Jan 14, 2008 - 9:05 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Calgary Currently Offline Reputation: 20 (100%) |
hey guys and girls, i've compiled a complete list of TRD parts for the 6th gen. If there are any that i've missed or any information i should add, feel free to post them or let me know and I will put them up..
..have a good read Important: All parts listed were recognized through the U.S. ToyotaWorld.com parts search engine and the following prices are in USD. So these are the North American version part numbers of TRD Parts. Japanese TRD part numbers can be found at the link I provided at the end of this post. Other genuine toyota parts sites are: Toyota Parts Cheap.com and 1st Toyota Parts.com if you want to compare prices. Note: All parts have been identified correctly but have unconfirmed availability, so I'd suggest to verify with the parts dept before placing an order online. more TRD parts can also be found from Valo666's thread (TRD Parts and #s) 1. TRD Front Strut Brace ![]() BRACE ASSY,STRUT TOW 00602-53607-006 $223.84 ![]() ^image taken from the TRD USA 2000 model catalog Note: THIS ITEM IS DISCONTINUED 2. TRD QuickShift Kit ![]() ![]() Version 1 QUICKSHIFTER 94-97 00602-30301-004 $154.89 Version 2 SHIFTER QUICK KIT PTR04-20940-04 $166.44 Note: Not sure what the difference is between the two, but one of them will shorten the throw by 40% from stock. Note: THIS ITEM IS DISCONTINUED 3. TRD Lowering Springs ![]() ![]() Version 1 SPRING SET,LOWERING, 00602-48130-008 $196.34 Version 2 SPRINGS LOWERING SET PTR04-20940-08 $201.40 Note: Not sure what the difference is between the two. 4. TRD Performance Brake Pads ![]() HP (High Performance) 1994-1997 Celica with 4 wheel disc brakes (ie. GT and GT-S) BRAKE PADS (Front) 00602-04491-015 $50.68 1994-1996 Celica with rear brake drums (ie. ST) BRAKE PAD SET,FRONT, 00602-04491-019 $51.33 HPZ (High Performance Z-Rated) (only available for ST) 1994-1996 Celica with rear brake drums (ie. ST) BRAKE PADS (Front) 00602-04491-020 $80.17 Note: I'm assuming the 'Z' in HPZ is of a higher performance model? It sucks how it's only available for ST 5. TRD High Flow Air Filter ![]() Version 1 AIR FILTER 00602-17801-001 $47.87 Version 2 FILTER AIR 3.0 V6 (don't be fooled by the '3.0 V6'. this filter is used in other models too.) PTR05-06990-01 $49.40 ![]() CLEANING KIT AIR FIL (optional) PTR05-00000-CL $16.72 6. TRD Type-N High Pressure Radiator Cap ![]() CAP RADIATOR 18.5PSI (or 127.55 kPa or 1.3 kg/cm) PTR04-00000-03 $29.30 7. TRD High Performance Oil Filter ![]() Version 1 (Red) TRD OIL FILTER 00642-90915-002 $18.48 Version 2 (White) FILTER OIL PTR14-00000-05 $11.40 Version 3 (Black) PTR43-00080 $9.95 Note: VERSIONS 1 & 2 ARE DISCONTINUED Version 3 still available. I just ordered 4 last week (May 11, 2011). 8. TRD Oil Filler Cap ![]() Version 1 CAP, OIL FILLER 00602-12108-001 $44.11 Version 2 (shown above) OIL CAP,SCREW-ON BIL 00602-12108-002 $40.28 9. TRD Gear Shift Knob ![]() A. SHIFT KNOB BLK ALUM 00602-36303-005 $33.43 B. SHIFT KNOB SILV ALUM 00602-36303-003 $33.43 C. KNOB, SHIFT, LEATHER 00602-36303-001 $22.00 ![]() D. KNOB SHIFT BALL TYPE PTR04-00000-06 $22.04 E. KNOB SHIFT LEATHER PTR04-00000-05 $58.07 F. TRD TACOMA SHIFT KNB PTR26-35060 $36.00 Note: IIRC, D is the only one that is a direct install to the stock shifter. The rest may require modifications to fit. 10. TRD Clutch Kit ![]() For AT200 Celica (ST Models) only CLUTCH SET, HI-PERF 00643-31200-006 $304.70 This post has been edited by azian_advanced: May 20, 2011 - 10:03 AM -------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- |
azian_advanced Complete List of TRD USA Parts Jan 14, 2008 - 9:05 PM
azian_advanced 11. TRD 3S-GTE Metal Head Gasket
GASKET CYL-HEA... Jan 14, 2008 - 9:15 PM
D_Dawg very nice, i thought u were messing with us with t... Jan 14, 2008 - 9:30 PM
95st-celica wow thats awesome...someone needs to find that oth... Jan 14, 2008 - 10:48 PM
CelicaST_CALI YES YES,is that oil cap for the ST? Jan 14, 2008 - 10:56 PM
azian_advanced QUOTE(CelicaST_CALI @ Jan 14, 2008 - 9... Jan 14, 2008 - 11:16 PM
808celica i really want that front strut bar. and damn trd f... Jan 14, 2008 - 11:09 PM
CelicaST_CALI wat about that oil filter and strut bar?? Jan 14, 2008 - 11:24 PM
laff09 QUOTE(CelicaST_CALI @ Jan 14, 2008 - 11... Jan 14, 2008 - 11:38 PM
CelicaST_CALI sickkkkkkkkk,ima admit i got a lil man crush here ... Jan 14, 2008 - 11:50 PM
Rusty nice
TRD oil filter (JDM ones look different) Jan 15, 2008 - 2:12 AM
laff09 How come? Jan 15, 2008 - 11:36 AM
daazndood wow 200 dollars for TRD lowering springs. thats pr... Jan 15, 2008 - 3:29 AM
SAE-HI QUOTE (daazndood @ Jan 15, 2008 - 3... Feb 3, 2012 - 5:49 PM
Starcraftjunkie So which quickshifter is the one we want? Jan 15, 2008 - 11:29 PM
CelicaST_CALI u dont even play starcraft.... Jan 16, 2008 - 12:00 AM
Starcraftjunkie lol.. nice way to go off topic.
I did play. Way... Jan 16, 2008 - 7:12 PM
hongkongnerdboy QUOTE(Starcraftjunkie @ Jan 16, 2008 - 7... Jan 18, 2008 - 12:55 AM
azian_advanced probably the later version... i've read before... Jan 16, 2008 - 12:33 AM
Rusty QUOTE wow thats awesome...someone needs to find th... Jan 16, 2008 - 1:48 AM
kloudkicka wow, you found alot of trd goodies, wish i had the... Jan 16, 2008 - 7:33 PM
CaliJeff i thought they dont make the 3 pt strut bar anymor... Jan 17, 2008 - 9:47 PM
azian_advanced yeah.. the part numbers that begin with PTR are th... Jan 17, 2008 - 10:37 PM
Daftboy tomo i will try too order the 3 point strut brace.... Jan 18, 2008 - 12:48 AM
azian_advanced hey now don't make him have to change his name... Jan 18, 2008 - 7:31 AM
Valo666 nice write up...i actually ordered some parts from... Jan 18, 2008 - 12:24 PM
laff09 QUOTE(Valo666 @ Jan 18, 2008 - 12:24... Jan 18, 2008 - 1:23 PM
Rusty oh stink to be where you guys are. We have overnig... Jan 18, 2008 - 1:38 PM
vile_v well today i looked up some trd parts on the toyot... Jan 18, 2008 - 10:39 PM
Blurr05 Would anyone recommend a TRD Quickshifter kit over... Jan 20, 2008 - 10:52 AM
Insanity-74 TRD Limited slip dif is still available
Also the ... Jan 20, 2008 - 2:18 PM
Valo666 QUOTE(Blurr05 @ Jan 20, 2008 - 10:52... Jan 21, 2008 - 12:15 AM
Blurr05 So the "lever" on the TRD peice would be... Jan 21, 2008 - 12:44 AM
_mikeE i'm gonna go to the toyota dealership and see ... Feb 12, 2008 - 6:41 PM
Tigawoods great post. i might get some make some orders this... Feb 12, 2008 - 11:11 PM
MaskedMan Has anybody confirmed if the TRD part number for t... Feb 12, 2008 - 11:38 PM
Tigawoods i will check tommorow...haha nah im too lazy Feb 13, 2008 - 12:43 AM
MaskedMan I should have got up went walked 100ft and asked t... Feb 13, 2008 - 1:54 AM
azian_advanced you guys are so lazy.. haha, just call them and a... Feb 13, 2008 - 8:10 AM
Tigawoods QUOTE(azian_advanced @ Feb 13, 2008 - 8... Feb 13, 2008 - 9:04 AM
MaskedMan Just to confirm the TRD strut bar part number is v... Feb 15, 2008 - 10:24 PM
99Celica how much did you pay? I think I might go order one... Feb 15, 2008 - 10:41 PM
MaskedMan I paid $240 which is about the same from Toyo... Feb 16, 2008 - 5:48 AM
Valo666 just an update regarding my parts. 2 of the 3 thin... Feb 17, 2008 - 3:02 PM
MaskedMan Care to share what parts you ordered? Feb 17, 2008 - 3:52 PM
azian_advanced the part numbers listed is all north-american.
th... Feb 19, 2008 - 7:04 AM
GotToyota Anyone have any experience with that quickshift ki... Feb 19, 2008 - 2:53 PM
hongkongnerdboy gave them a part number for the celica dragon badg... Feb 19, 2008 - 5:14 PM
thespacepanda QUOTE(hongkongnerdboy @ Feb 19, 2008 - 1... Feb 19, 2008 - 5:37 PM
hongkongnerdboy which dealership you go to? when i was in texas i ... Feb 19, 2008 - 7:13 PM
thespacepanda QUOTE(hongkongnerdboy @ Feb 20, 2008 - 1... Feb 20, 2008 - 4:50 PM
Valo666 QUOTE(MaskedMan @ Feb 17, 2008 - 3:5... Feb 19, 2008 - 8:06 PM
Tigawoods i went and they looked it up and had it there in t... Feb 20, 2008 - 8:10 PM
azian_advanced bump... added a few new items. see 2nd post. Sep 17, 2008 - 11:09 PM
GotToyota Is it possible to get that front bumper anymore? I... Sep 18, 2008 - 12:11 AM
Akirad1 QUOTE (GotToyota @ Sep 18, 2008 - 1... Sep 18, 2008 - 12:16 AM
GotToyota QUOTE (Akirad1 @ Sep 18, 2008 - 12:1... Sep 18, 2008 - 12:18 AM
azian_advanced someone said that it was discontinued.. but if you... Sep 18, 2008 - 9:38 AM
Akirad1 yeah i checked it it says 1195.10 + shipping i gue... Sep 18, 2008 - 12:40 PM
GotToyota QUOTE (Akirad1 @ Sep 18, 2008 - 12:4... Sep 18, 2008 - 1:30 PM
jmeyer Just bought front and rear strut tower braces from... Sep 18, 2008 - 1:19 PM
97celiman also i think the trd knob also fits the stock shif... Sep 18, 2008 - 5:54 PM
azian_advanced so the trd front strut bar is still available? i r... Sep 18, 2008 - 9:55 PM
audet2604 i want trd spoiler and how much this spoiler Sep 18, 2008 - 10:05 PM
azian_advanced visit japanparts.com. last time i checked it was a... Sep 18, 2008 - 10:36 PM
GotToyota The TRD body parts are crazy expensive. Would ther... Sep 18, 2008 - 10:44 PM
Akirad1 ebay for spoilers but bumpers i dunno maybe the ca... Sep 18, 2008 - 11:03 PM
Rusty QUOTE so the trd front strut bar is still availabl... Sep 19, 2008 - 1:34 AM
azian_advanced but make sure you get the right spoiler... there a... Sep 19, 2008 - 6:38 AM
Akirad1 did anyone ever confirm the carina TRD 7afe wires ... Sep 21, 2008 - 4:03 PM
nics Can we STICKY this?? took me forever to find this ... Jul 16, 2009 - 11:06 AM
Rusty yeah, great list of parts (I also had the feeling ... Jul 16, 2009 - 8:36 PM
SeverX13 ^^^^^^^^^^ I WANT THAT!!! Jul 17, 2009 - 2:24 PM
nics x2!!!!!!
Got P/N? Jul 17, 2009 - 11:13 PM
Rusty ummm just a second.....
right the
TRD Sports St... Jul 17, 2009 - 11:53 PM
Keiri I don't know if this holds true anymore but I ... Jul 18, 2009 - 12:21 AM
BonzaiCelica http://cgi.ebay.com/ebaymotors/JDM-Toyota-...sQ5fA... Jul 18, 2009 - 12:25 AM
Rusty ^ yeah forgot to add the TRD steering wheel & ... Jul 18, 2009 - 1:51 AM
2bcelica The TRD steering wheel is really nice and sturdy. ... Jul 18, 2009 - 7:20 AM
azian_advanced i just made a couple of changes and fixed one brok... Dec 11, 2009 - 3:37 PM
nics QUOTE (azian_advanced @ Dec 11, 2009 - 1... Dec 11, 2009 - 7:38 PM
Random_Stranger Why is this not stickied? I found this thread ver... Dec 11, 2009 - 7:53 PM
nics i asked to sticky this way back in july, nothing h... Dec 12, 2009 - 1:29 AM
BonzaiCelica hmm I need to find myself a japanese friend to tra... Dec 23, 2009 - 1:56 PM
Rusty check TRD japan, go through part section Dec 24, 2009 - 12:24 AM
BonzaiCelica I gave my toyota dealer the version 2 TRD air filt... Nov 8, 2010 - 10:36 PM
azian_advanced Version 2 is part of the newer series of TRD part ... Nov 9, 2010 - 8:26 AM
presure2 if nobody lets a mod know, then we cant do anythin... Nov 9, 2010 - 8:42 AM
Rusty has been for a while in the General discussion sti... Nov 9, 2010 - 12:21 PM
BonzaiCelica QUOTE (azian_advanced @ Nov 9, 2010 - 8... Nov 9, 2010 - 8:35 PM
Rusty those websites sell Japanese specific parts.
USDM... Nov 10, 2010 - 2:35 AM
BonzaiCelica QUOTE (Rusty @ Nov 10, 2010 - 3:35 A... Nov 10, 2010 - 3:31 AM
lagos Version 2
PTR04-20940-08
... Nov 10, 2010 - 11:47 AM
BonzaiCelica New TRD GT-4 Coilover Kit for the Circuit at ... Nov 10, 2010 - 9:24 PM
BonzaiCelica these cartridges are so darn expensive!!... Nov 15, 2010 - 8:30 PM
BonzaiCelica how loud is the decibal rating on the ST202 TRD Ex... May 18, 2011 - 12:56 AM
BonzaiCelica anybody know??? May 20, 2011 - 4:10 AM
Needles the full description is really helpfull lol, if i ... May 23, 2011 - 1:53 PM
BonzaiCelica many European and Japanese Members that buy TRD Co... Jul 20, 2011 - 1:24 AM
d_boice What is the part number for the ((21. TRD rear spo... Feb 3, 2012 - 3:51 PM![]() ![]() |
| Lo-Fi Version | Time is now: January 11th, 2026 - 11:09 AM |
