check engine light on |
Jan 8, 2008 - 3:15 AM |
Enthusiast Joined Jul 15, '07 From High ridge MO Currently Offline Reputation: 0 (0%) |
Hello celica lovers I'm having a little problem wit me car the check engine light is on but I dont know how to check it.I've seen it tested before just forgot how sumthing about engine codes read off how many times ur engine light flashes so any help on how I can check it myself I would be thankful
Jan 8, 2008 - 4:09 AM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
you can do it very easily.
open your hood and look for the DIAGNOSTIC box that is located next to the master cylinder (USDM) which is on the driver's side. get a paper clip and slide one end into the T1 terminal and the other end into the E1 terminal. turn car to the on position and the check engine will flash the code. -------------------- Pandelica 2.0 in progress. |
Jan 8, 2008 - 1:27 PM |
Viola!
Here are similar PDFs to download for your own use (note this is for a 1994 Celica, I'm not sure if it varies for newer models): Tests with Codes 1.8L Tests with Codes 2.2L Reading Diagnostic Codes Below are instructions on how to determine what diagnostic codes are stored in your engines computer. This can be very useful in locating the source of a problem when your check engine light comes on. Note: This procedure may not be correct for all Celicas. I do not know whether or not this is correct for RWD Celicas and OBD2 (1996-current) Celicas. Please try at your own risk. 1. Check your battery voltage (should be greater than 11 volts), turn off all accessories, put your car in neutral, and make sure your car is at operating temperature. 2. Jump the terminals TE1 and E1of the "Data Link Connector 1" with a jumper wire (a paperclip will do). 3. Turn the ignition to "On" (but dont start the car) 4. Read the trouble code by watching the flashes of the check engine light Sample Trouble Codes: These codes are for a 6th Gen. Celica...They may, however, be similar and/or carry over to other cars. Code Blink Circuit n/a 8 flashes normal 12 1, then 2 G, NE signal (#1) 13 1, then 3 G, NE signal (#2) 14 1, then 4 Ignition Signal Circuit 16 1, then 5 A/T Control Signal 21 2, then 1 Oxygen Sensor Signal 22 2, then 2 Engine coolent Temp Sensor Signal 24 2, then 4 Intake Air Temperature Sensor 25 2, then 5 Air/Fuel Ratio Lean Malfunction 26 2, then 6 Air/Fuel Ratio Rich Malfunction 27 2, then 7 Sub-Oxygen Sensor signal 31 3, then 1 MAP sensor 41 4, then 1 Throttle Position Sensor signal 42 4, then 2 Speed Sensor Signal 43 4, then 3 Starter Signal 51 5, then 1 Switch condition signal 52 5, then 2 Knock Sensor 71 7, then 1 EGR System This post has been edited by GriffGirl: Jan 8, 2008 - 1:34 PM -------------------- |
Lo-Fi Version | Time is now: November 25th, 2024 - 9:41 PM |
