> Turbo timer in the 5sfe, Finding the right wires!
post Aug 20, 2003 - 3:32 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
Has anyone ever installed a turbo timer in a 5sfe? I know it sounds kinda dumb but you do not need a turbo to run one!!! Anyway....I am getting ready to put one in and thought it might make my job easier to ask someone on here first. I would like to know the location and colors of the wires to tap into. Or if someone has a manual that can look up a few wires for me, that could help!
GT-4 people might be able to help me out????
The wires can't be that much different??
I really only need : speedo wire, ign on, start, ign acc, and emer brake!!!!
Any info is welcome...
post Sep 9, 2003 - 11:38 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
Nevermind, I figured it out!
post Sep 9, 2003 - 12:31 PM
How did you manage to use your e-brake circuit? No matter what I tried, I've never been able to tap into the e-brake circuit for my remote start.
Also, did you tap into the driver's side door pin in order to turn off the lights once your car shuts off?
post Sep 17, 2003 - 5:29 PM
Ok im doing the timer now and for my timer i need IG1, IG2, Batt and some others that are on the ECU. From what i have gathered IG2 is Blue w/Red wire, IG1 is Blue w/Orange wire, and Batt is white. Heres the thing, i dont have an Blue w/orange, ne body have any knowledge of this ?
post Sep 17, 2003 - 6:42 PM
yeah ok i figured it out - BLACK with orange
post Sep 18, 2003 - 6:57 AM
edo17982
Joined Dec 21, '02
From Italy
are the wires the same for the ST?
post Sep 18, 2003 - 10:08 AM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
All you need to do is find the:
ACC wire... I used the one that goes to the clock
Batt wire... Can hard wire to fuse box or tap into any pos wire that is always on
IGN wire... he was right it is the black with orange stripe(not sure for the st ) all you need to do is hook up a multimeter to it and turn the key to that position and see if it gives you a voltage.(just to be safe for you st people)
Ebrake wire... under the center console right where e-lever is (one wire)
I actually have not hooked up the speedo wire yet and it works already ????
(I am having trouble finding it)
That is an interesting point about the headlights but i always turn mine off before i get out of the car so i will have to check on that???? Good look on that!
post Sep 18, 2003 - 12:09 PM
TRDCelicaST
Joined Mar 21, '03
From Pittsburgh, PA
DGPerformance
I started at CALU last fall and saw your car around campus a few times. Are you still in the area? Id like to check out your car and bs with ya if you are. I live in the PGH/South Hills area and commute to school.
post Sep 18, 2003 - 7:59 PM
I dont have a speedo with mine, im assuming that the HKS one has that so that it can automatically set the timer. I think i have that i have to check but i have A/F ratio, O2 sensor and voltage in mine, and its the size of a pen.
On the GT the Battery wire is white, the IG2 is Blue w/red stripe, and the IG1 is Black w/Orange stripe. The ebrake is just the single wire that plugs into the brake, i used an electrotap and its really simple to use, no cutting or splicing.
post Sep 24, 2003 - 12:03 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
[QUOTE]DGPerformance
I am student teaching but i still live like a few blocks off campus!
post Sep 25, 2003 - 6:36 PM
1bwilson
Joined Aug 30, '02
From Maryland
DG,
Did the TT fit right into the clock like that? I was going to put mine there or under the radio.
-Bryan-
Member of Team 5sfTe
post Sep 30, 2003 - 1:10 PM
ToYCeLi8
Joined Mar 6, '03
From South Central Los Angeles and Long Beach, CA
The HKS TT fits exactly where our clocks are at, next to the hazard lights button. Thats where i put mine. Ill try posting pics up soon.
David
post Oct 1, 2003 - 12:51 PM
DG_Performance
Joined Jun 21, '03
From Pennsylvania
Bryan,
No it does not fit right into the clock space but it is only off (vertically) by about 1/8 of an inch so it was really easy to take and file it down. The width is pretty much right on and you only need to widden it slightly (paper thickness). Anyway it is worth the small amount of work that it took to make it look that good. It really looks like a stock item in the car if you do it this way.
Hope this helps you,
DG
Lo-Fi Version Time is now: February 17th, 2025 - 3:32 PM
