> Help, can't get hatch to open...
post Dec 17, 2007 - 10:46 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
mad.gif So after installing some new strut mounts to fix the clunking, since I neglected to do when lowering my car, I closed my hatch for the night. The next day I came outside to pop my hatch open to put stuff in there, my hatch wont open. I first inserted my key into the key hole and turned it to the right but the hatch wont pop up like usual. The key hole inert is stuck in the horizontal position (normally vertical) and wont budge. So I go inside and try to pop it from the inside and the latch thing near the driver seat has zero tension what so ever. All I hear is click click click when ever I lift on it. So now I'm left without a working hatch. I know the key hole isnt frozen, maybe the locking mechanism is broken, but how the heck am I going to open my hatch? Its just annoying me. I want to change out a bulb in my taillights since one is out, but can't get ot it. Someone please help?
94 Celica gt white (sold)
post Dec 18, 2007 - 12:38 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Ick, sounds like you might have to cut into the trunk plastics to reach the latch mechanism. If the key release has jammed, it could well prevent the remote release from catching.
It's US$150 from the dealer, so I'd suggest checking your local junkyards if it comes to cutting -- or try cutting with a knife at an angle, rather than a saw and you might be able to glue the piece back in.
post Dec 18, 2007 - 10:37 AM
Celicam8
Joined Nov 17, '07
it looks like your hatch is locked.. we have a lock so you cant open the hatch... turn it to the right, press in and it should go...
post Dec 18, 2007 - 8:34 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
I've already tried that. It just sits there turned to the right. So I just ghetto rigged the thing. I took the cables off and using the lock assembly connected the 2 cables together so I can open the hatch from the driver seat just not from outside the car.
post Dec 18, 2007 - 9:47 PM
Celicam8
Joined Nov 17, '07
post Dec 18, 2007 - 10:01 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Not really ghetto rig, thinking of what I'v done I pulled a Mcguyver. lol
post Dec 19, 2007 - 1:09 PM
Celicam8
Joined Nov 17, '07
tongue.gif haha!
post Dec 20, 2007 - 1:39 PM
tomazws
Joined Oct 30, '04
From So Cal
I donno but my trunk is getting harder and harder to unlock as years go by.. I wonder anything needs to be changed to prevent something you're facing...
post Dec 20, 2007 - 4:52 PM
Penkka
Joined Dec 20, '07
From Valkeakoski, Finland
Last week as I was popping Celicas trunk, the short wire in the back cut and now I cant get it open laugh.gif
Its almost 14 years old car so these are not a surprise for me..
320hp @ 6300rpm and 420Nm @ 3250rpm. yay!
My ST205 WRC buildthread
post Dec 20, 2007 - 6:23 PM
azian_advanced
Joined Apr 18, '05
From Calgary
QUOTE(tomazws @ Dec 20, 2007 - 12:39 PM) [snapback]624510[/snapback]
lubricating the release handle and the latch assembly itself should help, it's less tension on the cable. other than that, IPB Image.
post Dec 20, 2007 - 7:07 PM
Celicam8
Joined Nov 17, '07
hm, if you have a alarm that opens trunks you can think about getting the trunk popper... will help you a lot
post Dec 20, 2007 - 11:34 PM
CelicaST_CALI
Joined Feb 28, '07
say hello to my lil friend Mr.crowbar..
BANNED. for life, you moron.
Lo-Fi Version Time is now: February 18th, 2025 - 1:54 PM
