> steering "clunking"
post Dec 8, 2007 - 12:12 PM
captainpyro1
Joined Nov 12, '07
From NH
when my wheel is dead straight, its ok, but once i go past about 10 degrees to the left of right it will make this "clunk" noise. it sounds like its coming from somewhere near where the firewall and "cab" meet.... any ideas? and i dont think its lack of power steering fluid, its exactly full-but not too full.... any ideas why?
post Dec 8, 2007 - 12:18 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
bad cv joint or axle...tie rod?
post Dec 9, 2007 - 6:39 AM
prowzee
Joined Jan 17, '07
From (CA) orange county
yeah.. i had the same thing going on for a while and went to replace my axles in a shop on friday , i found out that they gave me the wrong part so they orderd another axle.. it was suppose to be done at the end of the day, so i went to pick up my car. the tech went to test drive it and i look down the block and see my car with the hazard lights on so im like wtf, and he told me the axles came off.. so there not getting back to it till monday mad.gif
This post has been edited by prowzee: Dec 9, 2007 - 6:46 AM
post Dec 9, 2007 - 9:35 AM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
This happens to me as well. In the morning when it is cold outside and my car is warming up, I will reverse out of my driveway. When I get to the end and start turning the wheel it clunks like 3 times.
Usually it happens after I go too an almost extreme of turning my wheel. Like almost all the way to one side or the other. Then it's like something clunked out of a socket because when I turn it in the opposite direction, it clunks once more.
A mechanic told me its no biggy cause it wont be too bad now, but later on when it gets worse, there will be a lot of play in the steering.
"You should take a short walk on a LONG PIER"-Crazy Steve
My Celica's SRI
post Dec 9, 2007 - 10:57 AM
adam_coverdale
Joined Jul 26, '07
From Luton
Ususually that is a knackered CV Joint, I would replace immediately as you dont know when it's gonna fail and pop out!!
post Dec 9, 2007 - 11:27 AM
captainpyro1
Joined Nov 12, '07
From NH
if its a cv joint wouldnt it only do it on one side? i mean usually only 1 cv joint goes at a time, and this is defiantly coming from near where my feet are, my dad suggested a tie rod, or steering knuckle?
post Dec 9, 2007 - 3:56 PM
cHinaman727
Joined Jun 8, '07
From Houston, Texas
QUOTE(captainpyro1 @ Dec 9, 2007 - 4:27 PM) [snapback]621098[/snapback]
somethin in there. Mine does it too. Clunks @ both extreme turns.
My Celica's SRI
post Dec 10, 2007 - 5:59 AM
trdproven
Joined Aug 2, '05
From Guam
Most commonly seen on worn strut mounts.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
Lo-Fi Version Time is now: December 2nd, 2024 - 8:41 AM
