> FS: Black Apexi Turbo Timer Pen Size
post Dec 17, 2007 - 3:15 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
used about a week. works fine, comes with the HKS harness so everything is plug and play...asking $100 shipped.
post Dec 17, 2007 - 6:16 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
QUOTE(LewFX @ Dec 17, 2007 - 3:15 PM) [snapback]623637[/snapback]
is this their auto turbo timer?? (counts up based on time in boost) if so i am very interested...
Breaking Axles...
post Dec 17, 2007 - 6:40 PM
How is it plug and play for a non turbo car?
post Dec 18, 2007 - 9:35 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
it doesn't hook up to the turbo... it hooks up to the ignition... there's not too many benefits of putting it on a non-turbo car though....
Breaking Axles...
post Dec 19, 2007 - 9:02 AM
I know how it hooks up. I have one, theres no plug & play harness for our cars. You have to splice everything.
post Dec 19, 2007 - 10:12 AM
LewFX
Joined Jan 28, '05
you use this, the turbo timer plugs into the hks harness which plugs into the stock ingition harness so no splicing necessary.
post Dec 19, 2007 - 3:57 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
lew is this the auto turbo timer for apexi?? or is this just a manual version?
Breaking Axles...
post Dec 19, 2007 - 4:08 PM
Does HKS make this specifically for the Apex timer? I am confused by this cross-branding. I would have liked to known this existed 2 years ago.
post Dec 24, 2007 - 4:50 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
is the harness car specific? cuz I might pick this up for the Supra.
-Alex {](O_o)[}
post Dec 24, 2007 - 9:02 PM
QUOTE(Supersprynt @ Dec 19, 2007 - 9:02 AM) [snapback]624114[/snapback]
yes there is. just lookup what harness they recommend for the st205 and use that. plugs right in.
post Dec 24, 2007 - 10:19 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
lew can you tell me if this is an auto turbo timer... i'm still trying to buy this...
Breaking Axles...
post Dec 24, 2007 - 11:07 PM
NgoFcukinWay
Joined Nov 7, '06
From Houston, Tx
how much for just the turbo timer?
-Alex {](O_o)[}
post Dec 24, 2007 - 11:35 PM
LewFX
Joined Jan 28, '05
QUOTE(pittfirefighter @ Dec 24, 2007 - 8:19 PM) [snapback]625514[/snapback]
its a turbo timer for n/a or turbo...im sure it can be made for auto or manual
QUOTE(NgoFcukinWay @ Dec 24, 2007 - 9:07 PM) [snapback]625520[/snapback]
id rather sell both since i wont need a harness
post Dec 25, 2007 - 12:36 AM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
[quote name='LewFX' date='Dec 24, 2007 - 11:35 PM' post='625527']
[quote name='pittfirefighter' post='625514' date='Dec 24, 2007 - 8:19 PM']
[/quote]
no i mean is it an automatic turbo timer.... which means for instance.... it will start at a 30 second duration when you start the car.... as you boost... the timer counts up... as you are out of boost the timer counts down.... therefore determines how long the timer will leave the car running automatically depending on time in boost... this is called a full auto turbo timer... if you have to program the duration every time you use it or if its just saved on the timer.... then its a manual controller....
Breaking Axles...
post Dec 25, 2007 - 4:09 AM
6strngs
Joined May 12, '06
From Wilmington, NC
which HKS harness did you use? I checked their website and didn't see a listing for ST202/204 or ST205. Does the one for ST185/SW20 (same part number for both) work? also do you know which timers this would work for? obviously HKS and Apexi, how about Greddy or others?
Sorry for the kind off-topic questions. I'm interested in buying just the harness if NgoFcukinWay or somebody else wants to buy just the timer.
post Dec 25, 2007 - 11:45 AM
LewFX
Joined Jan 28, '05
yeah its automatic, i had it set at 30 seconds..it was neat, i turn off car, take key out, car still runs til 30 secs and turns off. the harness number is TT04..was made for a supra but works for our car...i used the search feature on 6gc and came up with the result.
post Dec 25, 2007 - 1:31 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
it should just be a bypass harness which means it will work for every turbo timer.... however the greddy will need more splicing... the harness has bare wires at one end and thats what the turbo timer connects to... this way there is no cutting of the ignition wires and its easy to return to stock....
any turbo timer that has extra features such as the greddy will need extra splicing... features include turn off when parking brake it pulled or foot brake is pressed... as well as an RPM gauge or speedo hookup
Breaking Axles...
post Dec 25, 2007 - 1:36 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
lew pic of the turbo timer?
Breaking Axles...
post Dec 25, 2007 - 2:13 PM
6strngs
Joined May 12, '06
From Wilmington, NC
QUOTE(pittfirefighter @ Dec 25, 2007 - 10:31 AM) [snapback]625627[/snapback]
sounds good to me. I know how to splice wires, I just would prefer the option to convert back to stock easily should I need to at some point.
post Dec 25, 2007 - 10:40 PM
LewFX
Joined Jan 28, '05
Lo-Fi Version Time is now: November 22nd, 2024 - 6:28 AM
