![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) ![]() |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 2, '07 From Great Western Plateau Currently Offline Reputation: 9 (100%) ![]() |
QUOTE(Rusty @ Dec 13, 2007 - 3:02 PM) [snapback]622337[/snapback] Dont think it can gain that much but it sure can kill ur engine. Dont buy it. Its rubbish, this topic has been covered many times. Search ultility is ur best friend. -------------------- ![]() 98% completion --- aaRon |
![]() Enthusiast ![]() ![]() ![]() Joined Mar 15, '06 From Sunnyvale CA Currently Offline Reputation: 0 (0%) ![]() |
-------------------- ![]() - 180k and still running strong "Yes...yes I do have a myspace..." |
![]() Enthusiast ![]() Joined Mar 28, '05 From Dunedin, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
I saw that on trade-me too looks like a load of rubbish
This post has been edited by Sammyr: Dec 13, 2007 - 3:21 PM |
I was never going to buy it, I looked at it and though what the, where did they get the +25hp from?
Your cars red too thats god to be worth some extra hp
yeah, if I add them up I now have 200hp...
![]() Enthusiast ![]() ![]() ![]() Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) ![]() |
stock 4-banger motors with ecu modifications....not gonna gain 25bhp (we don't even have vvtl-i!!!)
now a well modified motor might, just still, don't buy it. This post has been edited by frosty: Dec 14, 2007 - 11:50 AM -------------------- ![]() CLOSED on 25 acres! -shop coming soon.... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) ![]() |
@Rusty:
You have a 3rd gen 3S-GE. Without increasing your revs and getting other more agressive cams (sacrificing low end power) there aint much to get out of the engine. It maxed out be Toyota themselves. -------------------- JDM Powerplant installed, BPU coming very soon!
QUOTE(Rusty) yeah I was never going to buy it
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 Currently Offline Reputation: 1 (100%) ![]() |
but some fire ball graphics on the side,that s a 20hp gain each!!!
-------------------- BANNED. for life, you moron.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 29, '07 From Philly Currently Offline Reputation: 11 (100%) ![]() |
your better off buyin some muffler oil and some steering wheel bearings...that will add some extra HP no doubt
-------------------- ![]() I"M NOT A TOYOTA FAN, IM A FANATIC 1984 accord hatch 5 speed (T-Belt)-Junkyard 1991 VDUB jetta wolfsburg Ed. 5 speed (clutch)-junkyard 1988 Dodge Aries K (sold) 1969 Chevy El camino - Traded for celica 1991 Dodge Daytona-Traded for Celica 1988 Chevy Camaro-Work in Progress 1989 Ford Mustang LX 5.0 - For Sale 1995 Toyota Celica-Work in Progress |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) ![]() |
dont forget to top off your halogen fluid
Enthusiast ![]() Joined Oct 17, '04 From St Louis, MO Currently Offline Reputation: 0 (0%) ![]() |
Some little things that do make a difference.
1- timing advance (if you run high octane gas) ... good for 3-4hp. If you cant alter your timing by rotating the distributor, you can do the intake temp sensor resistor mod trick. 2- Insulated intake manifold gaskets (you can get these on ebay). Make the car less prone to heat soaking after long traffic stops. Doesn't always ADD hp but sometimes it prevents it from being lost off to heat soak. If they do add power, they do it by making the intake manifold slightly longer which changes it's resonant frequency and usually adds some 2-3hp and some 5ft-lbs of torque. Sometimes you can find a different model (corolla, camry..etc) with a similar engine with a plastic intake manifold... you can swap this manifold on for the same effect. 3- Throttle body coolant bypass mod (simple to do and dyno proven for a 1-2 hp). 4- 'Voltage Stabilizers'. I know these sound like BS. But I built one on my own and installed it on my benz and it does work. My throttle response is better and my 4000-5000 rpm pickup is better with it. I talked to a couple of people about this, and our best guess is that it improves your ignition effeciency and response time. So from an ignition event point of view it's the same as having a slight timing advance. now those are 4 mods that add 3-4 hp. But don't expect a 16hp gain doing all of these together ![]() after you do all these mods , reset your ECU. -------------------- 2005 MB C200 Kompressor- K&N, Apexi WS2 Catback, DIY Voltage stabilizer, Intrax Springs, H&R RR swaybar, VDO Boost Gauge @ 6psi, Greddy L7 plugs, +0 Rear tires
To Do: E-manage Ultimate tuned up to 12psi |
![]() Enthusiast ![]() Joined Oct 27, '07 From Hastings, NZ Currently Offline Reputation: 0 (0%) ![]() |
Haha i've got a IAT resistor in! Car does actually feel a bit more responsive. Cost me only a couple of dollars though since I know what code resistor you use (from checking out one my mate bought few years ago) and bought one from an electronics shop.
-------------------- - TRD3SG -
Lo-Fi Version | Time is now: April 29th, 2025 - 7:56 AM |
