I think i have a vac leak, what do u think? |
Dec 21, 2007 - 7:19 PM |
Enthusiast Joined Jul 16, '04 From Los Angeles Currently Offline Reputation: 8 (100%) |
hks evc boost controller wont boost any higher then 14 to 15 psi
vac reads -58 to 62 bar which = about 17 to 17.5 ish inhg idle looks to be around 800k and it is steady with out any irregularities at idle when my ear is by timing belt side by i hear by the fuel rail area near the bottom of the intake manifold/plemuth either the fuel running through the lines or a vac leak... not sure thanks for input.... i plan on doing a vac leak test soon but figured id as for some input from you guys |
Dec 21, 2007 - 8:49 PM |
Enthusiast Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
Could be those vac lines for the power steering idle up.. they run behind the intake manifold and sometimes can pop off with boost.
-------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Lo-Fi Version | Time is now: November 28th, 2024 - 3:07 PM |
