![]() Enthusiast ![]() ![]() ![]() ![]() Joined Aug 31, '02 From Virginia Currently Offline Reputation: 4 (100%) ![]() |
Hello. For those parting out a GT or 5SFE engine, I am looking for both the intake and exhaust camshafts. If you could include any seals/washers/rings that are attached to them, that would be great too (I think the exhaust cam has like four of these things attached). And also, I would like all or some of your valve shims. Thanks!
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Dec 9, '05 From Bedford, TX Currently Offline Reputation: 11 (100%) ![]() |
i have an extra 5sfe available. do you want the whole cylinder head instead?
QUOTE(My2Celi @ Jan 21, 2008 - 10:37 AM) [snapback]632917[/snapback] i have an extra 5sfe available. do you want the whole cylinder head instead? Wow! The whole thing! I think that would cost a fortune to ship. You can't just part out the items I'm looking for? ![]() |
bump!
you dont need the shims, they wont work.
more than likely, you will need to order the shims from toyota, when you swap cams you end up needing mostly larger than normal sizes. -------------------- Former Team 5SFTE pro member ;)
Bump. No need for the valve shims part of the request.
bump
Enthusiast ![]() ![]() Joined Oct 18, '07 From Orange County, CA Currently Offline Reputation: 3 (100%) ![]() |
i got 5sfe cams but they are from '90 celica.
QUOTE(JasonX @ Jan 27, 2008 - 11:21 PM) [snapback]635250[/snapback] i got 5sfe cams but they are from '90 celica. Thanks, but I'm told that only 92-99 Celica will work. |
Lo-Fi Version | Time is now: February 13th, 2025 - 6:06 PM |
