anybody with a 7afte help! |
Jan 22, 2008 - 8:59 PM |
Enthusiast Joined Oct 27, '05 Currently Offline Reputation: 0 (0%) |
pabel89, your post is hard to read. there is no fullstop, comas and so on. I don't even know when is your sentences complete. With plp hard to understand what you're trying to explain, how can plp help you to troubleshoot?
Jan 22, 2008 - 9:03 PM |
TRD94,
yeah, basically im having the same "issue" as you do. at idle it was running rich but lean out nicely to 11-12 ratio on boost. I was told its due to limitation on piggyback (im using emanage blue) but its ok with me |
Jan 22, 2008 - 9:08 PM |
Enthusiast Joined Jan 9, '05 From green springs ohio Currently Offline Reputation: 1 (100%) |
QUOTE(normality78 @ Jan 22, 2008 - 9:03 PM) [snapback]633438[/snapback] TRD94, yeah, basically im having the same "issue" as you do. at idle it was running rich but lean out nicely to 11-12 ratio on boost. I was told its due to limitation on piggyback (im using emanage blue) but its ok with me -------------------- |
Jan 22, 2008 - 9:15 PM |
Jesus Christ... some of you guys need to go back to school.
QUOTE so we tuned it to run 8psi and it would run good at idle and at full boost it would richen upto about 14:7 . that would be a ok tune for the setup you got . 14.7 under boost will blow your motor. You should be aiming for anywhere between 11-12afr. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 22, 2008 - 9:23 PM |
QUOTE(lagos @ Jan 22, 2008 - 9:15 PM) [snapback]633448[/snapback] Jesus Christ... some of you guys need to go back to school. QUOTE so we tuned it to run 8psi and it would run good at idle and at full boost it would richen upto about 14:7 . that would be a ok tune for the setup you got . 14.7 under boost will blow your motor. You should be aiming for anywhere between 11-12afr. sorry that is my bad... you are right i was totally thinking of something else . boy i feel like a retard. it was a 12hr day at work and i was up way to late last night. and sorry for the bad typing. i will try to do better. sorry again. -------------------- |
Jan 22, 2008 - 9:39 PM |
Enthusiast Joined Sep 28, '07 From new jersey Currently Offline Reputation: 1 (100%) |
ok i order wideband from ebay $300 freaking crazy...if i knew this setup was going to be so expensive ive would of gone with the 3sgte swap.ok now tht i got my wideband this what im planning to do: right now my car is in my driveway, what im a do is install the 3sgte map sensor,drive to my mechanic, im a install the intercooler to the turbo so it can start boosting then go one with the tuning from thier. anything wrong with tht let me kno should i get a tow truck?
Jan 22, 2008 - 10:03 PM |
Enthusiast Joined Feb 26, '07 From Boston, MA Currently Offline Reputation: 1 (100%) |
well do you know what wideband you bought and why it was $300 as opposed to some cheaper ones out there
Jan 22, 2008 - 10:55 PM |
QUOTE(pabel89 @ Jan 22, 2008 - 4:19 PM) [snapback]633318[/snapback] this what im going to do im going to 1) install the 3sgte map sensor turn on my car see if anything is diffrent 2) im going to put the coupler the attaches to the intercooler from the turbo 3) what u mean by wideband? the air/fuel ratio gauge, yes i have that on the car is running really rich. first of all, these should all be installed at the same time. 1) without it your car is not capable of reading boost properly 2) by leaving that off, that is how you destroy your turbo 3) a wideband is the one that reads your a/f ratio in numbers. anything else is useless. This post has been edited by hurley97: Jan 22, 2008 - 10:56 PM -------------------- |
Jan 23, 2008 - 12:29 AM |
Enthusiast Joined Aug 8, '07 From United States Currently Offline Reputation: 4 (100%) |
Ok, first off.
WTF is your definition of choking? Is it: A: Smells like gas because it is running far to rich or B: Lacking fuel because its lean with no tune. Proper answer is B. Choking means you are lacking whats needed. However, it seems you are using A. This is still irrelevant and refer to my last post in red. Install everything the way it should be, put the damn map sensor in and tow the damn car to the tuner. -------------------- |
Jan 23, 2008 - 6:48 AM |
the car is running like tht cuz it isnt tune, it feels like the car is running on fuel then in between air then fuel again.
Jan 23, 2008 - 7:07 AM |
your asking the same question over and over again. you need to stop looking for more answers and just do it.
there's plenty of information in this thread already, you need to go back and understand it all before you post again. I think everybody else should stop replying until you have something new to say. -------------------- |
Jan 23, 2008 - 9:04 AM |
actually, no point for arguing now. the best is, fix the goddamn 2bar map sensor and tow to the nearest reliable tuner. period.
Jan 23, 2008 - 2:29 PM |
tht what im doing this weekend.
Jan 23, 2008 - 2:43 PM |
QUOTE(pabel89 @ Jan 23, 2008 - 2:29 PM) [snapback]633703[/snapback] tht what im doing this weekend. Dude, really ... what the hell does "tht" mean? Is English your second language or something? -------------------- 15PSI - 30MPG - Megasquirt Tuned
Jan 23, 2008 - 3:27 PM |
Enthusiast Joined Oct 7, '06 From wyomissing pennsylvania Currently Offline Reputation: 2 (100%) |
QUOTE(lagos @ Jan 23, 2008 - 2:43 PM) [snapback]633704[/snapback] QUOTE(pabel89 @ Jan 23, 2008 - 2:29 PM) [snapback]633703[/snapback] tht what im doing this weekend. Dude, really ... what the hell does "tht" mean? Is English your second language or something? hahahahaha this stuff is better than comedy central i think he means 'that' "that is what i plan on doing this weekend" i think the afr should be discussed some more, not making fun, but this is very entertaining. wish you luck with getting it tunned and up n running correctly. a project usually costs alot more than planned when corners are cut. when good plans are set and all the parts function properly, there should only be minimal expenses. seems like someone jumped into a project too fast. best of luck again with your setup and i hope you can maintain it well enough to enjoy it on a regular basis -------------------- you know why they put sheep at the edge of a cliff.... that way they push back!
(2:27:32 AM) edit: please f*cking work, f*ck, sh*t, piss (2:28:08 AM) edit: that did the trick |
Jan 24, 2008 - 12:12 AM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
Man you guys have all the fun here. Bro you need to turn the car over to someone who knows what they are
doing. You do not. I recommend you keep reading through all these post to get your knowledge up a bit. Everybody has to start somewhere, but your far from doing the job right. Why blow up your hard work? This post has been edited by madmods: Jan 24, 2008 - 12:13 AM |
Feb 2, 2008 - 11:28 PM |
alright i fix that little problem i had with my injectors. i have a question its probrably been coverd here but i wanna kno, if i use stock injector and a fmu how much boost will the engine take before maxing out my injectors, also how does that work the FMU, im just curious just in case this problem i had comes up again with the injectors?
Feb 3, 2008 - 3:34 AM |
so what is the actual problem on your previous? tuning or injector starve as the rest mentioned?
This post has been edited by normality78: Feb 3, 2008 - 3:37 AM |
Feb 3, 2008 - 7:47 AM |
i had to tune it, but also something about how my injector harness, wasnt sending enough volts to the injectors.
Lo-Fi Version | Time is now: November 28th, 2024 - 1:34 AM |
