> Weird speedometer issues
post Jan 20, 2008 - 8:43 AM
aggieanton
Joined Dec 16, '07
From College Station, TX
Hey guys, i recently got a GPS unit for my celi and I've noticed that the speed the GPS says I'm traveling at does not match my speedometer readout. Basically, the speedometer is always overshooting my actual speed - for example, when the speedometer reads 80mph, the GPS says i'm traveling at 72mph, speedo: 70- GPS: 63, speedo 55 - GPS 50. It's not the GPS unit getting a bad reading - I did the same test in another car and it read the same as the other car's speedo. Weird thing is, it's not just off by some systematic amount - it's a ratio thing somewhere. Any ideas??
post Jan 20, 2008 - 8:50 AM
do you have aftermarket rims + tires?
they can throw your speedo out a few MPH.
post Jan 20, 2008 - 9:11 AM
stevest202
Joined Oct 28, '07
From epworth uk
speedos in car are usually slightly under but larger rims will increase this depending on tyre size but gps will be spot on i used my gps to set my speedo back up when i replaced dials hth wink.gif
post Jan 20, 2008 - 9:51 AM
aggieanton
Joined Dec 16, '07
Nope, i just have the stock 15's... It's just strange that the speedo would be off by THAT much. There has to be a fix for it somehow
post Jan 20, 2008 - 10:24 AM
QUOTE(aggieanton @ Jan 20, 2008 - 9:51 AM) [snapback]632560[/snapback]
what size are the tires?
post Jan 21, 2008 - 10:50 AM
DEATH
Joined Dec 19, '07
From tx
It's also very hilly in and near college station - can GPS account for that? If you look at the numbers he's posting it would seem to make a certain amount of sense. He's going 80MPH but down hill and the GPS can only "see" him from a nearly vertical position so it "see's" 72MPH. Does that make sense to anyone else?
Just an idea.
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jan 21, 2008 - 6:44 PM
laff09
Joined Jul 28, '06
From Delaware
QUOTE(DEATH @ Jan 21, 2008 - 10:50 AM) [snapback]632880[/snapback]
Just an idea.
It adjusts for that.
post Jan 22, 2008 - 1:02 AM
Daftboy
Joined Jun 30, '06
From West Windsor NJ, USA
GPS lags...
Lo-Fi Version Time is now: November 23rd, 2024 - 6:01 PM
