For those that used the E153 tranny (mount question) |
Dec 22, 2007 - 10:51 AM |
Enthusiast Joined Mar 31, '04 From Summerville, SC Currently Offline Reputation: 5 (100%) |
Which ST205 mounts and brackets did you need specifically? I know for sure the rear bracket, but is the ST205 mount needed as well, and what about the front and sides?
-Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Dec 22, 2007 - 10:53 AM |
QUOTE(Dr_Tweak @ Dec 22, 2007 - 10:51 AM) [snapback]625009[/snapback] Which ST205 mounts and brackets did you need specifically? I know for sure the rear bracket, but is the ST205 mount needed as well, and what about the front and sides? -Doc not positive on the drivers side mount and front ( GT parts i think) the rear is 205 bracket and mount. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Dec 22, 2007 - 11:11 AM |
Enthusiast Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) |
yeah thats what i need now, and u know how the steering column thing sits right above and by the trans mount place, so did the mount fit under it nice?
Dec 22, 2007 - 1:19 PM |
Enthusiast Joined Jun 19, '06 From Portland, OR Currently Offline Reputation: 1 (100%) |
All GT mounts... The rear mount is E153 bracket w/ st205 rubber
-------------------- 87 4runner DLX 22re, 5spd, 4.30gr, 4" lift, 30" tires, HID w/ Projectors, 6spkr + sub, custom exhaust, 94 celica leather seats, SR5 gauge cluster and clinometer. Future engine swap... possibly a 2jzge.
Dec 22, 2007 - 2:04 PM |
QUOTE(Dr_Tweak @ Dec 22, 2007 - 10:51 AM) [snapback]625009[/snapback] Which ST205 mounts and brackets did you need specifically? I know for sure the rear bracket, but is the ST205 mount needed as well, and what about the front and sides? -Doc btw... are you still cutting and grinding that timing belt mount? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Dec 22, 2007 - 2:14 PM |
problem is finding a mount like that
Dec 24, 2007 - 11:00 AM |
QUOTE(lagos @ Dec 22, 2007 - 7:04 PM) [snapback]625051[/snapback] QUOTE(Dr_Tweak @ Dec 22, 2007 - 10:51 AM) [snapback]625009[/snapback] Which ST205 mounts and brackets did you need specifically? I know for sure the rear bracket, but is the ST205 mount needed as well, and what about the front and sides? -Doc btw... are you still cutting and grinding that timing belt mount? Yeah, why? Okay guys, I'm going to buy a bunch of these rear mounts and brackets so that they are on hand. If anyone needs one let me know. -Doc -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Dec 24, 2007 - 12:07 PM |
I am in line as u alreayd know
Dec 24, 2007 - 12:50 PM |
QUOTE Yeah, why? 5safe bracket, bolts to the 3s. then all 3 motor mount bolts line up. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Dec 26, 2007 - 9:01 PM |
believe it or not, I somehow got my st185 bracket and mount to line up and work, don't ask me how, but i can get pics if u want
Dec 27, 2007 - 12:50 PM |
QUOTE(lagos @ Dec 24, 2007 - 5:50 PM) [snapback]625433[/snapback] QUOTE Yeah, why? 5safe bracket, bolts to the 3s. then all 3 motor mount bolts line up. Yes, that's correct. A lot of the swaps we do are in STs though so there's no bracket to pull, and grinding the mount takes about 2 minutes so it's no big deal. This post has been edited by Dr_Tweak: Dec 27, 2007 - 12:51 PM -------------------- -Dr Tweak, 6GC's resident engine swap wiring expert extraordinaire Click here to see my swaps drtweak@phoenixtuning.com |
Jan 20, 2008 - 12:24 AM |
umm i know its kinda old, but just to make sure, the e153 trans must use the st205 tranny side mount right, or can the gt be used for the side, cause from what I am getting it can't
Jan 21, 2008 - 9:06 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
I used an st205 rear tranny mount and the st185 bracket that came with the clip.
then i just used USDM GT engine mount and bracket combo for left, right and front engine mounts. |
Jan 23, 2008 - 3:13 PM |
k thanks cause other people were saying i need only the st205 tranny mount
Lo-Fi Version | Time is now: December 4th, 2024 - 4:28 AM |
