E153 rear mount solution, st-205 rear mount and bracket |
Jan 9, 2008 - 6:46 AM |
Enthusiast Joined Aug 19, '07 From Farmington, MI Currently Offline Reputation: 7 (100%) |
okay, because don't the side mounts hold and make the postion of the engine? and can u tell me if thats a st mount in my pics above for the tranny side? cause i think it is
Jan 9, 2008 - 6:05 PM |
Enthusiast Joined Nov 6, '06 From Toronto Currently Offline Reputation: 0 (0%) |
QUOTE(toyotacrazy @ Jan 9, 2008 - 6:30 AM) [snapback]629478[/snapback] QUOTE(supra12big @ Jan 8, 2008 - 9:41 PM) [snapback]629371[/snapback] but i can't find a st205 side tranny mount, so does a gt mount work as well? I have a st185. I think it will work but ask around It wont its generation specific. As for the passenger axle use the one phattyduck recommended, you use the MR2 carrier so you dont need a whole axle unless you are getting one from a re-man in which case it will be complete but you seperate it at the 6 bolts. I sent you an email with a link of a guy selling the tranny mount. |
Jan 17, 2008 - 3:38 PM |
Enthusiast Joined Oct 13, '02 From Blairstown, New Jersey Currently Offline Reputation: 6 (100%) |
Yikes, theres alot of information being thrown out here to this poor guy thats either incorrect terminology, or just not right....
To address the mount issue first, it appears that you are using the ST205 rear mount and bracket which is perfect. GT passenger side bracket and mount work just fine, as well as your front transmission mount which can utilize either a GT or ST205 mount. No need to worry there. Your problem lies in the drivers side transmission mount. That looks to be an ST185 mount, since you can see an area on top of the mount where the All-Trac mount support bar bolts to. THIS NEEDS TO BE A ST205 MOUNT/BRACKET COMBO INSTEAD. Change this out, and the engine will sit perfect. To address the axle issues, let me start off with the passenger side first. Your inner looks to be an MR2 Turbo inner, so thats fine. The outer should consist of an outer axle from either an ST185 All-Trac OR an 88-91 Camry V6. Both right and left outer axle are the same on these models, and are the same for either Automatic or 5spd equipped Camrys. You need a spacer as well. You don't need "two spacers" or "a spacer and a half". Right now, your setup has the outer axle bolted up to an EXTRA bearing race....this is the thick metal piece that the inner CV bearings move inside of. That is currently being used as a spacer on your axle, and you need to remove it and get it machined down to 1/2" at a machine shop. Make sure that you leave the tapered lip on the outside of the spacer you make so that it can sit in the cup on your inner axle. Also, you MUST have the INSIDE of the 1/2" spacer you make from the old bearing race bored out as much as possible to where you almost totally eliminate the grooves for the bearings. This will prevent any grinding on binding of the outer axle as it passes into the spacer section. You will eventually want to make about a 1/3" spacer for the drivers side axle as well, just repeat the same method as the passenger side. You probably wont experience any short term damage from not using one, but the drivers side outer axle is at the absolute limit of its travel without one. IMPORTANT!!!!!: You cannot use JUST a set of 88-91 outer axles without spacers. No way, no how....Eggman40, I know you suggest using this combination, but it simply is NOT correct, because the outers on the 88-91 Camry and the ST185 are identical. Check on Autozone or Advance Auto Parts websites and you will see that they use the exact same part number for both. Eggman, I have no idea how you are using just those outers, but it is downright dangerous and I would strongly advise others NOT to use this setup without using a spacer. I had a passenger side outer literally EXPLODE on my car using just the Camry outer and no spacer. The bearings and the retaining basket exploded through the retaining hat on the axle from being over extended. I'm just lucky nobody was hurt, and I didn't blow a CV bearing into the engine block. So unless you like to risk your safety or that of others, DO NOT USE 88-91 OUTERS WITHOUT A SPACER. PLEASE! That should fix all of your issues supra12big. Let me know if you need pictures, I'm sure several of us with spacers would be more than happy to share what photos we have. Good luck. This post has been edited by Silver94CelicaOwner: Jan 17, 2008 - 3:41 PM -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jan 17, 2008 - 10:47 PM |
pics would be nice, how hard is it to pull apart the axles, i have some skill
Jan 18, 2008 - 10:32 AM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
QUOTE(supra12big @ Jan 17, 2008 - 10:47 PM) [snapback]631796[/snapback] pics would be nice, how hard is it to pull apart the axles, i have some skill They come out easy, when and only when the splines are lined up, otherwise GL pulling on it all day. |
Jan 18, 2008 - 2:54 PM |
pics
Jan 18, 2008 - 5:44 PM |
QUOTE(laff09 @ Jan 18, 2008 - 8:32 AM) [snapback]631964[/snapback] QUOTE(supra12big @ Jan 17, 2008 - 10:47 PM) [snapback]631796[/snapback] pics would be nice, how hard is it to pull apart the axles, i have some skill They come out easy, when and only when the splines are lined up, otherwise GL pulling on it all day. Thats false laff09. You DON'T have to remove the inners from the transmission (two piece axle), so there are no splines to line up..... Your axle issue lies entirely within your outer axle setup by using too large of a spacer from the extra bearing race just being bolted up. Like I said above, just remove the extra race and get it machined down to 1/2" including the lip. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jan 19, 2008 - 12:58 AM |
def gonna do it, thanks for all ur help man, how much would a shop charge to cut it down?
Jan 25, 2008 - 6:22 PM |
Enthusiast Joined Aug 17, '04 From California Currently Offline Reputation: 20 (100%) |
QUOTE(Silver94CelicaOwner @ Jan 17, 2008 - 12:38 PM) [snapback]631626[/snapback] IMPORTANT!!!!!: You cannot use JUST a set of 88-91 outer axles without spacers. No way, no how....Eggman40, I know you suggest using this combination, but it simply is NOT correct, because the outers on the 88-91 Camry and the ST185 are identical. Check on Autozone or Advance Auto Parts websites and you will see that they use the exact same part number for both. Eggman, I have no idea how you are using just those outers, but it is downright dangerous and I would strongly advise others NOT to use this setup without using a spacer. Good luck. Dude i know your just trying to help, but you really cant argue with results. Ive had my swap for over 2 years now running that setup and ive yet to come across any issues. I ran this set up just like Sphinx did (he's the one that advised me to do so) and we both had no issues, And he had his for much longer. He raced his car as did I. that means hard launches and high speeds with no issues. Ive driven my car long distances and have traveled at high speeds with no issues. to be honest, i dont think there is any way to fit a spacer in between a V6 camry axle and the mr2 inner. the space for it was just right and cant imagine it fitting anymore with a spacer in there. Maybe it was a faulty install or a faulty axle on your part but i honestly dont think you need a spacer. Because really at 2years? something should have happened at this point right? |
Jan 27, 2008 - 1:02 PM |
Its just really strange... The physical dimensions of the ST185 outer axle and the '88-'91 Camry V6 are definately the EXACT same size...so if they are identical axles then how is it that you don't have any issues with the axle being over-extended? Its just wierd.
Oh, I forgot to mention before that I took my outer 88-91 axle and compared it side by side by an OEM Toyota ST185 outer axle from a front clip and its identical in every way. My outers are from the 88-91 Camry V6 and they were definately too short, just like the ST185 ones. Just take a look at the drivers side and you can see how over-extended even that side is..... and mind you this is with the car in the air! My car was on the road for about a week with no spacers, and you could hear the axles making noise from the bearings rubbing against the retaining hat on the inboard CV joint the whole time. This is exactly what failed on my passenger side, you could see where the stress of the axle against the retaining hat got to be so severe that the axle shaft tore right through it and shot bearings out. I know for an absolute fact that both axles were installed properly, everything was torqued to proper specs and the failure wasn't with the workmanship, but with the axle being torn in half from being way too short. Since then, I have machined a 1/2" spacer for the passenger axle and a 1/3" for the drivers side and the axles are perfect now, no issues at all. Eggman40, could you take pictures of your axle setup and post them?? I really want to come to a solid conclusion on this whole thing and see how your axles are sitting for comparison. -Corey -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jan 27, 2008 - 1:30 PM |
wow, ur axles look normal compared to how mine sit when up in the air, mine are at a way bigger dip then that, atleast 2 times as much, so i am guessing thats super bad, anyways i need to get this fixed, but could u take a pic of ur spacers, and how do they work, cause i was gonna go with eggman, he said there are other people running this and no problems, also people say the v6 camry axles are longer then the st185 axles, i have read about it in past threads, thanks for everyone helping, but i have 2 roads ahead of me, and don't know which one to take?
Jan 27, 2008 - 11:38 PM |
heres a pic of eggmans setup on the passenger side,
Jan 28, 2008 - 2:04 PM |
Enthusiast Joined Dec 5, '05 From LA, CA Currently Offline Reputation: 1 (100%) |
QUOTE(supra12big @ Jan 27, 2008 - 10:30 AM) [snapback]635079[/snapback] wow, ur axles look normal compared to how mine sit when up in the air, mine are at a way bigger dip then that, atleast 2 times as much, so i am guessing thats super bad, anyways i need to get this fixed, but could u take a pic of ur spacers, and how do they work, cause i was gonna go with eggman, he said there are other people running this and no problems, also people say the v6 camry axles are longer then the st185 axles, i have read about it in past threads, thanks for everyone helping, but i have 2 roads ahead of me, and don't know which one to take? The ST185 and '88-'91 Camry have almost exactly the same track (58.3" vs. 58.1" on MSN autos), which hints that the outer axles would be the same length. The USDM 6GC is listed at 59.6", so that tells me that you want a total of 1" to 1.5" of total spacing in there for your axles split between the two sides. I used to be under the understanding that you didn't need a spacer, but this is good evidence that you do need one... -Charlie PS. If anyone has an ST185 right/passenger side inner axle stub, I'm looking for one. -------------------- 2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid 1988 Camry Alltrac LE - BEAMS swap started |
Jan 28, 2008 - 2:49 PM |
so wait are u saying his setup needs a spacer?
Jan 28, 2008 - 7:44 PM |
Yea, a spacer is definately needed.
Charlie, pointing out the difference in wheelbase is a huge help. The length of the Camry or All-Trac outers are SO close to working on our cars....it only requires a fraction of an inch more length to make it sit perfectly. However without that tiny fraction of an inch added, the whole thing is just a ticking time bomb. You'll either eat up inboard CV joints, or have the whole outer axle focibly separate from the retaining hat on the outside, which is clearly a sign that your axle is just too short. Believe me, I'm not saying that it WONT at least drive without a spacer.....it will. But eventually the axle will be the achilles heel of the setup and give out somewhere. Looking at eggman40's setup, that thing is extended way too much. Theres probably only a few millimeters at best between the bearings and the inside of the retaining hat that the bolts go into. A 1/2" spacer is what you need to use, ask me or anybody else using ST185 outer axles which are IDENTICAL to 88-91 Camry V6 axles and they will tell you that its the only way to do this reliably. I have my axle out right now putting in a new axle seal on the transmission, so I'll take pictures of the axle with the spacer while its off the car. I'll also take a picture when its back in the car so you can see how big of a difference it makes. -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jan 28, 2008 - 8:58 PM |
k, by looking at my pics, i hve either one of the two st185 axles, or v6 camry axles in right now, i have 2 spacers, but u said i need to get one cut down, i was wondering if u could sell me a whole completed spacer with axle, so i could just put it in, i don't know where to get spacers from also, thats y i am willing to buy everything i need off u, and just put it together myself? can u do that?
Jan 28, 2008 - 11:17 PM |
thanks supra for posting for me, i didnt wanna go looking for the picture
well there you have my set up. I dont know what else to say, i went with what was proven and its worked for me, 2 years and counting. sphinx ran the same set up, and he did well. I've taken my car up into the canyons, done a few 4-5k launches, burnouts, triple digit speeds and not once had any issues with the axle. never any strange noises or bumps. The only noise that ever came from that direction was a messed up wheel bearing and that went away once i replaced it. If i were to do the same swap again i would not run a spacer but that is just me... why would i change whats not broken? However, dont get me wrong, im not trashing your theory whatsoever. obviously we are dealing with a motor that wassn't designed to be in our car out of the factory, so there might be some X factor that is causing mixed results. I guess we need to keep digging till we find a universal solution. I understand your concern about it eventually being an issue, but so far it has not been. When i was doing my swap, Sphinx sugested this set up because its the one he went with and had absolutely no issues with it. At the time thats all i knew so i went with it and didnt worry about it again. up to this day ive had no issues. but as for now my setup works perfectly and i have no intention on changing it. If something ever comes up, i will let people know. This post has been edited by eggman40: Jan 28, 2008 - 11:22 PM |
Jan 29, 2008 - 6:51 AM |
that seems like a perfect setup since u did have really put it to the test, also quick question, how can people see the axle being over extended?
Jan 29, 2008 - 1:49 PM |
I'll show you the length of my axle when I put it back in. (leaking axle seal)
For me, the universal solution to this issue is to mount the outer axle in the same range of length as what is found on the OEM application for that axle. Using a small 1/2" spacer allows it to sit just like it does in a Camry or a All-Trac, so I figure its probably the best thing to advise to others. It's just one of those things where I figure its best to do it and be safe and not be sorry you didn't, and not stretch the axle to its absolute limits and pray for the best. But, to each his own. -Corey -------------------- 3rd gen ST205 3SGTE - Alive and boosting. |
Jan 29, 2008 - 2:50 PM |
wait did u get my message, could u sell me a 1/2 inch spacer, and i can get 91 v6 camry outters and put them together myself, and i will pay u since u said u have access to a machine shop? please let me know, cause i am going all of this over break
Lo-Fi Version | Time is now: November 28th, 2024 - 6:55 PM |
