2 Pages V  < 1 2
> 5sfe Header, Anyone know anything about this header?
post Jan 4, 2008 - 1:05 AM
QUOTE(sapperk @ Jan 3, 2008 - 11:36 PM) [snapback]627979[/snapback]
Yea so right now mine is going to be decoration for my garage, i got enough heat under the hood, dont want anymore.
you have an invader front end with the big mouth opening and a HOOD SCOOP, and you're worried about heat in your engine bay ? wft ? confused.gif
I've had a header on my GT and my ST and I have never had any probs with wiring getting too hot or any heat problems, and I have stock front/hoods ends on both cars. If you're worried about heat then just wrap it with heat wrap, you might enjoy the quicker response from having a header on your car.
post Jan 6, 2008 - 12:38 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
QUOTE(Element @ Jan 3, 2008 - 9:36 PM) [snapback]627990[/snapback]
put some heat wrap on that bad boy...that'll solve heat issues under hood...but then you'd need new garage decorations biggrin.gif
i dunno what kind of emission standards you have in washington state...but even if you don't put that header on you could gut the cats...i mean we all know how restrictive they are but it just seems so much worse when you actually pull the thing off and see all that tight honeycomb
Ye gods, do NOT gut the cat.
Gutted cats are effective only in creating turbulence in your exhaust stream and royally screwing up the smooth flow of gas out of the engine. Having the conduit for your exhaust rapidly increase in diametre and then just as quickly neck back down is a great way to allow the gas to expand, cool, slow and produce backpressure (no backpressure is not a good thing, even for NA engines).
That tight honeycomb is actually a highly efficient design which flows the exhaust gases almost as well as a straight, properly sized pipe. If the performance difference between a proper pipe and a cat matters to you, I hope you always remember to empty your bladder before driving too, as that makes about as much difference.
If you're running a stock cat and are concerned it's clogged (which requires a screwy AF ratio, bad gas or some other form of contamination), pick up a quality aftermarket piece such as a Car Sound high-flow cat (parent company of MagnaFlow).
Basic logic -- you and your car will perform better in clean air. And the air will be around to use a lot longer than your car.
post Jan 6, 2008 - 11:10 AM
sapperk
Joined Mar 9, '03
From Orting, WA
The cool thing im military so i dont have to worry about emissions or safety inspections. i live in WA but im not a WA resident. So my windows also could be as dark as they want. hehe.
Not gonna gut the cat. I just got the header cause it was cheap so id check it out. I do wanna go turbo sometime the end of this year after my interior project but thats a whole new subject. as of now though im still trieing to find a decent full exaust that will bolt right on.
post Jan 6, 2008 - 5:20 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
so do you guys have 2.5 or 2.25 with ur ebay header? And which would work better?
post Jan 7, 2008 - 12:22 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
QUOTE(sapperk @ Jan 6, 2008 - 8:10 AM) [snapback]628631[/snapback]
Not having to worry about emissions regulations is one thing. Not having reason to be worried about emissions is another.
2 Pages V  < 1 2
Lo-Fi Version Time is now: December 2nd, 2024 - 5:23 AM
