Exhaust |
Exhaust |
Dec 20, 2007 - 4:47 PM |
Enthusiast Joined Dec 20, '07 From Valkeakoski, Finland Currently Offline Reputation: 0 (0%) |
I´m after some aftermarket performance exhaustsystem to my 3S-GE. I´ve been looking for a while, but the only reaseonable I´ve found is Apexi N1. I also ran into HKS exhausts, but they were too expensive. Any suggestions?
Thanks allready mates. -------------------- |
Dec 20, 2007 - 5:29 PM |
Enthusiast Joined Aug 30, '07 From Oak, Ridge NJ Currently Offline Reputation: 0 (0%) |
I've been looking for an exhaust system for my car so that when i do my 3sgte swap, the turbo will breathe better. Where did you find the apexi n1 turbo for the 6gc? or the hks? THANKS!
Dec 22, 2007 - 1:04 PM |
My Celica doesn´t have a turbo, its N/A 2.0.
Dec 22, 2007 - 1:12 PM |
Enthusiast Joined Mar 17, '05 From The Netherlands Currently Offline Reputation: 0 (0%) |
The only one's I know off are:
Apexi HKS Kakimoto C-one -------------------- JDM Powerplant installed, BPU coming very soon!
Dec 22, 2007 - 1:33 PM |
Enthusiast Joined Apr 14, '06 From Vancouver, WA Currently Offline Reputation: 0 (0%) |
Or you could just go custom, it might cost less since the exhausts that fit our cars would have to be shipped. Find an exhaust shop and get a quote.
Dec 23, 2007 - 12:12 PM |
QUOTE(GTS13 @ Dec 22, 2007 - 1:33 PM) [snapback]625036[/snapback] Or you could just go custom, it might cost less since the exhausts that fit our cars would have to be shipped. Find an exhaust shop and get a quote. Yea I´ve been thinking about that too, but wich ones better, with a 2.25" bore or 2.5"? This post has been edited by Penkka: Dec 23, 2007 - 12:13 PM -------------------- |
Dec 23, 2007 - 12:31 PM |
60mm is the Size that all Japanese companies used. I would use the same.
Jan 4, 2008 - 5:58 PM |
Enthusiast Joined Nov 1, '07 From Santa Barbara, CA Currently Offline Reputation: 2 (100%) |
60 mm equates to 2.362in which is inbetween 2.25 and 2.5in. So, which is better?
Jan 6, 2008 - 8:05 AM |
If I´ve understood correctly, 2.5" looses the highpowers, but is more torguebased. the 2.25" instead gives you more power to higher revs, correct?
Jan 6, 2008 - 2:15 PM |
"If I´ve understood correctly, 2.5" looses the highpowers, but is more torguebased. the 2.25" instead gives you more power to higher revs, correct?"
can anyone answer this? Also do one of these sound ricey? I'm ready to go to the shop but I can't decide what size. |
Jan 18, 2008 - 2:40 AM |
Enthusiast Joined Aug 26, '07 From Finland Currently Offline Reputation: 0 (0%) |
QUOTE(Penkka @ Dec 20, 2007 - 4:47 PM) [snapback]624560[/snapback] I´m after some aftermarket performance exhaustsystem to my 3S-GE. I´ve been looking for a while, but the only reaseonable I´ve found is Apexi N1. I also ran into HKS exhausts, but they were too expensive. Any suggestions? Thanks allready mates. Hei Penkka! I have used hks super drager coming from japan. It's 60mm and it will be for sale... I can also get other exhaust from japan if you want. QUOTE "If I´ve understood correctly, 2.5" looses the highpowers, but is more torguebased. the 2.25" instead gives you more power to higher revs, correct?" It's exactly opposite you wrote... |
Lo-Fi Version | Time is now: November 29th, 2024 - 8:54 AM |
