Swapping for Leather seats |
Jan 15, 2008 - 4:37 PM |
Enthusiast Joined Dec 30, '07 From Kent, United Kingdom Currently Offline Reputation: 0 (0%) |
Hi, does anyone know if its difficult to take out the front and rear seats. I've seen a set of leather seats from a 1999 GT4 on ebay and was thinking of getting them, only going for £6 at the moment!
cheers |
Jan 15, 2008 - 4:43 PM |
Enthusiast Joined Feb 22, '07 From norcal bay area Currently Offline Reputation: 4 (100%) |
its really easy......all u need is a 14mm maybe a 12mm socket for da bak.
pop da plastic covers of da front seats to get to da bolts and ur ready to go. DONT FORGET TO UNPLUG UR SEATS BEFORE TAKING IT OUT.....i made dat mistake. good luck This post has been edited by ZEROCOOL: Jan 15, 2008 - 4:44 PM -------------------- of all da things i lost.... i miss my mind da most
Jan 15, 2008 - 4:49 PM |
wow easy!
So do you unbolt the rails from the floor or unbold the seat from the rails? Im guessing its eaiser to unbolt the seat from the rails, also is it the case of unplugging the seatbelt pretentioners and plugging the new ones in? |
Jan 15, 2008 - 5:40 PM |
4 14mm bolts hold each seat (with rail attached) to the car. Just unplug the seatbelt plug under each seat and remove the 4 bolts.
FYI the 94-95 seat belt clips are a different size than the 96-99 but since the new set is the same year, you won't have any problem. -------------------- |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:21 PM |
