> is 10lbs reliable?, garrett T3bb
post Dec 24, 2007 - 10:24 AM
Kerr1
Joined Dec 24, '06
From jonesville
ok im wrkin on a turbo kit 4 my freshly rebuilt 5sfe. heres a list of everything done to the motor:
bored .040 w/ topline pistons
arp head studs
soon to have arp rod bolts
cometic metal head gasket
everythin else if brand new but still stock..
new motor now has around 1000 miles on it
ive always heard a motor w/ arp head studs and rod bolts combined w/ a good head gasket can handle a lil more power and i was wondering since burien kits run a reliable 7lbs do u think w/ the right setup and proper tuning a 5sfe could be daily driven on 10lbs....
ne advice as appreciated thanx.
post Dec 24, 2007 - 10:55 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE(Kerr1 @ Dec 24, 2007 - 10:24 AM) [snapback]625419[/snapback]
do u think w/ the right setup and proper tuning [u]a 5sfe could be daily driven on 10lbs....
as long as you keep that always in mind you can run 10 lbs pretty save and probably even a little more.
post Dec 24, 2007 - 12:45 PM
arp head studs
no 10psi will not be safe at all. not even 7 psi.
why? because you didnt list how you are planning to tune it.
post Dec 24, 2007 - 2:05 PM
arp head studs
how are you getting ARP rod bolts for the 5s?
ARP dont make an application for the 5s rod bolts, and last time i saw someone inquire about them, ARP would only make them in runs of 50 sets.
if you do have a source for them, let me know.
post Dec 24, 2007 - 6:30 PM
blckcelica95
Joined Nov 20, '03
From Derry, NH
let me know too . i cold use a set on my car
Driving a 5SFTE and LOVIN IT!!!!!!
http://www.myspace.com/17psicelica <-- celica engine build pics
post Dec 24, 2007 - 11:03 PM
Kerr1
Joined Dec 24, '06
From jonesville
im gettin an SAFC II and taking it to Top Dead Center performance to get it dyno tuned
i have 3sgte head studs so i was assuming the rod bolts would wrk as well. if im wrong let me know. if 7lbs of boost wasnt reliable y would burien make their kit to run 7?
also does ne1 know what kinda numbers i would b puttin down? and im kinda worried a t3 is a lil big i dont want a lot of lag.
This post has been edited by Kerr1: Dec 24, 2007 - 11:05 PM
post Dec 24, 2007 - 11:22 PM
frosty
Joined Sep 1, '04
From Alabama
You need to remember that 7psi on the burien kits turbo isn't the same 7psi as the t3.
You need to give us a little more info on your set up. Do you at least have an intercooler? Boost controler? More info is helpfull for us so we can help you.
CLOSED on 25 acres!
-shop coming soon....
post Dec 25, 2007 - 7:16 AM
QUOTE(Kerr1 @ Dec 24, 2007 - 11:03 PM) [snapback]625519[/snapback]
3s rod bolts dont fit the 5s rods.
post Dec 25, 2007 - 12:33 PM
Kerr1
Joined Dec 24, '06
From jonesville
garrett t3bb turbo
fmic
2 peice icp
safc II
internal wastegate
prof bov
450cc injectors
3" under axle exhaust
custom 4 bolt down pipe
oil pressure gauge
boost gauge
i want to get a boost controller eventually but not netime soon prolly
umm im not sure wat else i need to tell u everything else is just ur "average" turbo kit. (i guess)
post Dec 25, 2007 - 2:03 PM
1bwilson
Joined Aug 30, '02
From Maryland
Buriens definition of reliable is a very loose term imo. Do you know anyone using their kit still?
Member of Team 5sfTe
post Dec 25, 2007 - 9:45 PM
Kerr1
Joined Dec 24, '06
From jonesville
no i was just reading abt. it.....im new to the whole turbo deal and want my motor to last at least 30-40,000 miles by then ill b able to buy a new one... i was just thinkin that since a stock motor is "supposed" to handle 7lbs...i asumed w/ the few minor parts that r supposed to make ur motor a lot stronger i could run 10lbs fairly reliable......the kit is not going on my car until i have all the parts to tune it the right way...
post Dec 29, 2007 - 2:11 PM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(1bwilson @ Dec 25, 2007 - 7:03 PM) [snapback]625636[/snapback]
Did some on here have it? I never knew...
QUOTE(Kerr1 @ Dec 26, 2007 - 2:45 AM) [snapback]625696[/snapback]
Again, 7lbs is different across turbos, and a motor isn't "supposed" to handle boost. Some do, some don't, even if they are the same type motor.
CLOSED on 25 acres!
post Dec 29, 2007 - 5:17 PM
QUOTE(Kerr1 @ Dec 25, 2007 - 9:45 PM) [snapback]625696[/snapback]
Thats kind of what your not understanding. Mechanical strength is only part of the equation. Fuel and timing control is what really decides how much boost you can safely run. Plenty of people have blown their motors in the past on 7psi of boost, because they failed to upgrade their injectors or make any attempt to visit a dyno and tune their car.
The weak link in your case is the safc. Its a really crude way to try to tune for bigger injectors. If you want the car to last, you should look into something like an emanage, map2ecu, etc... that allows for direct fuel and timing control, and is not just fooling the stock air sensor like the safc does.
Don't take any examples from the burien kit. They sold only one of those, and didn't offer any form of tuning.
post Jan 3, 2008 - 12:50 PM
Kerr1
Joined Dec 24, '06
From jonesville
so dynotuning my car w/ an safc would b kinda pointless? how much am i lookin at just to tune it the "right" way...and i dont mean the most exspensive thing they make but good enough to dyno tune it w/o constantly having to wry abt. it....after that being said...do yall think it would b worth it?
post Jan 3, 2008 - 2:30 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
an safc will work... its just not a good way. like he said, an emanage or something that offers a bit more than a general fuel map based on rpm and 2 points of throttle position will be alot better.
if this is just a fun weekend car then thats prolly the way to go with an safc, but if you want the car to run normal and still have drivability, you're better off going the emanage route.
its not the matter of actually dyno tunning the car, its using the right equipment so that all the time spent tunning is put to good use
This post has been edited by jason: Jan 3, 2008 - 2:31 PM
post Jan 4, 2008 - 6:42 PM
CelicaGT04
Joined Nov 22, '05
From Mesquite, Texas
QUOTE(jason @ Jan 3, 2008 - 2:30 PM) [snapback]627846[/snapback]
I agree with what you are saying, but i think many will agree with me when i say Emanage is not for everyone. It is very difficult for new users who are unfamiliar with any kind of tuning. SAFCII is pretty much your novice-intermediate tuning as it allows you to pull/add fuel or air when you need without needing a laptop in your car.
Kerr1, Once you finish your turbo set up, take your car to a reputable shop (and by REPUTABLE i mean have done EXTENSIVE tuning work) nearby and ask for a complete tune and dyno. They can easily tune your car with the SAFCII and make it RUN DECENT.
But if your looking for PRIME DRIVING then i would recommend the Emanage...
Lo-Fi Version Time is now: November 29th, 2024 - 11:20 PM
