![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) ![]() |
i jus check out the fluid reservoir and its near empty and instead of pouring some new fluid in, i was thinking of draining it out and pour some new fluid in...andbody done it b4?
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) ![]() |
This would be interesting to know b/c toyota said my p/s fluid is dirty and wanted over $100 to do a flush on it
bump
![]() Enthusiast ![]() ![]() ![]() Joined Jun 16, '06 From Bowling Green KY Currently Offline Reputation: 7 (100%) ![]() |
i'm pretty sure there is a drain bolt on the back of the power steering reservoir. and as you loosen it, the fluid will come out. once its loose just turn your wheels all the way to the right, and all the way to the left.
that should do the trick! i've never drained my system, but when i was trying to move the p/s reservoir i undid this 'drain' bolt and fluid started coming out. so i'm guessing that is it ![]() -------------------- **If you play My Brute, joing the 6gc.net clan!**
--A section of a kid's actual test that had been scanned-- ![]() |
unhook the return line, put it in a bucket, pull the efi/htr fuse and crank the engine a couple times. put in new fluid, empty the bucket, crank a few times. do this till it runs clear. now put the return line back on and then fill the reservoir. start the car and turn the wheels back and forth, then top the fluid. take it for a drive with lots of turns, top the fluid if needed.
Lo-Fi Version | Time is now: February 22nd, 2025 - 4:42 AM |
