lowering a ssII, GT4 springs or GT?, what springs do i need |
Dec 9, 2007 - 11:08 AM |
Enthusiast Joined Dec 15, '05 From UK - norfolk Currently Offline Reputation: 0 (0%) |
hi there, i'm in the process of buying a 1995 white ssII import, i'm quite excited. I'm
trying to get most of the parts i need to modify delivered before so i can get them on the car asap. but my problem is that i'm not sure what lowering springs do i buy, springs for a GT4 or normal GT springs. any help greatfully recieved. -------------------- imghttp://i111.photobucket.com/albums/n153/LI...KINGy2j/sig.jpg[/img]
Dec 9, 2007 - 11:25 AM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
Since the SSII uses the same front shocks as the GT4 I would say GT springs in the rear and GT4 springs in the front. TRD sells front and rears seperate.
-------------------- JDM Powerplant installed, BPU coming very soon!
Dec 9, 2007 - 6:24 PM |
ST202 and ST205 springs are both compatible. superstrut suspension or macpherson, doesn't matter. they both work.
but fyi, the gt-fours will generally have a stiffer spring rate for the rears to make up for the heavier rear end (about 55% stiffer than the st202) i'm currently using RSR st205 springs on my stock macpherson struts. so use any kind of spring for the front (for a st202 or st205, your choice) but get st205 rear springs if you want a stiffer ride. This post has been edited by azian_advanced: Dec 9, 2007 - 6:27 PM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
Dec 12, 2007 - 4:49 PM |
thats excellent, thanks alot for the help.
btw, does a ssII have the same break as a normal GT? -------------------- imghttp://i111.photobucket.com/albums/n153/LI...KINGy2j/sig.jpg[/img]
Dec 17, 2007 - 5:56 AM |
Enthusiast Joined Mar 14, '05 From Auckland,New Zealand Currently Offline Reputation: 1 (100%) |
superstrut is optional on ssII so check first if you have a superstrut suspension system.
Dec 19, 2007 - 12:50 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
how much does GT4 springs lower the car by, and later on when the springs compress properly?
Lo-Fi Version | Time is now: November 27th, 2024 - 12:39 AM |
