> installed Injen intake today. Need some assistance.
post Jan 12, 2008 - 2:53 AM
JasonX
Joined Oct 18, '07
From Orange County, CA
Hi everyone! Installed my Injen intake today. But, gotta few questions. On the directions it is talking about a "stock check valve", which was suppose to be on my old intake duct. When I looked at my old one, that hose wasn't there. There was a bolt covering it instead. So, I couldn't put that valve where I put the "blue question mark". Is it real necessary? If so, i'll go get one. Also, it mentions to plug the stock vacuum hose over the 3/8" nipple under the intake by the T/B. Is that where I put the "red circles"? The 2 red circles are the same line. it connects from T/B to the small diameter pipe under the intake. The "yellow line" is where the line used to be before the Injen. Please look into how I did it and let me know if it is correct. Also, does this intake just sit in there or does it require any other type of securing?
thanks a bunch.
This post has been edited by JasonX: Jan 12, 2008 - 2:32 PM
post Jan 12, 2008 - 2:16 PM
punkuup5150
Joined Apr 10, '07
From lodi, ca
yeah im not sure on how the gt fits up. >_< with my st i just used the little peice of tubeing they sent me and connected the 2 open nipples on the sri together since its built for a gt and not an st wasnt sure what to connect. but it does just sit there and its actually very stable if u feel its moveing a bit just push the cone down a little closer to the body and tighten the clamp around the throttle body and it shoudl hold it in place nice and secure. but it looks great and the sound when u rev is awsome that and the biggest plus is that its carb legal and around at least around here im safe from getting my car towed they r cracking down on racing stupid kids.
post Jan 12, 2008 - 2:35 PM
JasonX
Joined Oct 18, '07
QUOTE(punkuup5150 @ Jan 12, 2008 - 11:16 AM) [snapback]630263[/snapback]
thanks. it was making a little noise, but now it's gone. What's the carb legal sticker? Is that where it just says Injen? Bought my from an open box special, so hope i'm not missing it.
post Jan 12, 2008 - 3:55 PM
punkuup5150
Joined Apr 10, '07
From lodi, ca
my carb sticker is like a hard metal peice on the underside of the sri i beleave if i get a chance ill take a pictue of it. if it didnt come with it u might want to contact injen to get it replaced
post Jan 12, 2008 - 4:50 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
they won't just replace the carb legal sticker... that's the main reason the intake is so expensive... sorry if you don't have it frown.gif also thats connected right
This post has been edited by pittfirefighter: Jan 12, 2008 - 4:51 PM
Breaking Axles...
post Jan 12, 2008 - 7:46 PM
leave the hose connected as is (the red one)
cap the nipple on the TB.
post Jan 12, 2008 - 10:02 PM
JasonX
Joined Oct 18, '07
QUOTE(presure2 @ Jan 12, 2008 - 4:46 PM) [snapback]630349[/snapback]
thanks. i'll cap the nipple on the TB. How about the nipple under the intake? would I want to cap that one also?
thanks again
post Jan 12, 2008 - 10:51 PM
pittfirefighter
Joined Oct 10, '06
From Greensburg,PA
you don't have to cap the nipple on the TB, you have two connections on the intake... you cap the nipple on the TB if you only have one on the intake (like cheap ebay ones)... just leave it just like you have it
Breaking Axles...
post Jan 12, 2008 - 11:00 PM
JasonX
Joined Oct 18, '07
QUOTE(pittfirefighter @ Jan 12, 2008 - 7:51 PM) [snapback]630388[/snapback]
post Jan 12, 2008 - 11:26 PM
JasonX
Joined Oct 18, '07
today I felt the pipe of the intake and it gets pretty hot. At my work there is a insulation company usually on-site. I was thinking of having them fabricate a custom removable insulation blanket to reduce heat. i wonder if it would help.
This post has been edited by JasonX: Jan 12, 2008 - 11:39 PM
post Jan 13, 2008 - 12:12 AM
Rusty
Joined Nov 5, '07
From New Zealand
thats the trouble with metal intakes, it gets the heat from the engine.
what you could do is put a heat shield along the intake piping?
but nice work thumbsup.gif what kind of whistle does it make?
This post has been edited by Rusty: Jan 13, 2008 - 12:17 AM
post Jan 13, 2008 - 3:29 PM
JasonX
Joined Oct 18, '07
QUOTE(Rusty @ Jan 12, 2008 - 9:12 PM) [snapback]630412[/snapback]
i'm not sure if it's a whistle. it's more like a nice real deep tone when you accelarate hard. when you drive steady, sound just like before. so, i really like it. I feel a little difference on responsiveness as well.
post Jan 13, 2008 - 4:52 PM
JasonX
Joined Oct 18, '07
just wanted to make a final comment about what i've heard so far:
1. cap all nipples on new intake, keep the hose going from valve cover to T/B
2. keep the way I got it.
3. keep the red hose the way it is and cap nipple on T/B.
so, guess i'll leave it the way it is.
post Jan 18, 2008 - 3:40 PM
TrdKing
Joined Feb 16, '05
From Brantford, Ontario, Canada
Here is what I did with mine (5sfe)
I capped the one underneath (its just extra)
Then I went to Canadian tire and bought me a copper t fitting, I then used that to make a T so that it connects the factory tb, valve cover, and the new intake. You really dont need either fitting on the injen intake (stock doesnt have any). I just did it like that so every port had something on it (except for underneath).
So if I were you I would drive to Canada and find a canadian tire and buy a copper fitting and then drive back to your place and install it.
Seriously though just make sure you dont leave any port with nothing on it they should all be covered with something.
post Jan 19, 2008 - 12:47 AM
JasonX
Joined Oct 18, '07
QUOTE(TrdKing @ Jan 18, 2008 - 12:40 PM) [snapback]632071[/snapback]
thanks a lot. i was about to head over there but traffic is bad here right now heading that way. guess buncha people having the day off Monday biggrin.gif. thanks wink.gif
post Jan 28, 2008 - 7:47 PM
JasonX
Joined Oct 18, '07
QUOTE(pittfirefighter @ Jan 12, 2008 - 1:50 PM) [snapback]630304[/snapback]
quick update. i found out that they would provide if it didn't come in the box. They wanted pics showing that i don't have and that's it.i just got mine in the mail last Friday. awesome biggrin.gif
This post has been edited by JasonX: Jan 28, 2008 - 7:48 PM
post Jan 28, 2008 - 8:10 PM
SeverX13
Joined Dec 4, '07
From Northeast Pennsylvania
You installed it perfectly. Hoses are correct and it just sits there. there is no securing needed. All u need to do now is man the wheel haha lemme knwo how u like it
‹Superaison› i'm a computer inclined guy..
‹Superaison› or girl. idk what gender I am anymore.
‹SeverX13› *facepalm*
suprakid: o sh!t
suprakid: i wanna get an obama chia pet
SeverX13: hahahahaha
post Jan 30, 2008 - 12:10 AM
JasonX
Joined Oct 18, '07
QUOTE(SeverX13 @ Jan 28, 2008 - 5:10 PM) [snapback]635487[/snapback]
man, I love it biggrin.gif. ofcourse like everyone else who has it says, i love the sound!!! Thanks. I was wondering about the installment for too long now. You got it the same way too so, all good...
This post has been edited by JasonX: Jan 30, 2008 - 12:13 AM
post Jan 30, 2008 - 8:14 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE(presure2 @ Jan 12, 2008 - 7:46 PM) [snapback]630349[/snapback]
I put a breather filter on the nipple on the throttle body side, you mentioned to cap it, should I? I capped the hole on the side of the intake the one that is suppose to have a hose from the valve side. Reason why I did this is because there is already a hose from the valve side going into the TB side.
Anything wrong with my set up?
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 30, 2008 - 5:34 PM
Athorn
Joined Jan 4, '08
From Clearwater, Fl
how long did it take you guys to install?
Lo-Fi Version Time is now: February 19th, 2025 - 9:53 PM
