new idea to keep Injen SRI cooler... |
Jan 15, 2008 - 8:55 PM |
Enthusiast Joined Oct 18, '07 From Orange County, CA Currently Offline Reputation: 3 (100%) |
hey guys,
I put this insulation blanket on temporarily on my intake as seen in the picture to keep it cooler since i felt the pipe get pretty hot. the pipe did feel much cooler when i had it on so i'm thinking about having the guys at my work custom make one for my intake that would cover it end to end, stopping at the filter. ofcourse, there would not be a need for duct tape anymore . What do you guys think, would it make any difference on performance either way? I don't want the hassle if not worth it. Thanks... -------------------- |
Jan 15, 2008 - 9:06 PM |
Enthusiast Joined Aug 11, '07 From Corona, CA Currently Offline Reputation: 4 (100%) |
ey how much for a sheet that long? any way i can buy a slice from ya? i can jus put some rings around it n tighten it up for a good fit.
as for performance wise, i duno how much of gain there would be..assuming there is one :X -------------------- Pandelica 2.0 in progress. |
Jan 15, 2008 - 9:10 PM |
Enthusiast Joined Oct 30, '07 From hudson falls ny Currently Offline Reputation: 0 (0%) |
well the cooler the air the better your chances for a complete burn in the combustion chamber. so it would be helpful. personally i would just go to like advance auto or autozone and buy the stuff that is used to wrap the exhaust manifold and use that around the intake. it still works off from the same concept for the manifold just in a reverse process for the intake keeps the cool air in and the hot air out.
Jan 15, 2008 - 9:16 PM |
well, i was thinking about wrapping as well, but the carb legal sticker will be on the intake. so incase anyone needs to see that, i figured removable will be a good idea. They take the measurement and make it fit perfect and it stays on with velcro.
xs94st: i could give you this one, once i'm done experimenting. -------------------- |
Jan 15, 2008 - 9:29 PM |
gnarly sounds like a plan
my SRI is fairly shorter than your GT's injen so im sure it would fit jus fine..i have yet to buy exhaust wrap for my headers so i guess once i do that i will keep the rest for my SRI n wrap it like wrath had suggested -------------------- Pandelica 2.0 in progress. |
Jan 15, 2008 - 11:42 PM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
hmm, dunno how much that would help performance. yeah the pipe is cooler, but it'll still be sucking in hot air from the engine bay. aftermarket intakes only add about 3-5 hp anyways. if it doesn't cost too much to make one then go for it.
-------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Jan 16, 2008 - 1:57 AM |
Moderator Joined Nov 5, '07 From New Zealand Currently Offline Reputation: 3 (100%) |
I'd go for cold airbox, which is what I'm planning to do to mine...
Jan 16, 2008 - 3:24 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
cut holes in your hood to release hot air....................
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jan 16, 2008 - 10:21 AM |
Enthusiast Joined Aug 21, '07 From Toronto Currently Offline Reputation: 1 (100%) |
I wrapped my custom SRI as well but I used a thermal wrap.
Here's the thread with the pics. I felt a little improvement in the performance. My SRI and Custom heat shield box -------------------- -Derick
"In hoc signo vinces." In this sign thou shalt conquer." Gone but never forgotten.... |
Lo-Fi Version | Time is now: December 3rd, 2024 - 2:57 PM |
