> Idle adjustment question
post Dec 6, 2007 - 9:16 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
This is a noob question, is it clockwise or counter to increase the idle on the 3sgte
post Dec 6, 2007 - 9:51 PM
what exactly are you trying to turn, because the 3s doesnt have an idle adjustment.
post Dec 7, 2007 - 2:58 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
are u serious, everyone on the mr2 forum said it was located on the top of the throttle body facing away from the car, i found it and it does turn, just don't know which way
post Dec 7, 2007 - 4:53 PM
whats wrong with your idle? there is probably something like a vac leak, or your timing is not set correctly thats causing it to not idle right.
the ecu auto corrects idle. if you mess with that screw it will work for a day or so until the ecu auto corrects itself again.
This post has been edited by lagos: Dec 7, 2007 - 4:54 PM
post Dec 8, 2007 - 12:12 AM
supra12big
Joined Aug 19, '07
From Farmington, MI
okay well i will explain my idle to u, it idles fine for like 30 secs, then misses once and drops to 700 from 850, then goes back up
but if I hold the gas really easy at like lets say 900 it doesn't miss at all, any ideas
post Dec 8, 2007 - 1:07 AM
then you have a vac leak somewhere between the afm and the throttle body. do a boost leak test to find it.
post Dec 8, 2007 - 11:16 AM
supra12big
Joined Aug 19, '07
From Farmington, MI
I already did a boost leak down test, and fixed all that, every connection spot is good, I gonna clean my afm, change my fuel filter, and clean my injectors, new cap and rotor and go from there, how does that sound?
post Dec 8, 2007 - 1:49 PM
check your timing too.
if you do all that, and the problem is still there, then i would look into trying another afm and see if it helps.
post Dec 8, 2007 - 11:47 PM
supra12big
Joined Aug 19, '07
From Farmington, MI
ya, i dunno how to check timing, i am a noob at that, is there a how to or, not if not how much does a shop charge?
post Dec 9, 2007 - 12:08 AM
thespacepanda
Joined Apr 12, '07
From Houston, TX
To adjust timing you loosen the bolt that holds the distributor on and while the car is running you turn it eeeeeever so slightly until you get the right timing. If you don't know what to listen for you can use a timing light. I think autozone will let you borrow one.
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Dec 9, 2007 - 10:31 AM
supra12big
Joined Aug 19, '07
From Farmington, MI
isn't that a little dangerous if ur playing with the timing while the car is run, like i don't want to be turning it and have some **** break if u know what i mean, how much does a shop usually charge
post Dec 9, 2007 - 11:37 AM
QUOTE(supra12big @ Dec 9, 2007 - 10:31 AM) [snapback]621086[/snapback]
the only way to check the timing is when the car is running.
It's time for you to not be a noob and learn how to check some things with your car. Checking/adjusting the timing takes about 5 minutes at most, you just need a timing light and some know how.
post Dec 9, 2007 - 3:02 PM
all the info is in here.
http://www.celicatech.com/93rmsour/1993/93...3celica_bgb.php
post Dec 10, 2007 - 6:54 AM
supra12big
Joined Aug 19, '07
From Farmington, MI
lol, actually i am not really a noob, i did the swap on the most part, lol, but timing and suspension are my weaknesses
Lo-Fi Version Time is now: November 24th, 2024 - 7:44 PM
