Car will not go into boost, stays under Vac ..... |
Jan 7, 2008 - 7:23 PM |
Enthusiast Joined Feb 9, '07 From St.lucia Currently Offline Reputation: 0 (0%) |
hey guys my car is having alot of trouble getting into boost ..... there is alot of hestiation to get into boost ... wat do u guys think could be causing this ?
Jan 7, 2008 - 7:24 PM |
vac line
Jan 7, 2008 - 7:29 PM |
i have check all Vac lines ... my vac is 18 on idle where it is suppose to be ... so i am really lost where that is concerned
Jan 8, 2008 - 10:37 PM |
Enthusiast Joined Aug 28, '04 From FLA USA Currently Offline Reputation: 4 (100%) |
It could be so many things that can cause your car not boosting.
- Fuel cut - ECU is in low boost mode and prevent TVSV to open due to errors from knock sensor, intercooler level sensor, etc..) - Clogged cat - Stuck open wastegate - Bad turbo -------------------- _Gary
Jan 9, 2008 - 12:04 AM |
how much boost have you been running?
what are you using the safc for? This post has been edited by lagos: Jan 9, 2008 - 12:20 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 9, 2008 - 12:08 AM |
Should be around -22 when your car's warmed up.
Jan 9, 2008 - 9:43 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
i'm non turbo, and run about 22 idle... 25 on highway when off gas.
-------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 14, 2008 - 10:57 PM |
Enthusiast Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
check your piping?
Jan 15, 2008 - 12:29 AM |
Enthusiast Joined Oct 30, '07 From hudson falls ny Currently Offline Reputation: 0 (0%) |
could be a boost leak
Jan 18, 2008 - 8:42 PM |
Enthusiast Joined Jul 7, '06 From usa Currently Offline Reputation: 0 (0%) |
do a boost leak test to see where the leak is if there is one...gotta be a pretty big leak though if you have "no" boost. Other than that, maybe the turbo's gone.
Lo-Fi Version | Time is now: November 25th, 2024 - 9:40 PM |
