDC, close 0° In, max cam lift 8.7 mm, 244°, max lift at 113° ATDC, open 7° BTDC This is my guess for the 4th gen cam specs For the valve spec, according to the EPC, 4th gen 3sgte intake valve aren't interchangeable, so they aren't the same as other gen. According to the EPC, the exhaust valves of the 4th gen are the same as the 3rd gen ST205 one. So, find the diameter of the ST205 exhaust valve and you will know the spec of these 4th gen exhaust valves. I own a 4th gen too. If I disassemble the head, I'll take measurement to have the spec of the head. hmmm....thanks for the specs. I'm gonna guess that if the 3rd and 4th gen intake valves are not interchangale then mabey the 4th is slightly larger?... a guess though.... -------------------- ![]() CLOSED on 25 acres! -shop coming soon.... |
QUOTE(pitcelica @ Dec 10, 2007 - 3:03 PM) [snapback]621493[/snapback] Ok, thanks, I was thinking that the side feed or top feed was only the fuel rail setup: If the rail receive fuel from one end to the other, this was a side feed fuel rail. If the rail receive fuel from the top (center) to each end, this was a top feed rail. Thanks for the input! I suppose that this is why ST205 injectors have a larger body diameter than the ST215 for the same flow rate. What are the differences in performance between both (side feed and top feed) for the injectors, what should narrow my choice to top-feed or side feed injector if I have to change them for aftermarket ones. Thanks I'm not really sure if there are any performance benefits out of either, just that there is a greater aftermarket support for top-feed. -------------------- ![]() 94 GT - Sold -------- 69 Pontiac Lemans - Sold 88 Alltrac - Sold ---- 04 WRX - Sold 00 GT-S - Sold ------ 91 Miata - project/drift car 95 GT - Sold -------- 96 GT - New Daily Drive |
Enthusiast ![]() Joined Jun 25, '06 From miami Currently Offline Reputation: 0 (0%) ![]() |
EAST, share some info with us on the after market parts for the ST215 engine...my choice is runninng in the middle of the ST205 engine and the ST215... wow pit! this info is pretty useful! though im no gear head, im always trying to learn more. Chacha, sorry, dont have much in the way of aftermarket available here BUT i will try to get a hold of herbalife to find out what after market parts he had on his, im pretty sure he had an AEM fuel rail slightly modified but the caldina he has is in jamaica, and i dont have the list of stuff he has in my mail, will get back to ya on it if i can though TALK about being super late but heres herbalife car http://www.wheelsjamaicahost.com/wheels_fo...p?topic=81728.0 |
![]() Enthusiast ![]() ![]() ![]() Joined Dec 15, '02 From Tasmania(Australia) Currently Offline Reputation: 0 (0%) ![]() |
anyone know if the gen4 has oil squirters, 3 angle cut and stainless steel valves like gen3 does?
-------------------- ST205 Group A Rallye GT-Four, #61 of 77............600hp GT3582r
GRX133 Toyota Mark X 350s ![]() |
yes it has oil squirter, I have a spare gen4 head at home. I'll check for the stainless valves and the angle cut. I'll post close pics of valves and head.
i thought herbalife went to georgia? i guess he's back with his baby in jamacia! .... damn im late! ive been meaning to talk to that guy, cant get a hold of him!
Lo-Fi Version | Time is now: February 18th, 2025 - 3:00 AM |
