> moisture coming from exhaust..MODS DELETE TY
post Jan 12, 2008 - 1:49 AM
xs94st
Joined Aug 11, '07
From Corona, CA
well, i used my car today and did my usual errands n work stuff and then i had the idea of trying to put the silencer on my car without it sounding like a bumble. after not being able to drill a hole into the muffler lip, i gave up and just tried to tighten the baffler bolt as tight as possible but with a washer between the baffle and the lip..but thats not important. when i ran the car and tested out the sound of the muffler, i pulled out the baffle and there was a decent amount of moisture inside of the muffler. enough for it to make a small-ish puddle and run a little when i wiped it out. so question is, is my headgasket failing? i usually have a puff of steam or white smoke that comes outta the muffler everyonce in a while after starting. but it wasnt a cold start today cuz i drove it around for a good while 20 minutes prior to me trying to do this.
This post has been edited by xs94st: Jan 12, 2008 - 2:27 PM
Pandelica 2.0 in progress.
post Jan 12, 2008 - 1:54 AM
celicamike
Joined Dec 26, '05
From So Cal
This might help you: LINK
This post has been edited by celicamike: Jan 12, 2008 - 1:55 AM
post Jan 12, 2008 - 2:26 PM
xs94st
Joined Aug 11, '07
From Corona, CA
my bad..damn, i guess i overlooked that when reading through the search results. mods please delete.
Lo-Fi Version Time is now: December 4th, 2024 - 10:48 PM
