Enthusiast ![]() Joined Mar 23, '06 From Mass Currently Offline Reputation: 0 (0%) ![]() |
my celica got dinged up a bit the other night and now my night driving lights no work. basically when i drive at night and if you behind me you think that i am driving with my lights off. the thing is that night some guy went a lil over the double lines and just like smashed my celica. the fender is gone and he also damaged my rear wheel well too. i checked all the fuses and none seem to be blown. after a few days of trying to figure out wat is going on my head lights are acting wierd. you kno how when you flash the high beams, well the thing now is that when i do that my low beams flash just as well.
heres a pic of the damage http://farm3.static.flickr.com/2265/219862...d7ed91d.jpg?v=0 it looked worse in person and i pulled the ding of the front bumper out This post has been edited by chandy1986: Jan 21, 2008 - 2:09 AM |
Enthusiast ![]() ![]() ![]() Joined Nov 17, '07 Currently Offline Reputation: 0 (0%) ![]() |
you might have a short somewhere
if i were to start looking for this short circuit where would i start?
If I were you check fuses first then look around where the accident was...
or it could be just as easy as a blows bulb in the front or back, I know that it could affect it, I'd check all the bulbs in front headlights make sure they are in working condition then check rear bulbs....
i kno for a fact that the brake lights and turns all work but the side marker isnt working. im also wondering why when i flash high beams my lows also flash wat could be the cause of this?
sounds like something possibly draining the battery, I'll stick to the short... the fact you were in a accident might be reason of short
![]() Enthusiast ![]() ![]() Joined Jun 26, '07 From Greece Currently Offline Reputation: 2 (100%) ![]() |
I had a simiral problem and i find out that it was the printed circuit of the fusebox in the left side of the steering wheel inside the car! Maybe you should check it!
-------------------- Face your fears, Live your dreams!!!
something is definitely rong with my electricals. cuz my hazard lights did not work becuz the fuse was blown and now my clock and radio dont work. something is shorting out my system
Lo-Fi Version | Time is now: February 18th, 2025 - 3:47 PM |
