![]() Enthusiast ![]() ![]() ![]() Joined Dec 20, '07 From Valkeakoski, Finland Currently Offline Reputation: 0 (0%) ![]() |
And come on guys, the sound when you got ~4k rpm and coasting, its sensational <3
This post has been edited by Penkka: Feb 19, 2008 - 7:54 AM -------------------- |
Enthusiast ![]() ![]() ![]() Joined Jun 21, '07 From SoCal Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(Penkka @ Feb 19, 2008 - 12:54 PM) [snapback]643162[/snapback] And come on guys, the sound when you got ~4k rpm and coasting, its sensational <3 woot woot yes its worth it hearing the sound and feeling instead of gas mileage |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) ![]() |
Enthusiast ![]() ![]() ![]() Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) ![]() |
the main difference I see is if I drive economically I get about 8.5 litres per 100km city and If I have a heavy foot I get up to 10.5 litres per 100km, freeway I get under 8 litres per 100km.
This post has been edited by Euphoria: Jul 27, 2009 - 10:46 PM |
Enthusiast ![]() Joined Dec 28, '08 From long beach, CA Currently Offline Reputation: 0 (0%) ![]() |
Ive been doing some experimenting on my car and the best i have come up with is 28.5 mpg. This is a mix of street and highway. I achieved this by driving 60 mph on the highway, it is really slow but i get decent mpg. on the street the car has no problem but once you drive 70mph gas just burns like no other.
My suggestion: Drive 60-65mph, and set your **** on cruise control cause that **** does wonders!!!! werd |
Enthusiast ![]() ![]() Joined Apr 29, '03 From lynn,ma Currently Offline Reputation: 0 (0%) ![]() |
Consider driving at 65mph instead of +75 (which is considered slow here in CA). Also tail other cars like SUVs, trucks, and vans. Was watching Myth Busters the other day and you can increase your fuel efficiency by up to 35% depending how close you tail another car. I'm NOT saying you to follow 10 feet behind someone else, but instead of being the leader of every pack, consider being a follower instead. Even following 50 feet behind another car can reduce drag and save you ~5-10% on gas. My drive up from LA to SF, I made it on one tank (400 miles) by tailing behind RVs and semis and going ~70mph. On the way down from SF to LA, I was rushing fast (+80mph) and I had to refill at 330. So yeah, it does make a big difference how fast you're going on the highway. Plus I shift to neutral when going down steep hills (is this bad? idk ![]() actually, your better off letting your foot off the gas, and coasting in gear. anytime your above 1500rpm, in gear, and not on the gas, there is NO fuel being injected. coasting in neutral down a hill or to a stop your wasting more fuel (because your using fuel at idle) than coasting in gear. ![]() THANK U!!! i always use to shift in neutral too and thought i was saving gas..... wow i didnt think it was the case but i did some googling and bam! it hit me source from popularmechanic q&a on a google search so it cant be wrong right? lol Q: I have a question about fuel economy. If you are driving downhill, do you save gas by putting your transmission in Neutral and coasting, instead of having your vehicle in Drive? I think that you do but my wife seems to disagree. Can you give me the correct answer, so I can tell her that I’m “Mr. Right,” as usual? A: That depends. The engine isn’t braking the car going downhill if the transmission is in Neutral, so economy would seem to be high. But if you think the engine is still using fuel while coasting downhill in gear, you’re laboring under a misconception. Most fuel-injected cars turn the fuel delivery completely off when you lift your foot from the accelerator. They still burn fuel when idling in Neutral, so do the math. The amount of fuel burned at idle over, say, a couple of miles of coasting downhill is small, but it’s still more than zero. So if you’re driving a modern fuel-injected car, you’re wrong. Older, carbureted cars would suck gas through the engine while coasting in gear, even if you turned off the ignition switch. In this case you’d be right. This post has been edited by kamax: Aug 8, 2009 - 4:37 AM |
Enthusiast ![]() ![]() Joined Jan 27, '09 From New Orleans Currently Offline Reputation: 4 (100%) ![]() |
i get close to 400 every tank!
I get around 400 when I hit empty, but I've been told I drive like a granny.
![]() -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'93 MX-5 LE |
Enthusiast ![]() ![]() Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) ![]() |
I drove my car to 425 miles on 13.2 gallons. Thats about 32MPG. I've gotten up to 35. I'm going NC on Friday, and that's like an 800 mile drive. I'll tell you what I get going down there. I'm shooting for 36+.
Also, I'm pretty sure our gas tanks are 15.9 gallons... |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 16, '03 From Bay area Currently Offline Reputation: 0 (0%) ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Jul 9, '08 From California Currently Offline Reputation: 5 (100%) ![]() |
yea im only getting 21 mpg and im wondering how can i raise it up? just a fyi your in ca. Our fuel has more ethanal then other states so our MPG will suffer. 15% to be exact. On my 4runner I was getting 15-16 around town, after the switch I was getting 12. Thanks you bureaucratic ***tards. I'm averaging 22-24 on my GT with mods, but I also slide that car through turns and redline at least once a day. -TC This post has been edited by razor7: Aug 12, 2009 - 11:49 AM -------------------- Live your life for yourself. Don't hold back for anything or anyone.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) ![]() |
Your right foot is your best mpg moderator..end of story..
-------------------- BANNED. for life, you moron.
![]() Enthusiast ![]() ![]() Joined Feb 20, '08 From Abingdon, Maryland Currently Offline Reputation: 7 (100%) ![]() |
![]() Enthusiast ![]() Joined May 29, '09 From Burlington, NC Currently Offline Reputation: 0 (0%) ![]() |
I use Lucas myself. Works like a dream.
-------------------- wow . teespring.com/savethemanual
![]() Enthusiast ![]() Joined Dec 5, '07 From Sydney Currently Offline Reputation: 0 (0%) ![]() |
Its amazing how the conditions you're driving in effects your fuel efficiency.
In my previous job, I would be driving 60K's one way to work on a freeway. Although the freeway resembled a car park often. I would comfortably get 600K's out of a tank. The best was 840K's on a tank which included a long 2 hour one way trip up north on a freeway. Now with my new job, I am catching the train and so only driving to and from the train station and around local on weekends. Now I am barely getting 500K's on a tank!! Disgusting. Of course that same tank lasts longer now in absolute time, its just not as efficient. |
Lo-Fi Version | Time is now: February 18th, 2025 - 6:03 AM |
