> Lots of hesitation, What could it be?
post Jan 16, 2008 - 6:07 PM
lipweb
Joined Jul 7, '06
From usa
Well, I bought this car from my brother 2 days ago...he said he was just about to do a tune up and change the air filter...he didn't have the chance to do it and neither have I. Anyway, when I come to a stop my idle starts dropping from 900 to 800 to 700 and barely stays around 600 rpms...then when I pick up it pops and hesitates with some slight jerking and then it goes good again. What's that all about???
post Jan 16, 2008 - 6:22 PM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(lipweb @ Jan 16, 2008 - 6:07 PM) [snapback]631422[/snapback]
spark plugs.
post Jan 16, 2008 - 6:26 PM
Im going with vac leak. Check for any cracked, loose, or disconnected rubber hoses under the hood.
post Jan 16, 2008 - 8:35 PM
lipweb
Joined Jul 7, '06
From usa
yeah i figured had something to do with the plugs too, but now my check engine light came on...i have an injen intake with a k&N air filter and an aeroturbine exhaust. It bucks when taking off in 1st at a regular acceleration. I'm going to do the tune up and check for those vac leaks asap, I'll post up again. Thanks!!
post Jan 17, 2008 - 5:27 PM
check what the CEL code is. That will tell you whats causing the problem.
post Jan 17, 2008 - 7:01 PM
lipweb
Joined Jul 7, '06
From usa
QUOTE(lagos @ Jan 17, 2008 - 5:27 PM) [snapback]631679[/snapback]
well I just finished the plugs, wires, cap and rotor...didn't hear any vac leaks at all and traced all hoses and couldn't find anything. since i started it up the check engine light turned off. the plugs were pretty bad and the rotor lead was burned too. I'll have to run it before I'll know for sure...
post Jan 18, 2008 - 10:39 AM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(lipweb @ Jan 17, 2008 - 7:01 PM) [snapback]631723[/snapback]
CEL maybe a bad o2 sensor
post Jan 18, 2008 - 3:17 PM
lipweb
Joined Jul 7, '06
From usa
Ran the car on streets and highway for about 40 minutes...no probs at all. Thanks!
Lo-Fi Version Time is now: December 3rd, 2024 - 1:59 AM
