> Distributor cap, plug wires, and connection plug to the ignitor, Looking for recommendations
post Dec 11, 2007 - 2:29 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
Hey guys,
I am still working on this 2nd gen ST-185 3sgte swap, just need to hook up everything and replace a few parts. Anyways, I've seen a couple of distributor caps and spark plug wire options out there and I am trying to get some recommendations as to what I should use to replace mine's. I need to replace my distributor cap, spark plug wires, and there's this short connector plug wire that goes from the distributor cap to the ignitor that I need. The one I have for some reason does not fit.....I think my last mechanic tried to use an MR2 connector plug wire, one end would fit just fine on the ignitor, but the other end won't fit on the distributor cap that I have.
My question is, will an MR2 ignition kit like this work??
IGNITION KIT ON EBAY
If not, then can I order the OEM parts from an Autozone or Advance autoparts? I know I can get it from Toyota, but they always try to charge way too much for everything and they never have the stuff I need in stock.
If you know of any good options, advice, or any kind of recommendations would be greatly appreciated. Thank you in advance!!
-AT
This post has been edited by CelicaSTX02: Dec 11, 2007 - 2:43 PM
post Dec 11, 2007 - 2:38 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
Here's a picture of the Ignition kit off ebay if you don't want to go to the link:
*The connecting wire that I was talking about that I have is the exact same one as the one shown in the picture of this kit. From my Factory Service manual, it seems that the connecting wire for the All Trac 3sgte is different because both ends have 90 degree angles.....the one I have has only one end with a 90 degree angle and the other one is straight.
post Dec 11, 2007 - 5:24 PM
at least its all OEM parts.
if you know that COIL wire ( the wire goes from the cap to the coil, not the ignitor) wont work, why bother.
go to partznet.com get the the prices from there, and ask your local toyota parts guy to price match.
most of them will, if you ask nicely.
post Dec 12, 2007 - 5:32 PM
CelicaSTX02
Joined Sep 24, '02
From North Carolina
QUOTE(presure2 @ Dec 11, 2007 - 3:24 PM) [snapback]621835[/snapback]
Ah, coil wire is the name of that thing, haha. It's not that it won't work, it just wont fit on the current distributor cap. But if the distributor cap from the MR2 kit will fit on my 3sgte, then the coil wire will work.
post Dec 12, 2007 - 5:44 PM
phattyduck
Joined Dec 5, '05
From LA, CA
QUOTE(CelicaSTX02 @ Dec 12, 2007 - 2:32 PM) [snapback]622178[/snapback]
There are two things to worry about when getting 2nd/3rd gen 3s-gte ignition wires... If it is early or late ('90-'92 have large distributor cap ends, later have small distributor ends) and if it is MR2 vs. Celica.
I had to re-use the coil wire that came with my motor because the 3rd gen ignition wires I got from Champion Toyota were MR2 wires and didn't have two right angle ends on the coil wire.
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
Lo-Fi Version Time is now: November 24th, 2024 - 10:23 PM
