Enthusiast Joined May 4, '07 From Denver Currently Offline Reputation: 0 (0%) ![]() |
does any one know their Motegi Racing 18x8 rims with tires the tire size is 235 40 R18 will they rub and should i expect any hp loss.
This post has been edited by lxarmijo: Jan 6, 2008 - 12:57 AM |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) ![]() |
if your car is not lowered you will be fine, only slight rubbing MAY occur when the wheel is fully turned to one side and you hit a bump (like going into a driveway fast)
i havent had any issues, and neither have several others hp wise, power gettin to the ground will be a little less when at higher speeds (like 40mph+) the wheels weigh more than stocks, and they are wider so theres more resistance from the tires the car will also turn and handle differently. geometrically wise it hurts the car's handling, but traction gains due to the larger footprint more than make up for that. -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
![]() ![]() ![]() ![]() (2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Lo-Fi Version | Time is now: February 13th, 2025 - 2:46 PM |
