> Parts needed to make a beams 3sge?
post Jan 20, 2008 - 6:44 AM
GER-CELI
Joined Jan 14, '08
From Germany
What parts i need to make my 3gen 3sge to beams?
Or its better to swap?
Greets from Germany
ICQ: 270423730
post Jan 20, 2008 - 12:08 PM
pasqual
Joined Nov 4, '06
From POLAND
QUOTE(GER-CELI @ Jan 20, 2008 - 6:44 AM) [snapback]632544[/snapback]
I did this swap 4 months ago ...
what you need is :
exhaust Y pipe
and top of air-box ..
if you dont have with beams engine You need MAF sesnsor
swap is PnP ......no problems
1. Air intake + MAF sensor (beams -> right )
2. Y-pipe (beams bellow)
3. You need cut and make longer wiring (about 1m ...RHD to LHD conversion)
(I will make photo later)
I see You are located in Germany ... Im in Brno CZ
This post has been edited by pasqual: Jan 20, 2008 - 12:21 PM
BEAMS swaped .......
post Jan 20, 2008 - 12:16 PM
GER-CELI
Joined Jan 14, '08
From Germany
no more?
camshafts....
did u feel the difference.
u cam efrom poland, where u get the parts , and how expensive?
Greets from Germany
ICQ: 270423730
post Jan 20, 2008 - 12:24 PM
Kadett
Joined Mar 17, '05
From The Netherlands
QUOTE(GER-CELI @ Jan 20, 2008 - 6:16 PM) [snapback]632596[/snapback]
no more?
camshafts....
You cant just swap in some parts designed for the BEAMS, you need the ENTIRE engine.
post Jan 20, 2008 - 12:33 PM
pasqual
Joined Nov 4, '06
From POLAND
QUOTE(GER-CELI @ Jan 20, 2008 - 12:16 PM) [snapback]632596[/snapback]
no more?
camshafts....
no more smile.gif parts needed ........ read my prev post .. I edited it ...
camshaft are ok and will fit beams gearbox ....
difference is BIG smile.gif LSD power etc .....
I get parts from ASO not so much expensive ... I will provide You later ...
so Do you have Your beams ???? or just thinking about buy it ???
I have only one problem (I dont have time to fix it ) old RPM gauge dont want work .... with beams (diff signal ... )
post Jan 20, 2008 - 12:39 PM
GER-CELI
Joined Jan 14, '08
From Germany
before my corolla was crashed, iŽd ordered an 4efte, but i dont need it frown.gif
This importeur does have an Beams, grey or red top.
now i had to decide
Greets from Germany
ICQ: 270423730
post Jan 20, 2008 - 12:45 PM
pasqual
Joined Nov 4, '06
From POLAND
QUOTE(GER-CELI @ Jan 20, 2008 - 12:39 PM) [snapback]632606[/snapback]
now i had to decide
or maybe swap 3s-gte rev3 from MR2 (LSD ) .. more complicated but .... more power ..turbo etc
post Jan 20, 2008 - 1:54 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(pasqual @ Jan 20, 2008 - 5:08 PM) [snapback]632592[/snapback]
what you need is :
exhaust Y pipe
Huh???? You don't make sense. I think you misunderstood the question.
Anyway... to make your 3rd gen 3SGE into a beams, you'll need a COMPLETE Beams head with both manifolds and all sensors. You'll need Beams pistons, and finally, the exhaust pipes and intake studd mentioned. It's easier to just swap in a Beams.
post Jan 20, 2008 - 2:16 PM
pasqual
Joined Nov 4, '06
From POLAND
QUOTE(Kwanza26 @ Jan 20, 2008 - 1:54 PM) [snapback]632618[/snapback]
what you need is :
exhaust Y pipe
for me is clear for beams swapo You need buy comlete beams engine (exhaut , harnes ,all sensors etc )
He just told us he have ordered 4efte for corolla and want change order for beams (means comple beams engine )
ok maybe my mistake topic(question) is not about swap just make beams
so ...I forgot add one part more
1. BEAMS
a) (best chose is RedTop manual from celica st202 jdm .... but can be from mr2)
This post has been edited by pasqual: Jan 20, 2008 - 2:19 PM
Lo-Fi Version Time is now: February 17th, 2025 - 8:45 AM
