2 Pages V  < 1 2
> beams head on 3s-gtehe vvt-i
post Dec 24, 2007 - 8:21 PM
Outsider
From Kelowna, BC
http://www.tc-imports.net/available-98beams-turbo-celica.htm
http://cgi.ebay.com/ebaymotors/TOYOTA-ALTE...sspagenameZWDVW
(will also fit the Red Top)
http://www.mr2.com/forums/beams/Toyota-MR2...ms-turbo-3.html
(If you are a member then here are some Turbo BEAMS pics)
1994 GT-S (BEAMS) swap complete
post Dec 25, 2007 - 2:50 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
wow so many of you guys are taking stabs in the dark... turboing a beams with a piggy back will be the easiest. head swap on a 3sgte with a beams will be the hardest and for not that much gain... (3sgte pistons are weak, rods are strong)... really what this boils down to is someone's pipe dream
post Dec 26, 2007 - 10:23 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Beams has a really cool looking RED valve cover. That alone makes up for its shortcomings.
post Dec 27, 2007 - 2:20 AM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(Kwanza26 @ Dec 26, 2007 - 10:23 PM) [snapback]625891[/snapback]
laugh.gif +1
post Dec 27, 2007 - 11:44 AM
frosty
Joined Sep 1, '04
From Alabama
^definitly true tongue.gif ^
QUOTE(playr158 @ Dec 20, 2007 - 4:32 PM) [snapback]624479[/snapback]
you can boost a high CR motor (New celicas for that matter as well)
high compression helps with off boost driveability, as well as you make the "same" amount of power as a lower CR motor with a lower boost level on a high CR motor
Its all in the ability to tune your timing and fuel.
In my build i'll actually be raising the CR of the 3sgte to ~9.5:1 almost.
Don't forget a water/meth or alchohol injection for added cooling protection...
QUOTE(azian_advanced @ Dec 20, 2007 - 11:05 PM) [snapback]624592[/snapback]
well, i remember reading about it at some point a couple of years ago..
ok i found two. but the one i had in mind is not one of these two, i can't find it.
anyway.....
1.
HKS SS-III Celica Turbo
Uh, not seeing the vvt-i control on the exposed cam gears so I would say this either is not the beams motor or the vvti was removed.
IMO, turbo the beams, run a high octane, and get some sort of water/meth injection. Going through the hassel to swap heads wouldn't be worth it.
Now if you were to place the head on the 5s block and make it a stroker motor then that would be fun.
This post has been edited by frosty: Dec 27, 2007 - 11:45 AM
CLOSED on 25 acres!
-shop coming soon....
post Dec 27, 2007 - 12:20 PM
QUOTE(frosty @ Dec 27, 2007 - 11:44 AM) [snapback]626015[/snapback]
water/meth is a "band-aid" solution....how many REAL racecars do you see running around on it? (road course that is) answer is zero. A properly built and tuned motor does not need water/meth. W/M is used in order to run a higher boost level/change timing a bit for short periods of time and is not something you depend on.
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 26th, 2024 - 5:13 PM
