> W2A Intercooler
post Dec 14, 2007 - 10:54 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
Hi guyz, i have a top mount water to air ST185RC intercooler on my 3sgte. My question is how much boost i can flow through it before i have to change for a Frount mount setup.
I wanna install a ct20b and AEM EMS and crank boost up to 15psi. Is my intercooler enough good? And also, what a not enough efficient intercooling system can cause to a car?
post Dec 14, 2007 - 11:03 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(domyz @ Dec 14, 2007 - 10:54 PM) [snapback]622892[/snapback]
It could make it detonate and ruin your engine. I doubt you will have any issues with the WTA intercooler at 15 psi. But, An engine is very costly, a devils own water injection kit would be a good idea if you plan to crank the boost past stock. Boost is very addicting! Trust me! Get the Water injection also!
-toyotacrazy
post Dec 15, 2007 - 12:16 AM
Gary
Joined Aug 28, '04
From FLA USA
You should be fine at 15 psi on CT20B and ST185RC intercooler.
You can mod the pump to run constantly if you want.
You can also upgrade the heat exchanger to a larger unit.
_Gary
post Dec 15, 2007 - 4:51 AM
Kadett
Joined Mar 17, '05
From The Netherlands
Also, I would lag the underside of the intercooler with Heat Reflective material. Dont have any numbers, but my intercooler went from too-hot-to-touch to a-bit-warm.
Here's the topic I made for it.
http://www.6gc.net/forums/index.php?showtopic=53938&hl=
post Dec 16, 2007 - 12:38 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
Here is my celica
My W2A is always between cold and warm, my pump is set to run constantly. So I cannot go above 15 psi?
This post has been edited by domyz: Dec 16, 2007 - 12:39 PM
post Dec 16, 2007 - 1:04 PM
Kadett
Joined Mar 17, '05
You can go above 15 psi. The only problem is the more you go above it the hotter the are becomes. So it wont be effective (less air molecules) and dangerous (detonation). Installing Water injection and lagging your intercooler greatly reduces air intake temps.
IE A 1.3 bar CT20 could produce less HP then a 1.1-1.2 bar with Water injection.
post Dec 16, 2007 - 3:55 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
i don't want this water injection, i think this is like NOS and this is not good. I want to run my car like stock. Change oil and liquids, i dont wanna shoot things in my engine...
This post has been edited by domyz: Dec 16, 2007 - 3:58 PM
post Dec 16, 2007 - 4:56 PM
jcbass7
Joined Apr 20, '06
From Florida
QUOTE(domyz @ Dec 16, 2007 - 3:55 PM) [snapback]623240[/snapback]
when you get a chance read some more up on water/methanol injection, what it does actually protects your engine a lot more than hurting it like NOS can
post Dec 16, 2007 - 6:09 PM
95st-celica
Joined Mar 29, '07
From Philly
1988 Dodge Aries K (sold)
post Dec 16, 2007 - 7:41 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
Water injection when installed properly is the opposite of nos. It wont hurt your engine. NOS kinda adds more air, as WI adds more fuel (sorta)and lowers internal combustion temps.
post Dec 17, 2007 - 12:11 AM
Gary
Joined Aug 28, '04
From FLA USA
The reason not to go above 15 psi on your current setup is because of the turbo, not the IC.
And yep, do your homework about WI, and not just on this site.
I'm one of people that don't want the WI on my car and there are reasons for that.
(I'm not saying that the WI is not an effective way to lower the intake temp and prevent knock)
This post has been edited by Gary: Dec 17, 2007 - 12:12 AM
_Gary
post Dec 22, 2007 - 7:50 PM
domyz
Joined Jul 29, '07
From Quebec, Canada
so why you dont want it ???
For me, its adding something more under the hood, something that can break anytime and that needs refill every week.
This post has been edited by domyz: Dec 22, 2007 - 7:52 PM
post Dec 23, 2007 - 5:32 AM
Kadett
Joined Mar 17, '05
Looking at your engine bay I i want to say one more thing: Get a BOV before turning up the boost.
post Dec 23, 2007 - 5:46 AM
Insanity-74
Joined Jan 9, '05
From Under the car
QUOTE(Kadett @ Dec 23, 2007 - 10:32 AM) [snapback]625183[/snapback]
I wouldnt...st185 engines run much better without them
post Dec 23, 2007 - 5:16 PM
toyotacrazy
Joined Mar 4, '06
From Ohio
QUOTE(domyz @ Dec 22, 2007 - 7:50 PM) [snapback]625114[/snapback]
I only refill mine about every 2-3 weeks. and its only a 2 liter bottle.
Lo-Fi Version Time is now: November 29th, 2024 - 11:48 AM
