7AFTE PROBLEM, need help |
Jan 15, 2008 - 12:08 AM |
Enthusiast Joined Jan 31, '07 From Ontario, Canada Currently Offline Reputation: 1 (100%) |
kinda stupid question but what size injectors should i get for 7afte.. like ones off what car would be best i herd somewhere before that ford probe's are best or lime top supra ones, but im not sure. and as far as clutch, my current stock one is pretty new and i will only run the car max 8psi will they not last long at all or will i be ok? Also can i keep my same exhaust system? Right now its all stock except a n1 muffler and header/downpipe. Obviusly the header and downpipe have to go but do i HAVE to have 3" piping or can i just have stock after the downpipe out to a aftermarket muffler? thanks for any help
This post has been edited by mikecelica: Jan 15, 2008 - 2:04 AM |
Jan 15, 2008 - 2:49 AM |
Enthusiast Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
QUOTE(mikecelica @ Jan 15, 2008 - 2:08 AM) [snapback]630875[/snapback] kinda stupid question but what size injectors should i get for 7afte.. Ford Probe Turbo Injectors or any High Imp. 310cc. and as far as clutch, my current stock one is pretty new and i will only run the car max 8psi will they not last long at all or will i be ok? Need a stronger clutch. Your stock will not last too long. Also can i keep my same exhaust system? Right now its all stock except a n1 muffler and header/downpipe. Obviusly the header and downpipe have to go but do i HAVE to have 3" piping or can i just have stock after the downpipe out to a aftermarket muffler? You do not need 3 inch. 2.5 will suffice. But yes, your stock exhaust piping will need to go, you can reuse your muffler though. l This post has been edited by Harold_Fastwaker: Jan 15, 2008 - 2:50 AM -------------------- |
Lo-Fi Version | Time is now: January 11th, 2025 - 7:44 AM |
