> question my 3sgte motor
post Jan 9, 2008 - 5:08 PM
JOEY3S
Joined Dec 28, '07
From Puerto Rico/ NOW I AM IN WATERTOWN NY
hi guy's i wanted to know how much boost (psi) can the 3sgte motor support. and in my motor i have all the piston's and rods oem but i upgraded my turbo how much boost can it support right now is at 10 psi can i get it up to 20 psi without it braking my motor.
post Jan 9, 2008 - 5:55 PM
Gary
Joined Aug 28, '04
From FLA USA
It depends on your other mods and the turbo.
What kind of upgrade is it?
Do you have a wideband sensor installed?
_Gary
post Jan 9, 2008 - 6:19 PM
JOEY3S
Joined Dec 28, '07
post Jan 9, 2008 - 9:32 PM
phattyduck
Joined Dec 5, '05
From LA, CA
We would need a lot more information to give you an answer...
Intercooler setup, exhaust setup, turbo (type, trim, any other info), gauges, tuning method (reflashed ECU, piggyback, standalone, etc.), other supporting modifications (injectors, cams, etc.).
-Charlie
2003 Subaru WRX Wagon
1989 Camry Alltrac LE 3S-GTE - SV25/ST205 hybrid
1988 Camry Alltrac LE - BEAMS swap started
post Jan 10, 2008 - 7:33 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE(JOEY3S @ Jan 9, 2008 - 6:19 PM) [snapback]629625[/snapback]
Then don't even consider turning it up that high until you learn/mod afew things. You can mess that motor up really bad by running 20PSI without the right supporting mods.
Just don't do it.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jan 10, 2008 - 2:20 PM
99GT
Joined Dec 14, '06
From MN, USA
You can run any psi you want. Just get it tuned.
post Jan 25, 2008 - 12:13 PM
tufy
Joined Dec 3, '03
From Cyprus
which gen 3sgte is it? 3rd gen 3sgte have stronger internals then 2nd
Lo-Fi Version Time is now: November 25th, 2024 - 9:45 PM
