> 4ga wiring and 4ga terminals
post Dec 24, 2007 - 2:19 PM
Stogbob
Joined Dec 23, '07
From Calgary, AB
Looked around a little bit, couldn't find anything. Just a simple question, is it alright if I use 4 gauge terminals with 4 gauge wiring? I know it sounds like a dumb question, but just to be safe should I buy higher gauge terminals to make sure I'm getting full power to my subs?
Thanks in advance!
post Dec 25, 2007 - 11:56 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
it refers to size 1ga is bigger than 4ga in size
post Dec 26, 2007 - 1:55 AM
itssteve
Joined Dec 14, '07
From yorktown Va.
it all comes down to how much power you are running and what brand of wire you are buying(because of strand count)
so tells us how much power how long of a run of wire, and someone can better tell you what ga wire to use
for anything over 1200 watts or 130 amps i would suggest 1/0ga wire andthing less and i would be fine with 4ga
post Dec 26, 2007 - 1:17 PM
Stogbob
Joined Dec 23, '07
From Calgary, AB
QUOTE(soven @ Dec 25, 2007 - 11:56 PM) [snapback]625718[/snapback]
Ahh ok, I didn't know that haha. Learn something new everytime I look at something on this site lol. Thanks tongue.gif
QUOTE(itssteve @ Dec 26, 2007 - 1:55 AM) [snapback]625737[/snapback]
I'm pretty sure it's less than 1200 watts. Thing is, I already had everything in before. I had to take everything out because I went on vacation and needed trunk space, but when I was pulling the wire through one of the holes it got stuck because of the terminal on the end so I had to cut it off. I need to replace that terminal with a new one but I don't know if the other one that I cut off was 4ga frown.gif. So would a 4ga terminal be good enough to put on the end of the wiring or should I go with something bigger? If that makes any sense..
post Dec 26, 2007 - 10:16 PM
ShadowFX
Joined Jan 22, '04
From WA, Australia
4ga is just the size of the wire and terminal. Unless your talking about the quality of the gear, there's no such thing as a 4ga terminal being 'good enough' for the wiring, because it's referring to size.
If you have 4ga wire, you put a 4ga (or larger, to a point) terminal on the end of it. Look at the size of the wire, if the 4ga terminal fits, all good!
post Dec 26, 2007 - 11:35 PM
Stogbob
Joined Dec 23, '07
From Calgary, AB
QUOTE(ShadowFX @ Dec 26, 2007 - 10:16 PM) [snapback]625888[/snapback]
Sweet thanks a ton!
Lo-Fi Version Time is now: December 12th, 2024 - 2:53 PM
