> Engine Coolant, What kind?
post Jan 14, 2008 - 6:39 PM
aslearvert
Joined Aug 15, '06
From MICHIGAN
Hi guys,
My check engine light came on today, and I think I might be low on engine coolant (I cant see any in the overflow). Do you guys use the orange kind or green kind?... Specific brands? The only thing I know is its not supposed to be alcohol based. I read the manual but I just want to make sure I'm right. Please let me know.
-Thanks very much
post Jan 15, 2008 - 12:25 PM
zero07
Joined Apr 15, '07
From san antonio tx.
The "red" kind........ Toyota.
post Jan 15, 2008 - 12:28 PM
post Jan 15, 2008 - 1:43 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
**** Photobucket
post Jan 15, 2008 - 4:30 PM
Kadett
Joined Mar 17, '05
From The Netherlands
Toyota For Life Coolant all the way.
post Jan 16, 2008 - 6:43 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
I <3 Dustin---07/16/06
post Jan 16, 2008 - 6:54 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
Yeah dude, go get Toyota coolant. Only way to go.
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Jan 17, 2008 - 1:59 AM
Rusty
Joined Nov 5, '07
From New Zealand
post Jan 17, 2008 - 9:13 AM
QUOTE(hurley97 @ Jan 16, 2008 - 6:43 PM) [snapback]631441[/snapback]
post Jan 17, 2008 - 9:27 AM
DEATH
Joined Dec 19, '07
From tx
QUOTE(Kadett @ Jan 15, 2008 - 4:30 PM) [snapback]631036[/snapback]
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Feb 14, 2008 - 6:48 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Hey guys I'm just about to flush mine, How much fits in the system? I have a 2.5 litre bottle of coolant and was told to pour it all in and fill the rest with water, but I'm aiming for 50/50 ratio so how much should I put in???
Mike W
269awhp / 273ft-lbs
post Feb 14, 2008 - 9:10 AM
Mix it prior to putting it in.
post Feb 14, 2008 - 9:30 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
Prestone un-mixed then add some poland spring water. (kidding, i have well water) I don't consider it "tap" water.
post Feb 14, 2008 - 9:51 AM
wrathc5525
Joined Oct 30, '07
From hudson falls ny
i dont know about where you guys are but where i am (for whoever suggested the 50/50 mix) that is the biggest scam ever because it is the same price as a regular gallon of antifreeze. so basically your paying the same price for half as much because your only getting a half gallon of antifreeze.
post Feb 14, 2008 - 10:01 AM
crandsberry
Joined Jul 22, '07
From alexandria, VA
I once had an old '88 accord that ran with tap water for a while.
Yeeep, right up until the water pump completly failed and then the radiator cracked.
OBD-II makes me a sad panda
post Feb 14, 2008 - 10:43 AM
Redline08
Joined Feb 23, '07
From Albany, NY
no tap water! lol distilled water and toyota coolant ftw
post Feb 24, 2008 - 6:10 PM
94TRDcelica
Joined Feb 4, '08
From UK
EVANS NPG Coolant!
post Feb 24, 2008 - 7:47 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
low coolant wont cause your check engine light to come on....not until you've over heated, blown the headgasket, and caused a check engine light for misfires or something.
post Feb 24, 2008 - 9:23 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
QUOTE(Bitter @ Feb 24, 2008 - 7:47 PM) [snapback]645284[/snapback]
post Feb 25, 2008 - 8:48 PM
Bitter
Joined Mar 11, '06
i was being a little facetious, but there is no coolant level sensor that will illuminate the check engine light. those sensors illuminate a coolant level light. theres not even an OBD2 code for low coolant level, unless its manufacturer specific.
Lo-Fi Version Time is now: February 17th, 2025 - 7:11 AM
