5sfe Header, Anyone know anything about this header? |
Dec 27, 2007 - 4:17 AM |
Enthusiast Joined Mar 9, '03 From Orting, WA Currently Offline Reputation: 0 (0%) |
Dec 27, 2007 - 10:29 AM |
lets see...
its cheap, makes car really hot and loud farty first week or so wont pass smog works on high rpms might need to upgrade exhaust to 2.5" -------------------- |
Dec 27, 2007 - 11:18 AM |
Enthusiast Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) |
I'm not an ebay fan
-------------------- CLOSED on 25 acres! -shop coming soon.... |
Dec 27, 2007 - 12:24 PM |
Have u had these on your car? Im about to install them and check them out.
Dec 29, 2007 - 4:47 AM |
Enthusiast Joined Sep 29, '06 From US Currently Offline Reputation: 3 (100%) |
Hey, I have one in my car, its from that same guy surewin products. Works good recommend-
Dec 29, 2007 - 12:19 PM |
QUOTE(RisingSun1 @ Dec 29, 2007 - 1:47 AM) [snapback]626427[/snapback] Hey, I have one in my car, its from that same guy surewin products. Works good recommend- can u post some pics of it installed? I can not remove the 3 lower bolts i suck.... |
Dec 29, 2007 - 1:09 PM |
Enthusiast Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) |
QUOTE(RisingSun1 @ Dec 29, 2007 - 4:47 AM) [snapback]626427[/snapback] Hey, I have one in my car, its from that same guy surewin products. Works good recommend- did that header bolt on to the cat?....we need some more info or maybe even installation procedure -------------------- |
Dec 29, 2007 - 3:05 PM |
i have the header but i was having issue getting the 3 bolts out of the lower pipe, rusted as ****. any suggestions on that. I didnt want to break the bolts until im sure the header will fit and work without burning up my engine compartment with more intense heat then the car already makes.
pics and info appreciated. |
Dec 29, 2007 - 3:41 PM |
Enthusiast Joined Jul 12, '06 Currently Offline Reputation: 2 (100%) |
QUOTE(sapperk @ Dec 29, 2007 - 2:05 PM) [snapback]626500[/snapback] i have the header but i was having issue getting the 3 bolts out of the lower pipe, rusted as ****. any suggestions on that. I didnt want to break the bolts until im sure the header will fit and work without burning up my engine compartment with more intense heat then the car already makes. pics and info appreciated. soak it overnight with pb blaster then use a deep socket wrench and breaker bar. turn the bolt slowly using the breaker bar. also make sure that the car is raised well and supported. This post has been edited by kcizzle: Dec 29, 2007 - 3:42 PM |
Dec 29, 2007 - 6:32 PM |
^ what he said
Dec 29, 2007 - 9:28 PM |
Enthusiast Joined Jan 2, '07 From Little Rock, AR Currently Offline Reputation: 0 (0%) |
I bought this header off of E-bay. It's quality is pretty good. It bolted up to the stock exhaust no problem. It has bungs for the O2 sensors. It works alright. I really can't comment on the sound or the power gain as I did a lot off work at the same time when I put it on my Celica. It does get pretty hot. I'm thinking about making a heat shield to keep the heat from destroying my wiring harness. It doesn't look real pretty anymore, as it has turned color with age & heat. But it isn't rusting.
Dec 29, 2007 - 9:35 PM |
maybe ill screw with mine after im done with my interior project. as for now the header is decoration for my garage, all shiny and new. that'll sit there until i find an exaust system. By the way anyone have any good ideas for my exaust. i want a full catback system but i cant find anyone online with one.
Dec 30, 2007 - 4:34 AM |
Enthusiast Joined May 19, '06 From North NJ Currently Offline Reputation: 16 (100%) |
QUOTE(sapperk @ Dec 29, 2007 - 9:35 PM) [snapback]626572[/snapback] maybe ill screw with mine after im done with my interior project. as for now the header is decoration for my garage, all shiny and new. that'll sit there until i find an exaust system. By the way anyone have any good ideas for my exaust. i want a full catback system but i cant find anyone online with one. id suggest going with a custom 2.5" mandrel bent catback exhaust.. if you want a name brand the only exhaust available for our cars in the US is the GReddy SP2 catback exhaust. |
Dec 31, 2007 - 2:43 PM |
Enthusiast Joined Nov 1, '07 From Santa Barbara, CA Currently Offline Reputation: 2 (100%) |
"if you want a name brand the only exhaust available for our cars in the US is the GReddy SP2 catback exhaust."
The one for the 2000-2006 GT celica fits our car as well? |
Dec 31, 2007 - 4:04 PM |
QUOTE(99Celica @ Dec 31, 2007 - 2:43 PM) [snapback]626986[/snapback] "if you want a name brand the only exhaust available for our cars in the US is the GReddy SP2 catback exhaust." The one for the 2000-2006 GT celica fits our car as well? NO!!!...not if you mod it... -------------------- |
Jan 3, 2008 - 12:01 PM |
so it can be modded and made to fit? Or is there a better alternative?
Jan 3, 2008 - 10:24 PM |
QUOTE(99Celica @ Jan 3, 2008 - 12:01 PM) [snapback]627809[/snapback] so it can be modded and made to fit? Or is there a better alternative? a better alternative is going to an exhaust shop and having them make you an exhaust (either cat back or from the ex mani back) probably for cheaper than the greddy. -------------------- |
Jan 3, 2008 - 11:00 PM |
lets jus stick back to the topic and discuss about headers which we are talking about.....
any update on the install?.....did it bolt on to the stock cat/downpipe? -------------------- |
Jan 3, 2008 - 11:36 PM |
QUOTE(IllIllIll @ Dec 29, 2007 - 6:28 PM) [snapback]626571[/snapback] I bought this header off of E-bay. It's quality is pretty good. It bolted up to the stock exhaust no problem. It has bungs for the O2 sensors. It works alright. I really can't comment on the sound or the power gain as I did a lot off work at the same time when I put it on my Celica. It does get pretty hot. I'm thinking about making a heat shield to keep the heat from destroying my wiring harness. It doesn't look real pretty anymore, as it has turned color with age & heat. But it isn't rusting. Yea so right now mine is going to be decoration for my garage, i got enough heat under the hood, dont want anymore. |
Jan 4, 2008 - 12:36 AM |
Enthusiast Joined Apr 16, '04 From Raleigh, NC Currently Offline Reputation: 1 (100%) |
put some heat wrap on that bad boy...that'll solve heat issues under hood...but then you'd need new garage decorations
i dunno what kind of emission standards you have in washington state...but even if you don't put that header on you could gut the cats...i mean we all know how restrictive they are but it just seems so much worse when you actually pull the thing off and see all that tight honeycomb |
Lo-Fi Version | Time is now: November 29th, 2024 - 11:18 PM |
