> 3sgte boost
post Aug 18, 2003 - 10:51 PM
DoodieHead
Joined Mar 31, '03
From Bowling Green, KY
what is the st185 3sgte stock boost? and what do you think you could raise it up to safely
post May 26, 2004 - 6:27 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
I had to bring this topic back cause i have been doning some thinking.
My boost at first was about 10 psi..... but i have dont some mods such as big fmic, water sprayer, 3" exhaust and my boost went up to 13psi somehow and i have not even put on a boost controller yet to turn it up????????
i was thinking of turning the boost up a little bit to about 15 ,,,and i guess i would have to make something to avoid the fuel cut.
have any of you swappers turned up the boost on you 3sgte to like 15 psi or more staying with the stock internals????
just wondering,
DG
post May 26, 2004 - 6:46 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (DG_Performance @ May 26, 2004 - 4:27 PM)
just wondering,
DG
Well Ive done some reading on this, and the first thing you want is a fuel cut defenser so you can adjust the level of boost in which fuel cut is reached, without this you could have something go wrong and over boost messing up alot of things.
As for 15psi, that is like the magic number, its said that boosting 15psi is no more dangerous then boosting at stock levels. But once you start passing that is where you may run into problems. But people on mr2oc.com have been known to run15-20+ on stock engines with no problems, its just not recommended.
This post has been edited by Uppitycracker: May 26, 2004 - 6:47 PM
post May 26, 2004 - 7:13 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
Yeah go look on alltrac.net Everyone there turns up the boost because its pretty much proven to be just as easy on your engine as stock boost.
EDIT: I mean only to 15psi also. Thats the magic number...so says all the guru's at alltrac.net
This post has been edited by Doge: May 28, 2004 - 3:20 AM
post May 26, 2004 - 8:09 PM
i think it depends on what turbo u are using too.. i think the stock ct26 will start to crap out arter 15psi.
post May 26, 2004 - 8:47 PM
Justin
Joined Dec 13, '03
From Alabama
the ct-26 will start to crap out over 15. I know somebody with a supra that was waiting for his single turbo upgrade to come in. He was boosting like 20 to even 25 psi sometimes. After I think a month or so they both blew up, literally. He smoked thick blue plumes about 15ft high and 30-40ft long
post May 26, 2004 - 9:59 PM
Stock boost is supposed to be 8-9lbs. The CT-26 maxes out at about 15lbs. Supra CT-26s are different than Celica/MR2s.
I dont kno why you would think more boost is just as safe as stock boost, that sounds wrong. The 3sgte has been able to handle 25lbs, but not day to day.
Boost cut is 12.7lbs so you should already be reaching cut.
Biggest reason for increased boost is your bigger exhaust. The water sprayer prevents detonation by cooling the cylinders. I really wouldnt have the CT-26 on constant 15lbs, its going to wear it out quicker.
This post has been edited by Supersprynt: May 26, 2004 - 10:01 PM
post May 26, 2004 - 10:47 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
yeah, i would think that the turbo would wear out faster at higher boost. well the reason for my qusetion is i know i hit fuel cut and wow did that suck! i just want the turbo to be able to do whatever it wants up to 15 psi and not hit fuel cut. so ...... is there an easy way to raise the fuel cut to 15 psi and that way if i get 14 psi on the stock setup without a boost controller raising the boost that would work for me. (i don't want to totally eliminate the fuel cut)
thanks,
dg
post May 26, 2004 - 10:58 PM
Do a search on alltrac.net. There is a way to do it cheaply with zenier diodes.
Or you can just buy a boost cut controller. More expensive tho.
Both are adjustable, the BCC will be easier tho.
post May 26, 2004 - 11:38 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (Supersprynt @ May 26, 2004 - 7:59 PM)
Because thats what all the mr-2 people say, and Im not saying like joe blow or just anyone, Bill Strong himself says this and I take his word as gospel when it comes to cars since hes like the smartest car guy Ive ever seen.
Its all about the limitations of the Turbo Charger, more psi has nothing to do with the life of the turbo, aslong as you keep it within the abilities of the turbo.
This post has been edited by Uppitycracker: May 26, 2004 - 11:40 PM
post May 27, 2004 - 12:37 PM
Sirius
Joined Apr 15, '04
From United Kingdom
AT 15psi the main thing I would be worried about on a stock engine is the head gasket and bolts.
With the FMIC you'll be keeping the charge temps nice and low.
The water sprayer? is that spraying ON to the intercooler? Or is it water injection?
I run both on my car the Water injection is extremely effective at pulling charge temps down, The sprayer just helps things along smile.gif
If you want to be able to run all day every day - I would go for something around 13psi that shouldn't cause you any problems smile.gif
post May 27, 2004 - 12:44 PM
15 shouldnt cause any problems either with the engine, its the turbo. Im confused by this "more PSI doesnt wear down the turbo faster." The turbo is working harder to produce a higher pressure, logic states that harder work will decrease longevity.
post May 28, 2004 - 12:36 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
I am only running the water sprayer for now, not injection yet. it really cools down my front mount a lot!!!!
i was hoping to hear of other peoples stories and results of running higher boost first hand. i just was wondering who turned the boost up on their stock car and to how much?
thanks,
dg
post May 28, 2004 - 2:47 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
QUOTE (Supersprynt @ May 27, 2004 - 10:44 AM)
Because its still well within the limitations of the turbo (ct26), so holding 15psi is no more degrading then 8psi, but people then run 22psi obviously are pushing it and will wear down the turbo sooner.
This post has been edited by Uppitycracker: May 28, 2004 - 2:58 AM
post Jun 2, 2004 - 7:03 PM
politicsareevil
Joined May 1, '03
From Houston , Texas
I know this will sound noobish, but I am about to turbo my 7a-fe so what is this fuel cut thing you are talking about?? Just wondering.
Lo-Fi Version Time is now: April 24th, 2025 - 6:10 AM
