> Quick question?, 7AFTE CLUTCH
post Jan 20, 2008 - 8:56 PM
mikecelica
Joined Jan 31, '07
From Ontario, Canada
Jus need to know if the 7AFTE requires a stage 2 clutch or would a stage 1 exedy racing clutch be enough for about 200hp? thanks
post Jan 20, 2008 - 9:55 PM
95st-celica
Joined Mar 29, '07
From Philly
QUOTE(mikecelica @ Jan 20, 2008 - 8:56 PM) [snapback]632710[/snapback]
a stage 1 exedy or spec clutch will hold 200 fine anything more then that i would go with a stage 2
1988 Dodge Aries K (sold)
post Jan 20, 2008 - 10:13 PM
Dr_Tweak
Joined Mar 31, '04
From Summerville, SC
Exedy stage 1 clutches are advertised to hold 40% more torque than stock. Stock is 115hp, so 115x1.4= 161 ft/lbs of toque. Considering that most 7As run about the same amount of torque as HP when turboed, 200hp will be around 200ft/lbs of torque if not more. I would not put a 161ft/lb rated clutch on a 200ft/lb engine, unless your idea of fun is tearing your transmission out and replacing a brand new clutch that you just bought with a slightly more expensive one that you should have gotten the first time around. smile.gif
-Doc
Click here to see my swaps
drtweak@phoenixtuning.com
post Jan 20, 2008 - 10:18 PM
95st-celica
Joined Mar 29, '07
From Philly
QUOTE(Dr_Tweak @ Jan 20, 2008 - 10:13 PM) [snapback]632715[/snapback]
-Doc
this is true...depending on weither or not hes gonna get 200 out of the motor...if it was me i rather be safe and buy a stage 2
post Jan 20, 2008 - 10:30 PM
hurley97
Joined Mar 3, '04
From Portsmouth, RI
just as a reference... I love my Exedy Stage 2. it's a 3 puck style but has a good number of springs to compensate. it's a little rough at first but once you get like 500 miles on it it'll wear in and once you get used to it you can drive it pretty smoothly.
I <3 Dustin---07/16/06
Lo-Fi Version Time is now: February 20th, 2025 - 1:53 AM
