> headlight rings, rubber around them...
post Aug 20, 2003 - 3:29 PM
Jeremy1210
Joined Dec 16, '02
From Cincinnati, Ohio
The rubber ring around my LB are coming off. What can I use to keep it in place?
post Aug 20, 2003 - 5:17 PM
SuperMica
Joined Aug 19, '03
My boyfriend and his buds have that problem only with their t-top's weather stripping. all you need to do is go to an auto parts and buy some weather stripping glue or plastic trim glue and glue it in place. The blackish gray green weather stripping glue though we have had to keep putting it on after a heavy rain or in lots of heat, So if you can find the plastic trim glue because I had to glue the t-top weather stripping back on, on my first car (an old '91 camaro iroc) and that one time was all I had to worry about but then too, I totalled the iroc about 10 or 12 months later. smile.gif
post Aug 20, 2003 - 11:48 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
mine both flew off on the highway- arrrgg!
post Aug 21, 2003 - 12:38 AM
Mynzeyes
From Franklin/Nashville, TN
dab a small amount of krazy glue on it, then push the ring back in place. that should do the trick. smile.gif. what it is, is that the ring has come out from under these little metal clips...so if you wanna do it right, you'd have to take the headlights out, and if you wanna do that, you have to take the bumper off. tongue.gif. krazy glue. wink.gif
-John-
ps, if you ever loose them (i lose my high beam seals) they are only 8 bucks each from toyota.
AIM==Mynzeyes
post Aug 21, 2003 - 1:05 AM
macavely
Joined Nov 4, '02
3 bucks at the dealer
post Aug 21, 2003 - 5:34 PM
Verde97
Joined Aug 20, '03
From Kansas City
Just get more clips. I had the same problem. Cheap at the dealer.
Lo-Fi Version Time is now: November 25th, 2024 - 1:28 PM
