> paint your plastics by Marbledpearlcelica AKA"DAPAINTER"
post Jan 17, 2008 - 5:49 PM
Marbledpearlceli...
Joined Sep 9, '07
From tampa
Whats up guys I am a custom painter in clearwater,fl PPG certified and I-Car certified and currently working at a highend dealership here.... I saw a few write ups on painting interior , they were descent but if you want the real custom look follow these steps Pics of fisnished work will be up soon
Step one: remove the interior pieces ... 99% of the time the interior is held in by clips... But on the center radio bezel after you take out the bottom piece there is 2 10mm screws on both sides then just pops out
Step 2: most people clean there interior and armoral them up baaaaadddd news if your painting thats fisheye heaven there... you will need to go to a auto parts store or local paint dist shop and get what is known as wax and grease remover its a solvent based cleaner if your using ppg the deltron line dx440 is awsome. wipe on with a towel moistend with it then right aways wipe off with a dry towel...
Step 3: if there is no texture like on our interior pieces scuff them up with 600 or 800 grit paper this will alow the paint to stick...
Step 4: pick your color do not use the cheap duplicolor that you can buy at the autopart store... go to your local bodyshop supply pick the color have them mix you 8 oz or a pint buy some reducer and clear and do it the right way mettalics and pearls on a hvlp gun shooth them at 10-15psi and clear at 25psi ... on a conventional spray gun shoot them at 35 psi and clear between 35-40 psi....
PPG is a good paint will last forever if prepped as written... is somewhat pricey but you can do your interior awsome for under 100.00$ you can go with the dupont nason line and do it for under 75 but would rather you go the PPG route
PPG materials needed for spraying your parts
Deltron or global paint
deltron or global reducer deltron is cheaper pick your temp rating
Deltron or global clears global clear that is good for this stuff is D893(clear) with d884(hardner) and D871(reducer)
THESE PICS ARE A TAD BIT MORE ADVANCED THEN JUST A SIMPLE COLOR THESE ARE MARBLED JUST AS I DID MY CAR BUT COLORS SWITCHED WITH BLACK POPPING THREW THE GREEN WITH GREEN BEING THE TOP COLOR BUT THIS IS WHAT YOUR STUFF COULD LOOK LIKE
ANY QUESTIONS ASK AWAY
This post has been edited by Marbledpearlcelica: May 17, 2008 - 3:02 PM
post Jan 17, 2008 - 6:23 PM
Stogbob
Joined Dec 23, '07
From Calgary, AB
What if you don't have a spray gun? How could someone like me go about painting the interior pieces?
Nevermind just found out how =\
This post has been edited by Stogbob: Jan 17, 2008 - 6:28 PM
post Jan 17, 2008 - 6:26 PM
jason
Joined Oct 7, '06
From wyomissing pennsylvania
great write up, however i doubt too many people who paint their interiors have a gun to use which is why they just clean, spray, n install
id love to see some metallic/pearlescent interior shots, hopefully not too overboard... like some metallic gunmetal ones would be nice =) just something subtle, yet refined
post Jan 17, 2008 - 6:29 PM
punkuup5150
Joined Apr 10, '07
From lodi, ca
when i paint my car im painting the interior the same color so ill be doing this pretty much to the letter. ill be sure to post lots of pics biggrin.gif
post Jan 17, 2008 - 6:31 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUESTION!
I already have the grease/wax remover and a can of paint that I want to use. My local paint guy suggested doing a fog coat of adhesion promotor on the surface and let it dry before laying down the color coat. Any thoughts on adhesion promoter?
"He won't come out of the bathroom. He keeps telling us we're dark somethings and not his friends."
"Hmm. Ask him if he's the dragon reborn."
"What?"
"Just do it."
".......He said yes."
"Tell him you are not darklings. He should open up."
".......Sweet. Thanks."
"No problem."
post Jan 17, 2008 - 7:33 PM
punkuup5150
Joined Apr 10, '07
From lodi, ca
if it does not have one built into the can allready then yea that sounds like a good idea if your primering it first then u shouldnt have to worry about it.
post Jan 17, 2008 - 8:22 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(punkuup5150 @ Jan 18, 2008 - 12:33 AM) [snapback]631727[/snapback]
You shouldn't have to primer it if you use good paint. We're not talking about exterior pieces that have to hold up against wind sheer.
"What?"
"Just do it."
"No problem."
post Jan 17, 2008 - 9:31 PM
CelicaST_CALI
Joined Feb 28, '07
can u make a write up on how to convert the little compartment below teh stereon into like a place to house switchs?
BANNED. for life, you moron.
post Jan 17, 2008 - 9:54 PM
thespacepanda
Joined Apr 12, '07
From Houston, TX
QUOTE(CelicaST_CALI @ Jan 18, 2008 - 2:31 AM) [snapback]631763[/snapback]
What does that have to do with paint?
"What?"
"Just do it."
"No problem."
post Jan 17, 2008 - 10:33 PM
azian_advanced
Joined Apr 18, '05
From Calgary
kinda offtopic, but i'd like to see someone paint their interior black, as in piano black finish. that'd look nice.. i'm not into colorful interiors..
post Jan 17, 2008 - 11:18 PM
CelicaST_CALI
Joined Feb 28, '07
idk...nothing i guess..lol
post Jan 18, 2008 - 10:22 AM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(CelicaST_CALI @ Jan 17, 2008 - 9:31 PM) [snapback]631763[/snapback]
Do u have the kind where you push a little button down and it flaps open?? IF so, its pretty easy. First, you take the compartment out, just unscrews from the headunit iirc. Dremel the back piece off, so that you have a strip of plastic and your box, minus the backing wink.gif . Now sand down the edges of the strip to make them straight and allow just enough space to slide the strip into the box, and mark and drill your holes for the switches on that strip.
Now the fun part, what you want to do is epoxy that strip approx 1/2"(you know, or whereever looks good to you) from the front of the compartment box opening. I suggest fabbing up 2-3 1/2" spacers out of MDF/wood/etc that are the same height as the compartment and that will hold the plastic strip evenly when you close the flap so that the epoxy can set.
Once the epoxy sets, you can just mount the switches and run the wires out the back of the box (easier if you use a few extra inches of wire so that you can wire it up in front of the box, and then just push them in their holes and that should be that. Enjoy.
I have no pictures because I haven't done this yet..but I've been thinking about this little mod for a while.
post Jan 18, 2008 - 11:56 AM
DEATH
Joined Dec 19, '07
From tx
95celGT did a killer job painting the interior plastics on my car with the same NightHawk Black Pearl that's on the exterior - looks really nice and subtle but def better looking than stock. I could get pics of that if anyone wants them.
This post has been edited by DEATH: Jan 18, 2008 - 11:56 AM
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jan 18, 2008 - 3:34 PM
95st-celica
Joined Mar 29, '07
From Philly
^^ yes
1988 Dodge Aries K (sold)
post Jan 18, 2008 - 8:49 PM
mrgrape
Joined Jun 21, '07
From SoCal
do u have any pics of doing it this way????
i wanna see the after pictures
post Jan 25, 2008 - 6:12 PM
Marbledpearlceli...
Joined Sep 9, '07
From tampa
yes adhesion permoter would be good but isnt needed like they said no windsheer lol ill have pics up of mine this weekend i did mine the marble thats on my hood but reversed its the black popping threw the green ,,,, and also as far as the spray gun goes for small things you can use a cheaper HVLP gun and it will work you wont be able to see blotchyness like on a outside pannel
Lo-Fi Version Time is now: November 23rd, 2024 - 8:39 AM
