2 Pages V  < 1 2
> 96 prism sleeper build
post Jan 3, 2008 - 10:41 PM
jdg371
Joined Jun 14, '05
http://www.youtube.com/watch?v=RKE3id5PmmY
11.4 AE92 Corolla... 7AFE + Blacktop 20V + Turbo = Balls Fast GTZ
post Jan 4, 2008 - 1:26 AM
do7d
Joined Dec 29, '07
From pennsylvania
i found an entire silvertop (20v) swap- just dynoed @ 160hp, about everything needed for the swap:
full silvertop harness.minus fuse box.
redirected forward facing intake.stock
maf,ecu,igniter,coil.etc
2 sohc trannys
flyweel,trd clutch and pressure plate.
2 walbro inline 190lph fuel pumps
altogether delivered for ~$1000. this is really tempting, but i'd *really* like to find the 4AGZE setup. i don't know.. would i still be able to use *most* of these upgrades if down the road i DO find the agze? if so then i could at least use the practice of taking that engine bay apart. smile.gif do we think it's worth it for 55 hp- possibly more properly tuned maybe 75 total.. advance timing, 92 octane, etc.. ?
This post has been edited by do7d: Jan 4, 2008 - 1:57 AM
post Jan 4, 2008 - 11:49 AM
do7d
Joined Dec 29, '07
From pennsylvania
update:
within the next few days i should be acquiring a 4agze swap (from a late model jdm map setup corolla). included with the engine is ecu/harness/440 injectors/arp head studs.
is there anything anybody can recommend that i should get before i start with this? i will be taking out the sc and installing a turbo. but i don't think immediately, unless someone can guide me otherwise.
post Jan 4, 2008 - 12:17 PM
Muggs
Joined Sep 13, '06
From St. paul, MN
You could also twin-charge the gze (turbo AND sc) for big power gains...
Even if you swap a 4age in now, you can drive it as is until you locate AWD parts from a corolla alltrac, which should still bolt up to that motor.
post Jan 4, 2008 - 12:18 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
2 sohc trannys
Silvertop 20V will only make ~115-120WHP. And I don't know why it says SOHC transmissions, as 1) it doesn't matter. and 2) 20V is clearly DOHC.
As for the GZE... After speaking to a local 4AG speed shop they told me ditch the S/C as fast as you can... apparently it is the biggest PITA to wire and work properly.
This post has been edited by 95CelicaST: Jan 4, 2008 - 12:19 PM
**** Photobucket
post Jan 4, 2008 - 12:23 PM
do7d
Joined Dec 29, '07
From pennsylvania
very true.. it's not as if i'd pass one up just bc my engine was already swapped. it's just make things a bit easier with the motor already out, and a little more elbow room to work with. yah well. i can't believe i found a swap so quickly. i just need to wait 2-3wks for the garage space, then i'll have a sc prism. word smile.gif i have not researched a proper turbo to mate with this setup yet. does anyone know right off hand? i would be happy topping 225-250hp for the time being.
and, btw i have already thought abt needing suspension/stopping power upgrades. searching for suspension tonight when i get home from work. i will definitely be checking out the classifieds here & mr2oc, toyotanation, club4ag, ectoyotas.com. i know i need to find a junked LSi to get all-wheel disc brakes, master cyl, lines.. then upgrade to bigger brakes.
This post has been edited by do7d: Jan 4, 2008 - 12:31 PM
post Jan 4, 2008 - 12:26 PM
devilsden97
Joined Jun 13, '05
From Poughkeepsie, NY
QUOTE(Muggs @ Jan 4, 2008 - 12:17 PM) [snapback]628110[/snapback]
Why not just suggets buying a gun, and shooting himself in the face? Cuz from what I just read, u suggested a Twincharged AWD 4A vehicle. No one has substantial info on building an AWD platform on this site (or many others for that mater) and twincharging has been done two times (ive seen it 2x) and it was done by 2 very well know and very deep pocketed shops.
Kawi Love
post Jan 4, 2008 - 12:30 PM
95CelicaST
Joined Feb 5, '05
Check www.club4AG.com
**** Photobucket
post Jan 4, 2008 - 12:44 PM
do7d
Joined Dec 29, '07
From pennsylvania
i forgot to ask- with this engine already having head off, i was thinking a good cleaning is in order. anyone in the philadelphia area know of a solid shop to do the work? maybe tweak it a bit..
post Jan 4, 2008 - 9:57 PM
jdg371
Joined Jun 14, '05
ARP stud everything, get the blocked, pistons, and other cleaned, balance the crank if you have money. I fresh looking motor is always better than having all the dirt collected with the miles.
As for twincharging, I ask why? Sure it "cool" but Turbos are soo efficient now that there are ball bearing turbos that have close to NO lag.
post Jan 4, 2008 - 10:45 PM
do7d
Joined Dec 29, '07
From pennsylvania
i was not looking to twincharge. i was looking to take out the s/c and use the turbo in it's place. im definitely getting everything refinished.
post Jan 6, 2008 - 12:16 PM
do7d
Joined Dec 29, '07
From pennsylvania
when i do the swap i will absolutely be getting a new timing belt- i found one from HKS that goes along with the adj cam gears i was looking to get. my question is this: at the $153 (retail for belt) and $185 (retail for gears) would they be the best quality? are there others equal or better for less $$$?
cam gears 22004-AT001 TOYOTA Corolla GTS 1985-1991 http://www.hksusa.com/products/?id=629
timing belt 24999-AT009 TOYOTA Corolla GTS 1985-1991 ; 113R http://www.hksusa.com/products/?id=2937
and yah, they're both purple. my girlfriend thinks it's cute. it's one less thing she'll bitch abt smile.gif
This post has been edited by do7d: Jan 6, 2008 - 12:21 PM
post Jan 6, 2008 - 6:49 PM
jdg371
Joined Jun 14, '05
No expirience with either of them, but you can't really go wrong with a named brand. Especially HKS.
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 27th, 2024 - 1:28 AM
