> turbo pressure sensor
post Dec 10, 2007 - 8:44 PM
pabel89
Joined Sep 28, '07
From new jersey
hi i was wondering is a turbo pressure sensor 100% neccesary on a turbo set up on my 7afe if it is can u let me kno where i can get one..thank you
post Dec 13, 2007 - 1:36 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
use a check valve for your stock one so it doesn't see boost and if your doing piggy back just pick up a 3 bar gm map sensor. get em from a turbo suntbird in the junk yard. or use any 2 bar sensor that you can find.
post Dec 18, 2007 - 7:13 PM
pabel89
Joined Sep 28, '07
From new jersey
where can i get a check valve??
post Dec 18, 2007 - 7:29 PM
look on mr2oc.com or ebay. youll find the sensor there.
dont ghetto rig it with a check valve.
post Dec 18, 2007 - 7:33 PM
pabel89
Joined Sep 28, '07
From new jersey
what happens if i just keep my stock map sensor..with out a piggyback...and can i keep the stock map sensor with a emanage...also is thier a specific model for the map sensor i need?
post Dec 18, 2007 - 8:56 PM
pabel89
Joined Sep 28, '07
From new jersey
someone let me kno if this will work
http://cgi.ebay.com/ebaymotors/GM-2-bar-ma...bayphotohosting
post Dec 19, 2007 - 11:14 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
QUOTE(lagos @ Dec 19, 2007 - 12:29 AM) [snapback]623939[/snapback]
i wouldn't consider it ghetto because a brake booster uses one.
and yes that sensor will work you just have to wire it properly pulling up the wire diagrams from both vehicles and you have to calibrate the sensor to your piggy back system.
This post has been edited by rjbibeau: Dec 19, 2007 - 11:16 PM
post Dec 20, 2007 - 1:27 AM
Hanyo
Joined Aug 16, '03
From Bay area
PLEASE STOP MAKING SO MANY RANDOM THREADS AND USE THE SEARCH FUNCTION:
ok you want to know about the map sensor bar thing.
well there have been a couple people who have turbocharged their ST. First there is Doggy's turbo, then the most recent Stef's.
here is stef thread:
http://www.6gc.net/forums/index.php?showto...p;hl=map+sensor
She used a toyota map sensor. If you look closely at the picture you can read out the part number. Take this part number to your toyota dealership and have them order it for you.
Now to clear out some confusion:
what does the map sensor do?
-It tells your car how much air is going inside the engine.
Why do you need to add a new one?
-because your regular ST sensor can not read boost. It simply can not see it. So it messes up how your engine runs and WILL result in a blown engine if nothing is done about it.
What is this check valve business?
IT IS NOT A FISH TANK VALVE.
- did i make that clear enough? should i say it one more time in caps? A check valve is a one way valve that lets air move in one direction. So in your case and by recomendations by others, the idea is:
YOu install a check valve to make sure your stock senser does not sense boost. therefore you will be ok.
i recomend you just buy the bar sensor that stef used.
any more question please post here!
This post has been edited by Hanyo: Dec 20, 2007 - 1:33 AM
post Dec 20, 2007 - 6:51 AM
pabel89
Joined Sep 28, '07
From new jersey
i bought a 3sgte map sensor from mr2oc.com today thank for ur help.
post Dec 20, 2007 - 3:28 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
only 12 threads started by pabel just in the 1st page!
post Dec 22, 2007 - 7:57 AM
Turbofun
Joined Dec 11, '07
From Norway
Any know how much volt this 2 bar map sensor gives out at 0 boost ? (engine not runnig)
Cant find it any where and I am experimenting with 2 other sensors.
post Dec 23, 2007 - 9:58 AM
Gary
Joined Aug 28, '04
From FLA USA
QUOTE(Turbofun @ Dec 22, 2007 - 7:57 AM) [snapback]624994[/snapback]
Here you go
http://gtfour.supras.org.nz/mapsensor.htm
_Gary
Lo-Fi Version Time is now: December 2nd, 2024 - 11:33 PM
