California, Upgrades and such |
Jan 24, 2008 - 7:48 PM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
it'll be pretty difficult to find your rx-7 in decent condition. the rotary engines aren't as long lasting so you're most likely gonna run into some problems as opposed to a 15-year-old toyota. and if you're not very knowledgeable under the hood, then a rx-7 might be too much to handle. as for a turbo kit... put one together yourself. it'll be much cheaper, and most likely better than buying the whole kit. plenty of info on what you need and what to do. http://www.6gc.net/forums/index.php?showtopic=5574
-------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Jan 24, 2008 - 8:51 PM |
Enthusiast Joined Apr 22, '07 From Bay Area, California Currently Offline Reputation: 14 (100%) |
actually here, this is quoted from the CARB website:
The following list will help you determine if a part for your vehicle is a replacement part and legal for use on pollution. Check the manufacturer's catalogue to verify vehicle application and look for disclaimers, such as "Not legal for street use in California." Air Cleaner Most emission controlled vehicles will have an air cleaner that is a closed element type or thermostatically controlled. A replacement air cleaner must meet the same specifications as the original and connect to any emissions equipment that was attached to the original equipment air cleaner. Any replacement air cleaner elements may be used as long as they meet original factory specifications. Any air cleaner that does not meet the original factory specifications requires an Executive Order to be legal for street use. Cams The manufacturer of replacement cams determines which of their parts are considered replacements for original equipment. These replacement cams are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. A replacement cam must have exactly the same specifications (grind) as the original part. Cams that have different specifications than the original part require an Executive Order to be legal for street use. Carburetors The manufacturer of replacement carburetors determines which of their models are considered replacements for original equipment. These replacement carburetors are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Carburetors not listed as replacement parts by their manufacturer must have an Executive Order to be legal for street use. Catalytic Converters A legal aftermarket catalyst is one that is listed in an ARB approved manufacturers catalogue for the year, make, model, and engine size of vehicle on which it is being installed. Manufacturers of aftermarket catalytic converters must obtain an Executive Order for their products from the Air Resources Board in order to be listed in an approved catalogue. Coils and Ignition Wires Any type of coil or ignition wires may be used as long as they meet original manufacturer specifications. Computer Chips Replacement computer chips must be an original equipment manufacturer part. Aftermarket computer chips must have an Executive Order to be legal for street use. Electronic Ignitions The manufacturer of replacement electronic ignitions determines which of their models are considered replacements for original equipment. These replacement electronic ignitions are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Electronic ignitions or electronic point replacement units for vehicles not originally equipped with these items require an Executive Order to be legal for street use. Swapping electronic ignitions from different years, engines, or makes is illegal. Distributors The manufacturer of a replacement distributor determines which of their models are considered replacements for original equipment. These replacement distributors are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Swapping distributors from different years, engines or makes is illegal. Aftermarket distributors that are not listed as replacements for the original part require an Executive Order number to be legal for street use. Fuel Injection The manufacturer of replacement fuel injection systems determines which of their systems are considered replacements for original equipment. These replacement fuel injection systems are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Fuel injection systems not listed as replacement parts require an Executive Order to be legal. Modifications that change a vehicle from fuel injection to carburetion or from carburetion to fuel injection also require an Executive Order to be legal. Fuel Tanks Replacement fuel tanks must be identical to the original part. Add-on fuel tanks, or tanks with greater capacity than the original tank are legal for street use only if they have been issued an Executive Order. Heads Replacement heads must be identical to the original part. Head swaps from different years, engines or makes are illegal. Aftermarket heads or valve train components that are not made to the same specifications as the original parts require an Executive Order to be legal for street use. Headers Non-Catalytic Converter Equipped Vehicles Headers for non-catalyst equipped vehicles are considered legal replacement parts as long the replacement header allows for the installation of all smog control equipment originally attached to the stock exhaust manifold. Depending on the vehicle, some of the equipment that would normally be attached to the exhaust manifold includes: Air Injectors Heat Shields for the Thermostatic Air Cleaner Heat Risers EGR System Hookups Fuel Evaporation Systems Catalytic Converter Equipped Vehicles Headers for use on catalytic converter equipped vehicles require an Executive Order to be legal for street use. Intake Manifolds The manufacturer of replacement manifolds determines which of their models are considered replacements for original equipment. These replacement manifolds are then listed by vehicle year, make, model and engine size in the manufacturer's catalogue. Replacement manifolds may be made of a different material than the original part, for example polished aluminium instead of cast iron, but the design of the casting must be the same. Any manifold not listed as replacement part by its manufacturer must have an Executive Order to be legal for street use. Carburetor adapter plates are not legal unless they are an integral part of a replacement manifold. Other Internal Engine Parts Replacement internal engine parts, such as pistons, rods, or the crank, must be designed to factory specifications. Oversize parts can be used as long as they are within factory tolerances for replacement engine parts. Any part not built within factory specifications requires an Executive Order to be legal for street use. Transmission or Transaxle Transmissions and transaxles changes alone are not legal. Transmissions and transaxles can only be changed along with their matching engine. The total engine transmission package must conform to the engine change requirements above. Replacement Engines Entire engines can be replacement parts. As with any other replacement part, the engine must be identical to the original. If the replacement block or engine is obtained without emissions equipment, all the equipment from the original engine must be installed on the replacement block. If the engine is not identical to the original then it is not a replacement part, instead it is considered an engine change. Engine changes are a modification that must meet certain requirements to be legal (please see "Engine Changes"). Japanese Replacement Engines Used engines imported from Japan can be used as replacement engines as long as the engine being used has been identified as functionally identical to the original engine. Please refer to the engine importers catalogue to determine if a replacement engine is legal for installation in your vehicle. Engine Changes Engine changes are legal as long as the following requirements are met to ensure that the change does not increase pollution from the vehicle: The engine must be the same year or newer than the vehicle. The engine must be from the same type of vehicle (passenger car, light-duty truck, heavy-duty truck, etc.) based on gross vehicle weight. If the vehicle is a California certified vehicle then the engine must also be a California certified engine. All emissions control equipment must remain on the installed engine. After an engine change, vehicles must first be inspected by a state referee station. The vehicle will be inspected to ensure that all the equipment required is in place, and vehicle will be emissions tested subject to the specifications of the installed engine. Exemptions for Uncontrolled Vehicles Vehicles that were manufactured before emission control regulations took effect are called uncontrolled vehicles. Aftermarket parts regulations and anti-tampering laws do not apply to these vehicles. Uncontrolled vehicles may have any aftermarket add-on or modified part installed as long as the vehicle can still meet the tailpipe emission standards for the year of the vehicle. Uncontrolled vehicles must retain any original or retrofit crankcase control (PCV) devices and NOx device required for the year of the vehicle. The following vehicles are considered uncontrolled vehicles: 1965 and Older : U.S. Manufactured California Certified Vehicles 1967 and Older: U.S. Manufactured Federally Certified Vehicles 1967 and Older: Foreign Manufactured Vehicles -------------------- You say you don't understand how we go dumb, but have you ever been where i'm from?
-=-] Livin it in tha bay's a lil different [-=- |
Jan 24, 2008 - 10:02 PM |
Enthusiast Joined Mar 20, '07 From Bakersfield, CA Currently Offline Reputation: 10 (100%) |
QUOTE(j0e_p3t @ Jan 25, 2008 - 12:48 AM) [snapback]634207[/snapback] it'll be pretty difficult to find your rx-7 in decent condition. the rotary engines aren't as long lasting so you're most likely gonna run into some problems as opposed to a 15-year-old toyota. and if you're not very knowledgeable under the hood, then a rx-7 might be too much to handle. as for a turbo kit... put one together yourself. it'll be much cheaper, and most likely better than buying the whole kit. plenty of info on what you need and what to do. http://www.6gc.net/forums/index.php?showtopic=5574 I know, that is why I kicked myself for not jumping on this 93' RX7 with 38k original miles for only $17,888.00!!!! The guy said he is getting in another and will email me as soon as possible. One thing about me, is that I am a fast learner. I know people who would be willing to help me and show me things, if I have a car worth seeing. Otherwise if it is minor things I am on my own. I know those rotary engines aren't as long lasting, but dammit, they look so goooooooood. -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Jan 25, 2008 - 4:43 AM |
Hey what about dual exhausts? Well I mean having two separate exhausts in the back. Just because I see a kit that has space for one on each side and well...... It would be kind of silly to have only one exhaust with that other space there. Would that effect smog? Maybe go with two of those Apexi N1 that people get? Or is that just not practical? Just another question for you smarties out there (Yeah, I said Smarties... I dunno where that came from).
Jan 27, 2008 - 7:53 PM |
Enthusiast Joined Jul 28, '06 From Delaware Currently Offline Reputation: 0 (0%) |
QUOTE(Random_Stranger @ Jan 25, 2008 - 4:43 AM) [snapback]634343[/snapback] Hey what about dual exhausts? Well I mean having two separate exhausts in the back. Just because I see a kit that has space for one on each side and well...... It would be kind of silly to have only one exhaust with that other space there. Would that effect smog? Maybe go with two of those Apexi N1 that people get? Or is that just not practical? Just another question for you smarties out there (Yeah, I said Smarties... I dunno where that came from). 2 apexi n1s and 2.5-3" will run you like $1100 bucks man |
Jan 28, 2008 - 7:10 PM |
dual exhaust shouldn't affect smog if you keep the cat and what-not on the car. as far as practicality, dual exhaust on a 4-banger isn't gonna make any difference in performance. you can still do it if you like the look though.
Jan 29, 2008 - 12:51 AM |
Someone tell me where I can get the cat for the two exhausts please. $1100 doesn't sound too bad right now. There will be time to think it over though if needed. I am in no big rush. Need those lights changed first, need rims, and a drop. Then begins the tinkering....
Jan 29, 2008 - 2:04 AM |
you can make a custom cat-back exhaust with a y-pipe for the dual mufflers.
This post has been edited by j0e_p3t: Jan 29, 2008 - 2:04 AM -------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Jan 30, 2008 - 10:31 PM |
QUOTE(j0e_p3t @ Jan 29, 2008 - 7:04 AM) [snapback]635618[/snapback] you can make a custom cat-back exhaust with a y-pipe for the dual mufflers. That's what I figured. Some guy was selling a Kyo-- something that was a dual cat for the 7gc. Perhaps I could get my hands on that with some custom piping and take it to someone here in town. Any idea how much it usually runs for labor on custom piping or did the $1100 or whatever pretty much fall along those lines? I would imagine so. Oh well. I might go that route. It was just in case I decided to go wtih this one back end that had two spots for exhausts. I would think it would look silly if I got that back end and had just one exhaust to fill in only one spot. -------------------- 91 MR2 Turbo SW20, 92 MR2 Turbo SW20, 95 Celica GT ST204
Lo-Fi Version | Time is now: January 11th, 2025 - 1:51 AM |
